High voltage ac fuse?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Willie Walker, Jan 20, 2026.
  1. Willie Walker
    Willie Walker New Member
    22
    Salisbury md
    After swapping out 2 engine in prius Gen 3 the ac doesn’t work. If I disconnect neg 12 volt and orange disconnect from battery pack. Let seat for 15 minutes do you think I need 1000 volt gloves to take out fuse and check continuity? Thanks
  2. ChapmanF
    18,454
    Before trying that, or trying anything, I would start by asking the HVAC system for any trouble codes. (You haven't said a lot about just what sort of "doesn't work" you are seeing.)
    Start with the car off. Hold down both the A/C AUTO and FRESH/RECIRC buttons, while turning the car on (two power button presses, no foot on brake). Look for two-digit codes shown at the left end of the HVAC display, as described near the bottom of this page:
    Blink (a/k/a Flash) Codes – How to. | PriusChat
    BiomedO1 likes this.
  3. Willie Walker
    22
    Salisbury md
    I tried to do that and it didn’t work but I’ll follow your instructions and see if it’ll give me any codes. Thank you
  4. BiomedO1
    4,018
    2,109
    SacTown, Ca
    If you've removed the fuse to check continuity, why would current be flowing across it? Now pulling the fuse out, you'll need to be careful of residual current in the system.
  5. Willie Walker
    22
    Salisbury md
  6. Willie Walker
    22
    Salisbury md
    Hello I ran the ac diagnostic and it came up with 71 72. Could that point to a blown high voltage fuse in inverter? Thanks
  7. Willie Walker
    22
    Salisbury md
    hello I ran diagnostic and came up with 71 72 could that mean a blown high voltage fuse in inverter? Thanks
  8. rjparker
    10,411
    6,521
  9. Willie Walker
    22
    Salisbury md
    Yeah before I put the JDM motor into it. Coolant did get into the female connector for the air conditioner, but as soon as I did that, I took my compressor, and I blew all of it out thinking when the liquid with all those little metal prongs would cause electrical problem in the future. so then I could’ve blew that little fuse in the inverter box.
