Please help identify source of engine noise
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by batcat420, Dec 16, 2025.
  1. batcat420
    batcat420 Junior Member
    Atlanta
  2. Frontporch
    Frontporch Active Member
    535
    121
    Nj
    Its your brake booster pump. Seems louder than it needs to be. I can hear mine sitting in the driver seat. Always comes on when I open the driver's door and will cycle on again after using the brakes a little bit. Its normal. What is not normal is if it cycles on when you are not using the brakes. That is a pretty good indication that there is a leak
    I swapped out my master cylinder (accumulator?) and it definitely helped, but I have read of others that had the cycling going on for years.
    bisco and batcat420 like this.
  3. PriusCamper
    PriusCamper Senior Member
    12,956
    5,268
    Pacific Northwest, USA
    Monitor how often you hear the noise... Once you hear it more than once in a minute its time for a brake booster pump swap.
    batcat420 likes this.
  4. bisco
    52,231
    houston, all systems normal
  5. indel
    indel Member
    251
    78
    Northwest Indiana
    I normally hear this sounds whenever I am coming to a stop (using brakes of course) and it goes away as soon as I am fully stopped. Perhaps it's not the same sound, but I definitely do not get it when the vehicle is stationary, unless the car is not on and I open the driver's door.
  6. batcat420
    Atlanta
    The noise is happening every 15 seconds or so now. Just ordered part number 47070-47060 (pump assembly, brake booster). Wish me luck!
  7. ASRDogman
    ASRDogman Senior Member
    7,724
    3,960
    Mine has been cycling at 22 seconds for several years.....
