SUB-BATTERY MALFUNCTION INTEGRATED CAPACITOR (INTEGRATION CONTROL SUPPLY)
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by otatrant, Jun 1, 2025.
  1. otatrant
    otatrant Active Member
    345
    210
    San Francisco
    2023 Prius Prime
    XSE Premium
    Got a message while driving that SUB-BATTERY SYSTEM MALFUNCTION back in April. Was able to clear the message by restarting the car. When the error popped up I lost the ability to use radar cruise control. Happened again a couple of weeks ago and my dealer called me while I was driving and set up an appointment.
    Took it into the dealer this last week and here is a summary of the service which was covered under warranty.
    They wanted to know if I had installed any aftermarket accessories which I haven't. Still a mystery as to what triggered the INTEGRATED CAPACITOR (INTEGRATION CONTROL SUPPLY) part to fail.
    Interested to hear if anyone else has run into this issue.
    soft_r likes this.
  2. klerk99
    klerk99 New Member
    US
    Have you figured it out yet?
  3. bisco
    52,187
    it's at the bottom of the dealer work order
  4. priusasa
    priusasa Member
    95
    47
    2023 Prius
    can I ask which warranty covered this issue, Bumper to bumper, Power train or Hybrit system warranty?
  5. otatrant
    345
    210
    San Francisco
    2023 Prius Prime
    XSE Premium
    Not completely. Had a second sub-battery system failure most likely due to a different cause. My best guess to what caused it the first time is a short I made by accident in the 12V auxilliary power port while trying to check the voltage with a multimeter. Wasn't careful enough and accidentally let one of the probes of the multimeter touch both the tip and the side at the same time.
    The second time my best guess to the cause was running a readiness test on the car while the car was in 'Room Mode'. Trying to clear a error code on the digital rear view mirror and subsequently ran a readiness test to see if it was cleared but the car was not in 'Ready' mode. The result was that the second time it discharged supply control capacitors beyond a point that could be recovered.
    My understanding is that it is kind of a grey area which warranty covers it. Looking at the service document I don't see any indication as tto what warranty covers it. I saw a video while waiting for my car the second time from The Car Care Nut about how Toyota sends components to an electronics specialist to look for the cause. Without me telling them they indicated in conversations that the first failure was due to a short and the second failure was due to excessive drain.
    I am guessing if you have a part that is failing due to a known design flaw or some other issue due to some other oversight by Toyota and you are out of the 3 year bumper to bumper the same part can be covered by Powertrain (5 year) or the hybrid components (8 year) warranties. I got this impression from talking to my advisor at the Toyota dealer. The first time they covered it completely. The second time they gave me a loaner car and I bought the part from Impex for ~$325 plus import tax and shipping so probably more like ~$400 versus the $2k they quoted if I bought it from them. They comped the labor for the replacement the second time.
    One other thing I learned in the process was that Toyota America can comp the part for goodwill and it looks like this is an option they reserve for loyal customers that have purchased many of their cars. Toyota America did not decide they wanted to comp the part for me this time. This is my only Toyota.
    VelvetFoot likes this.
  6. priusasa
    priusasa Member
    95
    47
    2023 Prius
    Thank you for your response. I have the same part failed at 60.8k mileage and I still have extended powertrain waranty along with hybrit. But my dealer quoted me 1720 dollar to fix that. I escelerated the situation with the Toyota over the phone and lets see what is going to happen.
    My argumant is that this part is directly related to the transmission. The dash error says "Shift System Malfunction" and shift system is the transmission part. So it has to be under powertrain warranty. Also, when you use Toyota Techstream, the error code is under "Hybrit Live" section. So hybrit warranty can also cover this. As you said, its the gray area and off course the dealers will not want to pay.
    Its crazy that this part fails especially second time. Make sure you check your 12V battery voltage. Even the 12V battery is fine, the connection cables (positive and negative) needs to be clean and sit well.
    otatrant likes this.
