Mild sulfur smell when heat is on
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by indel, Jan 22, 2026.
  1. indel
    indel Member
    279
    88
    Northwest Indiana
    2012 Prius Two
    144K Miles
    - Engine does not burn any oil (at least it hasn't in the 2500 miles I have driven since I bought the vehicle)
    - No DTCs, pending or otherwise
    - No drivability issues, even in eco mode.
    A couple of times I have noticed mild sulfur like smell when the heat is on. The first time I was driving through rural area surrounded by farms, so I thought may be it was the fertilizer. But yesterday it happened again in the city. When this happens, I do not have any loss of power, no rattling noise and certainly no CEL or any codes in the system.
    I wonder if it could be the cat, or something else. How should I go about diagnosing this intermittent issue?
  2. PriusCamper
    PriusCamper Senior Member
    13,102
    5,310
    Pacific Northwest, USA
    Next time you smell it, pull over and check your exhaust system, as well as figure out if the smell is stronger inside the car or outside the car.
    I mention the exhaust system because back when I was a kid in the 80's my Dad bought a European car on the grey market and shipped it to California and had it equipped with emissions gear to get it road legal and that exhaust system was never quite right and had an overwhelming sulfur smell that never went away until the exhaust system cooled down.
    indel likes this.
  3. indel
    indel Member
    279
    88
    Northwest Indiana
    Can you expand a bit upon what you mean by check the exhaust system? A leak from exhaust manifold? Are you suggesting that the smell may be stronger in the engine bay if that's the case?
    One technical question: what proportion of exhaust gases are sent to EGR instead of tail pipe? I don't the mechanics of this but what are the primary leakage points? A gasket between the EGR cooler and the exhaust manifold may be one. Are there others?
  4. PriusCamper
    13,102
    5,310
    My point: Is the smell coming from inside the car or outside the car? Until we know that, we can't narrow it down.
  5. indel
    indel Member
    279
    88
    Northwest Indiana
    Gotcha.
    When I did some googling, 12V battery was mentioned as one of the potential culprits. I have a brand new 12V (Toyota oem) that I installed last month. I will check the vent tube to make sure it's not loose or something.
  6. rjparker
    10,577
    6,634
    If you have an exhaust leak upstream of the muffler you can hear the leak. Most likely its from the tailpipe feeding back from the windshield air intake in heating.
  7. indel
    indel Member
    279
    88
    Northwest Indiana
    I was wondering what chatgpt might be able to tell me. Probably on point. We will see.
  8. PriusCamper
    13,102
    5,310
    Thanks for sharing... It's nice to see my guess on it being exhaust system related has been validated.
    indel likes this.
  9. PriusCamper
    13,102
    5,310
    True... Also leaks upstream of the cat are easy to smell inside the engine compartment.
  10. rjparker
    10,577
    6,634
    In city traffic it is easy to smell other vehicles poorly performing exhaust, especially in heat where outside air is forced open. In cool mode, most run recirc which primarily closes off outside air.
    Plus the cat is not effective until its fully warmed up. Initial startups also have increased (rich) fuel trims. The cat can be ineffective as well although that "needs repair" situation usually codes unless an o2 sensor hack (illegal) is in place.
    I once was dealing with a woman who complained of exhaust smells and loud noises. Her gen2 cat was gone.
    #10 rjparker, Jan 22, 2026
