AC Blowing Not Cold
Discussion in 'Gen 3 Prius Technical Discussion' started by PriuSocal, Jan 22, 2026.
  1. PriuSocal
    PriuSocal Member
    309
    52
    SoCal
    Car: 2015 Gen 3
    The AC blows but I don't feel its cold enough. Of course, here in SoCal it is still winter and its chilly outside so the slight cold air may be due to the outside temp of 61F. I started the diag process and checked the AC fuse under the dash and it was fine, next i took the airbox out and noticed the plug to the AC compressor had come off so I thought that was my issue so, I cleaned up the male/female ends with electronic parts cleaner and added a bit of dielectric grease (just a pin size in each pin) and replugged it and still no change. I then connected my “basic” AC gauge that comes with the AC Pro can and it read low, so I added a bit just to see if any change was made and nothing. I also checked the peephole on the hose and nothing was moving inside (not sure if I am suppose to see freon moving), lastly, I checked my cabin air filter and it was super dirty and appeared clogged from debris, I removed it just to let the free air flow to see of that helped and nothing.
    Anyone ever experience this? If so, have I missed something or any ideas what to look at next? I do have the AC Gauge manifold to dive into it further but wanted to checl with just basic tools at the moment to see if I could find the issue.
    Also, there are no codes.
  2. BiomedO1
    4,059
    2,136
    SacTown, Ca
    You should see bubbles in that peep hole, unless the system is overfilled.
    Have someone else start the car and set temp. to Lo, fan on high; activate AC button. You should see a spurt of bubbles. Both radiator fans should start spinning.
    Hope this helps
    PriuSocal likes this.
  3. PriuSocal
    PriuSocal Member
    309
    52
    SoCal
    I hooked up my Icon T10 scanner and noticed there was a special function called “ AC System Relearn/Initialization” then “ Servo Motor Initialization” then a message saying “Use this function when the servomotor or the AC ECU is replaced or the battery disconnected (12 battery indeed replaced 50 miles ago). Then “This function is used to servomotor initialization of AC”. I proceeded and then heard a loud buzz coming from the front and noticed the AC compressor was now working and a “clear” liquid flowing thru the peep glass BUT AC was not cold still. I hooked up my basic gauge and it read LOW. I also noticed that when in the car, I would turn AC off and would hear the compressed air hiss that you get when shutting off the AC.
    On my 08, the AC compressor running just sounds like an electrical humming but not a loud buzz like this. I am not sure if this is normal but I will post a video of this soon. I hope its not an indication that the compressor is toast although it appears to be running.
    #3 PriuSocal, Jan 22, 2026
  4. PriuSocal
    PriuSocal Member
    309
    52
    SoCal
  5. Tombukt2
    13,336
    2,401
    Yeah that's no good. So when this starts to happen or when you activate the compressor do you see the low side gauge get sucked down from the lo gauge buried .? Should come down to near 40 PSI?
  6. PriuSocal
    PriuSocal Member
    309
    52
    SoCal
    Whats not good? The noise? I have not used the professional AC manigold gauges as mentioned, I only used the gun style gauge that comes when you buy the AC Pro R134 can. When the compressor came on, I reattached the gauge but the can was empty and ot showed LOW now as mentioned above. I didnt have any r134 left in the can to see if the gauge moved up. I will be checking it again with my HF manifold gauges for a more accurate reading.
    My biggest concern right now is the loud buzzing sound coming from the compressor. It appears too loud to be normal. Then again I have never heard the AC on a gen 3 before.
    Also, I checked the hood and says the AC uses a total of 520g of freon on an empty system as well as the ND-11 oil. I recall doing this on my Honda Odyssey van when I replaced the AC condenser. I pulled a vacuum for a few hours and then closed off the lines and waited 30 mins to make sure it held pressure. Is the process the same on the prius? If so, can anyone share the info from the manual or DIy?
    #6 PriuSocal, Jan 22, 2026
  7. JC91006
    JC91006 Senior Member
    16,825
    8,600
    The Gen3 cars have a pretty loud AC compressor noise. That's not the problem here. You can get that AC properly recharged for about $150
    Mendel Leisk and PriuSocal like this.
  8. PriuSocal
    PriuSocal Member
    309
    52
    SoCal
    I can do so myself, just need to figure out if thats all it needs or if there is a problem somewhere 1st. I have all the tools necessary to pull a vacuum and refill properly. The only thing I do not own is a recovery tank and wait for the rain to stop here.
    So as far as the sound in my video, you're saying that sounds normal? I personally think if that is normal, it is quite loud (im used to my quiet gen 2 AC)
  9. JC91006
    16,825
    8,600
    yes the noise is normal. My gen 2 car is much quieter than my gen 3 car.
    I've never manually added refrigerant, always used a machines to draw out the old stuff and put in the proper weight when refilling. The symptom that you have is similar to when my gen 2 ran low on refrigerant. Adding to it fixed the problem.
  10. PriuSocal
    PriuSocal Member
    309
    52
    SoCal
    I just saw this video of a guy replacing the compressor:
    and that compressor is not loud at all, you can hear him talking and mine is much much louder.
    Also, the main high voltage fuse that is in the inverter, I have seen when the compressor is not working some check that and have found it blown but I guess thats not my issue and no need to check that.
    Once the rain stops, ill have to bring my HF Manifold out to check properly.
  11. BiomedO1
    4,059
    2,136
    SacTown, Ca
    You need to evacuate and refill. It's a variable speed compressor, so you'll need to measure R134 weight for refill. That gun gauge will lie to you, since it's hash marks are for a continuous operation compressors.
    Hint: whenever I refill an AC unit, I always put in a few oz of oil and dye. Refrigerant slowly seeps out of AC systems and Freon levels gets low after 5-10+ years. That's normal and I also replace those Schrader valves too. If those valve has old rubber o-rings, they usually dry-rot and start leaking.
  12. JC91006
    16,825
    8,600
    if you are going to put Oil, you have to make sure you get non conductive ND11 oil. since this is an electric compressor.
  13. PriuSocal
    PriuSocal Member
    309
    52
    SoCal
    So would it be too early to say that it simply needs refrigerant and compressor is ok even as loud as it is? I also did cinfirm both fans are indeed on when AC is on.
  14. PriuSocal
    PriuSocal Member
    309
    52
    SoCal
    I have the ND-11 plus Dye that I put into my Odyssey, so that wont work? I googled “non-conductive ND-11 and nothing came up. Is that a parts store item or dealer only? Thanks for letting me know though as I would have never guessed that. Videos I have seen did not mention that.
  15. JC91006
    16,825
    8,600
    I think that would work fine, but I'm not sure you even need oil at this point. If you plan to top it off
  16. PriuSocal
    PriuSocal Member
    309
    52
    SoCal
    Got it. At this point I am going to check with the HF gauges and see where I am at on refrigerant and top off if needed. I would e concerned if it is very low because that sound of the compressor worries me even though you say it may be normal, all the videos I have seen so far of compressors on 10-15 prius, none sound like mine in good working condition.
    I would just hate to top off and then it still be bad, or perhaps if low and filling it up, compressor may quiet down a bit?
  17. JC91006
    16,825
    8,600
    I really notice it during summer, when it's 100 degrees out. I sometimes think the compressor is broken, it's really loud
  18. PriuSocal
    PriuSocal Member
    309
    52
    SoCal
    Its nowhere near hot here in SoCal. Its raining and 61 f degrees
  19. JC91006
    16,825
    8,600
    I'm just saying, it can get really loud and still be normal.
    I'm speaking from experience as I probably have owned more than 20 prius in the last 10 years
  20. Tombukt2
    13,336
    2,401
    I had two gen 3s in the Southeast USA never sounded like this . And I did replace 1 compressor still not for noise like this . Should sound like a good running gen2. Not very Audible. At least not like this . Don't waste freon.
