AWD vs FWD
Discussion in 'Gen 5 Prius Main Forum' started by HamiltonPrius, Oct 14, 2025.
  1. Templeton
    Templeton Active Member
    324
    115
    usa
    2024 Prius Prime
    SE
    Not wanting to add more fuel to the fire, but not all "AWD" systems are equal. There are mechanical ones and there are electrical ones. And among those categories, there are many different systems with considerable variation in purpose, function, performance, and effectiveness. For example, the ZR1X corvette has a type of electric AWD, but it is very, very different from the gen5 prius electric AWD. And, unfortunately, the gen5 prius AWD does not appear to be super effective:
    Isaac Zachary likes this.
  2. Blackat
    Blackat Active Member
    478
    339
    Colorado
    2023 Prius
    Limited AWD-e
    Good thing the roads aren't rollers....LOL. That's not a real life test. I've run mine pretty fast on snowy/ice roads in the mtns and it handle really well
  3. Templeton
    324
    115
    usa
    2024 Prius Prime
    SE
    You're correct about that, but nobody is saying that they are.
    Rollers are indeed a challenging test. But some cars with AWD are able to pass this kind of roller test with ease. Unfortunately, the prius AWD is not one of them.
  4. Moving Right Along
    Moving Right Along Senior Member
    731
    588
    The latest gen Camry failed the last test as well, and needed to be run in sport mode to pass one of the others. He concluded it’s good for some ice and snow, but would get overwhelmed by a lot.
  5. mingc
    mingc Member
    77
    58
    Portland, OR
    2023 Prius
    XLE AWD-e
    Of course they are. That's their whole point: rollers are like slippery roads. Otherwise, why bother?
    My takeaway from the video? When stuck on snow and ice or other slippery stuff, switch to sport mode and turn off traction control.
    #85 mingc, Jan 23, 2026
  6. ChapmanF
    18,509
    Sounds like a great recipe for ice polishing:
    These drivers work with the traction they've got:
  7. Templeton
    324
    115
    usa
    2024 Prius Prime
    SE
    My takeaway from the video? The AWD on the prius has very limited effectiveness.
  8. Trollbait
    12,667
    Yes to turning off the traction control. The gen2 didn't have a button for that, and the TC kept me from leaving my driveway.
    Eco mode would be better than sport though. You want more graduated throttle response when starting off to reduce the chance of spinning wheels when moving from a stop.
    BiomedO1 likes this.
  9. mingc
    mingc Member
    77
    58
    Portland, OR
    2023 Prius
    XLE AWD-e
    Guess we'll have to install winches.
  10. Templeton
    324
    115
    usa
    2024 Prius Prime
    SE
    No need, just don't get stuck in any giant snowbanks.
    I have only FWD, and I haven't got stuck yet. It's easy!
    :D
    mingc and BiomedO1 like this.
  11. BiomedO1
    4,096
    2,140
    SacTown, Ca
    Having weight directly above your drive axles really helps. Dealing with the traction you've already got and NOT breaking it, will keep the car under control. If you don't throw a few hundred pound sack of sand into your trunk, that rear axle will slide out from under the car anyways, AWD isn't going to help wheels that has already broken traction. Especially when people don't adjust their driving habits to conditions. IMHO; AWD is just a false sense of security, since most people don't know how to use it properly
    PS; you can also air down the tires a bit to get better traction. Most of us run our tires over-inflated to get more mpgs.
    mingc likes this.
  12. Winston Smith
    Winston Smith Active Member
    397
    271
    OH
    2024 Prius
    LE AWD-e
    Cutting the torque to the front wheels leaves them less likely to break traction.
    The tuning of the Toyota system in the Prius is set up so as to offer few surprises to a FWD driver. Provoking oversteer takes determination at low speeds and at higher speeds the front still washes out first.
  13. Mendel Leisk
    41,867
    Proportionally, on 17" and 19" rims? 3rd/4th gens were 195/65R15 and 215/45R17, for comparison.
