parking break 2011 Prius Squeaking Upon exit from vehicle
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Kthi, Jan 23, 2026.
  1. Kthi
    Kthi Junior Member
    33
    my 2011 gen3 chassis squeaks most times I get out of the vehicle with my parking break set. Doesn't do it when I do not apply the parking break.
    Do you think it's as easy as pulling the tire and hitting it with break cleaner? I did the breaks my self last February. And, it was all fine up until around last September.
    I appreciate any input.
  2. ASRDogman
    ASRDogman Senior Member
    7,758
    3,967
    Did you use the paste on the spot where the pads touch the caliper?
    #2 ASRDogman, Jan 23, 2026
  3. Mendel Leisk
    41,822
    Yeah see the “rear brake drag” link in my signature, (on a phone turn it landscape to see signatures).
    first time I did the rear brakes on our ‘10 I got bit by this; first car I’d had with rear disk brakes, and you HAVE to pay attention to caliper piston orientation, and ensure it’s well seated in that orientation.
  4. Kthi
    Kthi Junior Member
    33
    Thank you all, that gives me something to look at, check. I remember the post concern, maybe I didn't set the brake right and the piston rotated? Other than this noise, there seems to be no drag, so I'll check this out at my planned maintenance end of February. I'll update the thread at that time.
  5. ChapmanF
    18,452
    I wonder if it's necessarily the brakes at all. Setting the brake changes the forces on the suspension as you're climbing in/out of the car (with the brake set, the rear wheels can't roll; with the brake off, they can). Could be a suspension squeak.
    My 2001 started making awful noises that ended up being the driver's door moving against the rubber weatherstrip whenever there were twist forces on the body ... fixed by new hinges for the driver's door.
    Approach chassis squeaks with an open mind.
  6. Kthi
    Kthi Junior Member
    33
    Yes, thank you, I will check my suspension torques also. when it is happening I am on a very slight incline, my driveway.
  7. Mendel Leisk
    41,822
    Another relevant link, some pics of what my rear brake situation look like after my first (disastrous) rear brake job
  8. Kthi
    Kthi Junior Member
    33
    Perfect Mendel, the subtleties. I will be checking both brakes and suspension tightness.
  9. ChapmanF
    18,452
    Tightness of bolts and nuts isn't the whole suspension story. Bushings get funny, and stuff.
  10. Kthi
    Kthi Junior Member
    33
    Good to know I did replace the shocks about two years ago with all new bushings. I will definitely keep this in mind. Thanks!
