Solution to 12V issues? Disconnect 12v negative terminal sensor plug
Discussion in 'Gen 5 Prius Main Forum' started by Halcykon, Dec 1, 2025.
  1. BiomedO1
    4,020
    2,110
    SacTown, Ca
    Gently pry up on the locking clip and pull the connector back. Battery monitor should show 14+V, anytime the car is in ready mode.
    jbbass and VelvetFoot like this.
  2. Gokhan
    Gokhan Senior Member
    6,480
    2,593
    Paramount CA
    No pliers, you will break it. LOL
    I can’t believe someone wrote a 31-page whitepaper on this and posted it on Reddit.
    VelvetFoot likes this.
  3. lloydg
    lloydg New Member
    Houston
    2023 Prius
    Thanks. I got it off-before I broke it with pliers.
    VelvetFoot and Gokhan like this.
  4. Paul Gregory
    Paul Gregory Senior Member
    2,219
    587
    Alberta
    2024 Prius Prime
    XSE
    Of course it's anyone's choice to obsessively monitor voltages with a calibrated Fluke meter,
    to replace the battery at the first sign of degradation.
    But I'll speak for the rest of us, who recognize that a battery begins to degrade the moment you start using it,
    and we will try to get the best use out of it before replacing it.
  5. VelvetFoot
    VelvetFoot Active Member
    1,140
    449
    New York State
    2026 Prius
    It can be a fine line though, can't it? Cold snap, car starts fine in the unheated garage, park somewhere-like at an event at night, perhaps not by oneself, come out-no start. Break out the jump pack at -9f. Ugh.
  6. Paul Gregory
    2,219
    587
    Alberta
    2024 Prius Prime
    XSE
    I'd rather upgrade the battery before I chased after factory specs.
    I bought a 100 Ah lithium battery to replace the factory one, but I went a different route;
    I put it in parallel with my OEM battery, connected with a smart isolator.
    I've had zero problems since I fine-tuned the settings.
  7. Brian1954
    Brian1954 Senior Member
    2,371
    954
    South Central PA, USA
    I am curious. What settings did you change on the smart isolator?
    Are you still using the NOCO battery charger to charge the 12v battery, or don't you need to use it any longer?
  8. Paul Gregory
    2,219
    587
    Alberta
    2024 Prius Prime
    XSE
    I plug in my NOCO whenever I park where there is an outlet available.
    The 100Ah battery is no help in starting the car when the OEM 12V battery is flat.
  9. Brian1954
    2,371
    954
  10. Paul Gregory
    2,219
    587
    Alberta
    2024 Prius Prime
    XSE
    If memory serves...
    I set the cutoff voltage just under what the 12V OEM battery is set to charge to.
    It cuts in whenever the lithium battery falls below the 12V system voltage.
    I believe I have posted the settings on here a few months back, but I have probably tweaked them a bit since then.
  11. Paul Gregory
    2,219
    587
    Alberta
    2024 Prius Prime
    XSE
    Funny how the mind first settles on the complex solutions before arriving at the simple ones.
    I found an old booster pack with a two headed socket adapter, which I can use on any pack for boosting through the lighter socket.
    The batteries no longer hold a charge, but the accessories still work.
    I had a socket wired direct to the battery, protected by a circuit breaker. I'm reasonably certain I can boost the car through the live socket, without lifting the hood and going through the regular rigmarole.
