Prolong Battery Charger problem
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Todd Wallace, Jan 14, 2024.
  1. Todd Wallace
    Todd Wallace Junior Member
    Chatham NC
    Two Eco
    Hello folks,
    I foolishly attached my Prolong Charger with reverse polarity. I swapped out the fuses,then reattached correctly. Now it won't charge. The display Shows the correct 224v but charging amps reads -.024A steady. Any help here on a repair fix? I am open to suggestions...
  2. JC91006
    JC91006 Senior Member
    16,806
    8,593
    I believe you can email them directly for technical support. You should get an answer in about 2 days
    Brian1954 likes this.
  3. Brian1954
    Brian1954 Senior Member
    2,362
    949
    South Central PA, USA
    Did you replace the fuse in the wiring harness AND in the charger?
  4. Todd Wallace
    Chatham NC
    Two Eco
    Yes - I replaced BOTH fuses
  5. Todd Wallace
    Chatham NC
    Two Eco
    - before I tear into it to repair it.
    I am looking for a quick solution from someone who fixed the unit at home before I have to dig into it...
  6. Todd Wallace
    Chatham NC
    Two Eco
    The unit has been repaired - thanks for the assistance.
  7. "GREENGOBLIN"
    "GREENGOBLIN" New Member
    us
    How did you repair it?
  8. Carall
    Carall Active Member
    316
    104
    Harrisonburg, VA
    In my case, when the positive and negative wires fell onto the battery cover and caused a significant flash, burning out all the fuses, this LED driver failed.
