AC Blowing Not Cold
Discussion in 'Gen 3 Prius Technical Discussion' started by PriuSocal, Jan 22, 2026.
  1. PriuSocal
    PriuSocal Member
    308
    52
    SoCal
    Im with you on that. Otherwise every gen 3 video would sound this way.
  2. Tombukt2
    13,336
    2,401
    It could be damage from improper oil added at one point in cars life.
  3. Mendel Leisk
    41,850
    Has that equipment been used with various car AC systems? I'm out of my depth, but Repair Manual cautions against using equipment which may introduce oil other than spec into the Prius system. Not sure how crucial that is, say compared to dumping a incorrect oil in.
    We had lacklustre AC performance, starting about 5~6 years back, maybe a bit more. Went this route, no problems since:
    PriuSocal likes this.
  4. rjparker
    10,437
    6,544
    A set of gauges are as "basic" as it gets for ac system diagnosis.
    Has the ac ever worked (cold air) in your ownership? These systems get turn it up cold.
    How did this happen? They don't come off by themselves. Was it the orange high voltage plug or the control plug?
    The compressor is not loud. You "might" hear ir for a few seconds before both radiator fans engage - which are much louder.
    I would record the high and low side pressures with ac set for high fan and Lo temp. Windows open on a warm to hot day.
    Then when it was found to be low with some higher pressure on the high side you know the compressor is running.
    You can check the saturated r134a temperature on your low side gauge and it should be over 32f.
    At that point I would add r134a using refrigerant with no oil, dye or leak stop. Usually the cheapest small can. An ac guy's 30 pound can has no additives; neither should yours.
    Slowly add no more than 12 oz while watching the site glass. Stop when it is almost clear; no bubbles.
    If this cools it off you have a leak which must be found and repaired.
    If the compressor never adds pressure it is not running. However adding gas will usually engage the low pressure switch and allow compressor operation if it is functional.
    I would not be surprised if the compressor failed and someone unplugged it
    #24 rjparker, Jan 24, 2026
    PriuSocal and BiomedO1 like this.
  5. BiomedO1
    4,059
    2,136
    SacTown, Ca
    Yep; those connectors usually have a "lock tab"; they don't just fall off....
  6. PriuSocal
    PriuSocal Member
    308
    52
    SoCal
    It was used only once on my Odyssey but they both use the same refrigerant and I added the ND-11 directly to the low pressure line by removing the shraeder valve so no cross contamination.
  7. PriuSocal
    PriuSocal Member
    308
    52
    SoCal
    No, i bought the car that way where it was just cool air but never cold. When I found the plug off, I also thought someone might have deliberately left it off for a reason BUT when I installed it again I noticed the clip would not catch and would stay loose but connected. If i just use minimal tug, it comes off so another theory of mine was, it could have fallen off with a bump or something since it wouldn't “clip” to the base.
    Upon doing more video surfing, very similar issues indicate it to be low on oil as they say compressor gets louder when LOW on reffrigerant. So I wll try that 1st with my HF manifold gauges and check back
  8. PriuSocal
    PriuSocal Member
    308
    52
    SoCal
    Update:
    Brought out the manifold gauges and low side was under 25psi and high was about 100Psi. Added a bit of R134 and noticed after a few seconds that the compressor quieted down but was still on, now making just a very quiet buzz (nothing like the loud buzz it was making before) and I went to check the air and it was very cold now. Checked the gauges and low side went to about 32psi and high side 180ish> i stopped it there and it appears to be working fine now.
    AC has been on for about 30 minutes and working properly and very cold.
    Appears as some of you said, it was low on refrigerant.
    BiomedO1 and Mendel Leisk like this.
  9. BiomedO1
    4,059
    2,136
    SacTown, Ca
    The reason I usually push a few ounces of oil back into the system is because oil is pushed out with the freon leak. Low oil can fry a compressor.
    Just saying.....
