crazy cold weather this weekend..
Discussion in 'Gen 2 Prius Main Forum' started by highmilesgarage, Jan 23, 2026.
  1. highmilesgarage
    highmilesgarage Active Member
    489
    180
    Kansas City
    So I have to move my Prius into my garage so that my other car parked in the street can be parked in the driveway. It's 8F outside and when I started my Prius nothing happens.. it's not going "READY" mode so I can't move it. Tried several times and depressing hard the brake pedal (thinking that it might be bad) but no luck. I see all the lights up in the dashboard light but READY isn't lit. Voltage when turn is 13.8v on my cigarette lighter plug (it has voltmeter built in) I made it to turn on when I don't press on the brake and turn the start button on twice and when all the lights are on I press the brake pedal and press the start button again and it suddenly went to READY and engine started running.. Any experience similar with this cold weather? this is the 1st time I encounter this on my hybrid.
  2. VelvetFoot
    VelvetFoot Active Member
    1,161
    459
    New York State
    2026 Prius
    13.8. That’s too high. Not a true battery reading. In my opinion.
  3. PriusCamper
    PriusCamper Senior Member
    13,004
    5,286
    Pacific Northwest, USA
    That's the voltage from the DC to DC converter that's powered by High Voltage battery and used to run the vehicles 12v sytems as well as charge the 12v battery because car is in ready mode. It can go up to 14.1v.
    #3 PriusCamper, Jan 23, 2026
  4. PriusCamper
    13,004
    5,286
    With temperatures that cold you're gonna have glitches if your 12v is weak, especially if there's moisture in the vehicle from the usual Gen2 leaks. What's more the hybrid battery ECU dials back the packs available discharge and charge abiliity in temperatures that cold.
    In other words, report back when temperatures are above freezing if you still have issues, but suspect the symptoms will go away once weather warms.
  5. highmilesgarage
    489
    180
    Kansas City
    that's not the battery voltage since it's in accessory mode (cigarette lighter plug on when accessory mode is on)
    I suspect it could be a weak 12v...
    I just recently replaced the 12v battery (3 days ago) on my Lexus gx470, it died just a week after the 3yr warranty expired. Voltage is fine when fully charged but it has weak CCA to crank the motor. Now trying Costco batteries see if it's better than Walmart.
  6. VelvetFoot
    1,161
    459
    New York State
    2026 Prius
    Cold weather highlights the weak links. And hot weather as well, lol.
    Cornvalue likes this.
  7. pasadena_commut
    pasadena_commut Senior Member
    2,787
    832
    Southern California
    The 12V and/or the HV pack are too cold. So maybe try to warm them up, old school style? Heat a bunch of rocks, bricks, or what have you to about 115F in the oven. Hot enough to warm things up, not hot enough to burn you or melt plastic. Hustle them out and layer them over the top of the 12V compartment and over the HV pack. Put some sort of insulating layer over that. Even just newspaper, but an aluminized mylar blanket would be perfect. Wait a while for the two batteries to warm up. Try and start the car. There might be a possibility of the thermal shock damaging something, so caveat emptor. I don't think that is likely though, as here the heat has to diffuse through the hatch carpeting and floor material.
    How old school? Waaaay back in the day it was common to warm beds this way. Some methods were way more dangerous, where they would put hot coals in metal container and wave it around under the sheets, keeping it moving to avoid a fire.
    Bed warmer - Wikipedia
    Also, if it is just the 12V that is weak, you could jump the car and it should start. Of course if the HV is the problem, that won't help.
  8. Tombukt2
    13,336
    2,401
    Those temps I put my Stanley ceramic heater in the car on 750 watt . The temp dial on about 1/2 . Fan on medium . It can just sit in they're all night W no issues at all . Heater will shut off if any dumb shiet occurs.
  9. PriusCamper
    13,004
    5,286
    Why not just a space heater and an extension cord? Preferably radiator style, which is safest...
  10. Prius92
    Prius92 Active Member
    595
    122
    Iowa
  11. VelvetFoot
    1,161
    459
    New York State
    2026 Prius
  12. Cornvalue
    Cornvalue New Member
    24
    Internet
    Business Ed. Plus
    Us living in the northern hemisphere always have atleast one room temp fall back 12V battery to swap in when winter. Then take the OG battery indoors and charge with a 5A charger after 24 hours (never charge semi/frozen batteries).
    The capacity to deliver Amperes drops dramatically by every degree below zero Celsius. Also; unless the battery has a good charge - the electrolyte pH is to high and it will freeze more easily.
  13. ColoradoBoo
    ColoradoBoo Senior Member
    1,266
    874
    Monument, Colorado USA
    Yep, we're seeing -15 here in Colorado with the windchill.....BRRRR
    Make one almost think Al Gore was 100% full of crap, huh??? (Tip: He's never been a scientist and, yes, he was.)
  14. pasadena_commut
    2,787
    832
    Southern California
    Well, he was a politician, so >= 90% is pretty much guaranteed. However, in this case you are implicitly assuming either that if the global average temperature rises then the local temperature must always rise, or that if the average temperature rises that local extreme temperature swings to the low end cannot occur, and both of those assumptions are false. The global average temperature, as predicted, has been going up steadily since well before Al Gore started talking about it (long after other people had been)
    Temperature record of the last 2,000 years - Wikipedia
  15. ChapmanF
    18,484
    Not to mention that when a prodigious mass of really cold air shows up someplace way farther south than you'd expect it, that doesn't mean anything happened to lower the global average temperature. It means a prodigious mass of really cold air traveled thousands of miles to get there.
    That traveling took prodigious amounts of kinetic energy.
    Which there is more of, because global average temperature is higher. Temperature pretty much is an energy measurement.
    So if you find yourself asking "does it seem there's more energy around these days to push around these prodigious masses of sharply different-temperature air?", you're asking a question that has an answer.
    Details are complicated enough to keep climate scientists busy, but basics aren't that hard.
  16. bisco
    52,334
    Well, this thread took an unexpected turn, like the weather I guess
  17. bwilson4web
    16,347
    When do you plan to leave Florida? Space X has two launches planned Feb 1-2.
  18. highmilesgarage
    489
    180
    Kansas City
    same thing happened to my Lexus RX400h but it was able to start at 3 attempts.. no READY light at all. Unfortunately I sold my Escape Hybrid so I wasn't able to test how it performs on cold/snow conditions. Ford quality and design has gone downhill over the years and the escape hybrid was riddled with electric/mechanical issues even though it has Toyota licenses for the hybrid system (even has aisin parts) It's also a rust bucket.. Their accountants can't design cars!
