Transaxle/Transmission Fluid Change - Dark Brown and Overfilled(?)
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Purrius, Dec 2, 2024.
  1. Mendel Leisk
    41,693
    I’ve seen a Toyota document (have a copy here, somewhere…) that says to only use their ATF WS fluid from freshly opened bottles.
  2. johnHRP
    johnHRP Active Member
    645
    188
    KA, DE
    Excel
    Thanks Mendel, as always very valuable info in our forum. I also heard that ATF-WS is hygrocospic but does not say how long in the sealed bottle we can keep.
  3. ASRDogman
    ASRDogman Senior Member
    7,665
    3,940
    ???????????????? :confused::confused::eek::eek::eek:o_Oo_Oo_O(n)(n)
    It's obvious you don't know what lifetime means.
    It means until the warranty expires. They changed it because of epa crap.
    But you change it at 60,000 miles? If it's lifetime, and YOU say it doesn't change,
    even though it gets cooked in a hot transmission, WHY would you change it?
    Suddenly, at 5 years the oil is no good?
  4. johnHRP
    645
    188
    KA, DE
    Excel
    My first Pirus 2006 have a transmission fluid change recommended by my dealership every 100k miles or 6y. My car runs fine until I sold it at 220k miles. The Prius 2 transmission has a weak point on the needle bearings and still use some chain mechanism inside. The Prius 3 is much more reliable. The ATF-WS in hybrid works much less compared to 6 or 8 speed torque converter type transmission. It does not have to flow and spin really fast as a fluid coupling between engine to the wheel. Hybrid only have a spring damper to the flywheel, no clutch materials either. I am a car enthusiast and change the ATF just because I want. That's why Toyota does not say anything about Transmission fluid change in the owner manual or service schedule, like Mendel said. I think changing the fluid in the transaxle is more important in hybrid than ATF. Just like clean and lubricate the brakes more important than just stupid European 2 yearly brake fluid change.
  5. ASRDogman
    7,665
    3,940
    It's a clutch with clutch material.... Did you think it was metal on metal?
  6. johnHRP
    645
    188
    KA, DE
    Excel
    Calm down man. Prof. Kelly shows clearly that gen 3 does not have clutch (friction materials). All just gear rubbing gear on bearings. Only the damper (spring disc) connect directly to the ICE and it has no clutch either. Clutch by definition is friction materials to grab other parts to move together with it. But you may be right defining the damper disc as metal on metal clutch. But this damper is not exposed to ATF. it is dry.
  7. ASRDogman
    7,665
    3,940
    I'm very calm boy. I was typing about the damper, catch up.
    johnHRP likes this.
  8. Mendel Leisk
    41,693
    Are you responding to someone? Maybe quote them.
    johnHRP likes this.
  9. Purrius
    Purrius Member
    164
    47
    Northeastern US
    Putting this here too, since I suspect Mendel is on to something— the shop may have filled it via the incorrect egress on the top.:confused:
  10. indel
    indel Member
    222
    78
    Northwest Indiana
    If the bottle is sealed, I would use it even after a long time. At least 5 years, may be more. Opened, half full bottle is another story. I won't use that past six months, if even that.
  11. indel
    indel Member
    222
    78
    Northwest Indiana
    What do you mean exactly?
  12. Mendel Leisk
    41,693
    I stumbled on a Toyota document that stressed to only use ATF-WS from freshly opened bottles. Got it here, somewhere. I’ve got a half-full bottle here, seriously should recycle.
