Does anyone else have a urinal smell coming from their A/C ? I recently took over my parents 2008 Prius. I remember around 11 years ago the day they bought it used. It had a sweet, putrid 'urinal' scent pack smell to it. I thought the used car guys had placed a scent pack in the car, but I can't find it. 11 years later, and the smell is just as strong as day 1, despite trying all sorts of odor absorbers. I thought maybe a cat had got into the car, but the smell would have gone away after 11 years. I can't trace the origin of the smell, but I notice that it seems possibly stronger with the A/C on, but this may be the wind blowing the smell into my face from elsewhere. My next thought was the cabin air filter, but no. The smell would have gone away in that too after 11 years. Any ideas ?
I had a stinky car lately. Changed cabin air filter and sprayed some stuff from the parts store made for it while the filter was out and fan running. Worked.
Thanks ! I figured this might be the issue, but would the smell be just as potent after 11 years ? This is my first full day with the car, so I'll have a look at the filter maybe this evening. Edit : I'll look in the manual and online to find the filter location, but is there more than one, and if so which one did you change ? Do you just clean the things, or do you have to buy a replacement? - Thanks
This was a different car. The filter is usually in the glove box but mine wasn't. Only one. Clean the filter? Change it!!!!! Spray the heck out of the box too while the system is running-see directions on can. Mine had something to do with A/C and moisture in the airbox/filter causing mold/mildew, I suppose.
Toyota have a cleaner to clean the evaporator box also. I think CarCareNut have a video for this. Replace the filter and the passages, if possible, take out the fan and clean it and then clean the evaporator with that Toyota spray. .
It can always be mold and or mildew growing in the air conditioning part of the box it never drains fully they're always done droplets sitting around that the smell wen ya first start the AC is that water standing getting ready to become maybe mold or similar . Flushing that box and drain tube out regularly is a good thing if it's run alot .
The car has been sitting in direct Texas sun all day. The smell was overpowering as I opened the door just now. A sickly sweet urinal smell. So apparently heat makes it worse. Almost unbearable. I should add that the A/C was not turned on just now either. Cabin air filter in glove box checked. Nearly brand new - no dirt, but also no smell at all.
I would think mold would have a 'moldy' smell and not a sickly sweet odor. I'll check the battery vent tubes next - would the battery smell 'sickly sweet' ?
If it's related to the A/C it might be that the drain was blocked and the carpet got all wet and moldy, although that doesn't sound like the smell you're experiencing. Sickly sweet sounds like coolant.
I checked the area near the battery. No smell coming from there. It seems more pronounced near the A/C vents, so I will clean it using the stuff mentioned on another post here on this forum.
I don't think so. We had a bad refrigerant leak into the evaporator, enough to lose all of it in tens of days. It didn't smell bad while it was leaking. Pretty sure the smell is from various bacteria and molds growing in the evaporator. One way to reduce this is to shut off the A/C (even if the car turned it on automatically) several minutes before parking, while running the fan at a pretty substantial setting to try to dry out the evaporator. This is easy to do in the summer but in winter it is harder because it frequently results in the windows immediately steaming up. Also pull up the carpet at the front on the passenger side (under the glove box) to reveal the drain hose. If it is wet under there there is probably a blockage in that hose. There is a junction at that location and if blocked lower down it leaks out there. Easy to clear the blockage - open the junction and run a wire or some weed whacker filament through until it comes out the bottom of the car. Wiggle it around some to loosen the crud in the tube, then force water through to wash it out. If I'm remembering the right car the tube comes out above a lateral piece of metal, so it isn't easy to see the end of the hose. Once you see where water comes out reach up (blindly) and it can be felt.
After reading other posts here on the forum, I see others have used "Kool It " brand A/C cleaner. I watched their video, and they recommend Injecting the stuff into the A/C drain line. I will look to see where that is. I have also seen that some people have sprayed it into where the cabin air filter is ( glove box ) but I see some have cautioned about possible damage to anything electrical nearby. Is there anything specific I should know about using this stuff on a G2 Prius ?
I cleaned the A/C with 'Kool It'. It seemed to work for about a week. Maybe I need to do several cans.
If the A/C has been running (even indirectly, like in the defrost mode) it is a good idea to turn it off a couple of minutes before the car will be turned off, and the fan turned up to at least the middle range. That blows some of the moisture out of the evaporator, so it isn't sitting there to provide a nice place for little organisms to grow. Also check that the drain hose which runs down under the passenger footwell is not at all blocked.
