2012 Prius No READY Mode After Dead 12V Battery – Lost Key, No SMR Click
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Eugene_prius, Jan 24, 2026.
  1. Eugene_prius
    Eugene_prius New Member
    Charlotte
    Hey everyone,
    I'm dealing with a frustrating issue on my 2012 Toyota Prius (Gen 3) and could use some advice from the Prius experts here. The car was parked for a while, and the 12V battery completely died (down to 3-4V – wouldn't even unlock the doors or start). I replaced it with a new 12V battery, but now the car won't go into READY mode. The dashboard is a Christmas tree of warning lights, the SMR relays in the back aren't clicking/closing (so no high-voltage engagement), and there's a clear loss of communication between modules. Also, my second smart key seems to have been lost/erased from the system – only the master key works to unlock doors, and I can't reprogram a new one because communication drops during the process.
    Here's what I've tried and checked so far:
    • Jump-started before battery replacement – no luck.
    • Replaced key fob batteries (they were good at 3V, but swapped to new ones anyway) – still only one key recognized.
    • Checked all fuses, fusible links, and the hybrid battery – everything tests good.
    • Scanned codes after new battery:
      • U0155: Lost Communication with Instrument Panel Cluster (IPC) Control Module
      • U0293: Lost Communication with Hybrid Powertrain Control Module
      • U0073: Control Module Communication Bus 'A' Off
      • U0126: Lost Communication with Steering Angle Sensor
    • There was a prior issue with fuel gauge calibration, but that might be unrelated.
    • Towed to first dealer: They replaced the brake switch (didn't help), then quoted $3,500 for a new inverter (I declined, as it didn't seem right).
    • Second shop diagnosed for 2 weeks: Couldn't pinpoint the issue, replaced the ABS brake cylinder/actuator (no change). They tried to add the second key but lost communication. Also swapped Smart Key Control Module, Power Management Control Module, and Transmission Control Module – still no READY mode.
    • Now at a third shop: They're stumped too – can't figure out which module is blocking key programming or preventing READY. Communication keeps failing.
    I suspect this stems from the deep voltage drop corrupting something in the ECUs, Smart Key/Smart Box, or immobilizer system. The car powers up to IG mode (dash lights, accessories), but no hybrid activation.
    Questions:
    1. Any ideas on how to force it into READY mode or bypass the SMR relays for testing? (Safely, of course – I'm not trying to fry anything.)
    2. Has anyone seen this exact combo of comm errors after a dead 12V battery? Could it be a fried ECU or immobilizer that needs reflashing?
    3. Looking for a skilled Toyota hybrid specialist in the Charlotte, NC / Spartanburg, SC area who knows Techstream inside out, can diagnose ECU/Smart Key/immobilizer issues, and handle reprogramming. Dealer-level experience preferred, as shops so far haven't cracked it.
    Thanks in advance for any help or leads – this car's been down for weeks, and I need to get it back on the road!
    52,395
    Any chance of vermin chewing on wiring?
  3. Eugene_prius
    Charlotte
    I checked for any signs of vermin damage and everything looks good. All wiring appears intact—no chewing, no green corrosion, nothing unusual. The wires look brand new and fresh.
    I also inspected under the dashboard near the ventilation area, and everything there looks clean and untouched.
    All the problems started after the 12V battery was drained when the dome/door light was left on. I’m especially concerned about how one of the two keys was erased from the system, but that also happened after the battery issue.
    I do have some technical questions I’m hoping you can help clarify:
    • Which module/system is responsible for monitoring the 12V battery condition and determining whether the voltage is acceptable for operation?
    • The battery measures about 12.3–12.5 V, yet the system still seems to think the 12V battery is not OK. Which module “decides” that the voltage is sufficient and communicates that to the rest of the system?
    • At what point, when I press the brake pedal, should the ABS or brake system send or receive the correct voltage to activate the next module and allow the SMR system to turn on?
    • Which specific module is responsible for that handoff or authorization?
    • How does the 12V power travel from the battery through the system—especially in relation to the brake system and SMR activation?
    If possible, I’d really appreciate:
    • Wiring diagrams
    • A module interaction diagram (showing which module talks to which)
    • Any documentation explaining how the 12V system is evaluated and distributed
    Lastly, I’m looking for a mechanic or auto electrician in the Charlotte area with Prius experience who can help diagnose and fix this and get the car drivable again. Any recommendations would be greatly appreciated.
    Thanks in advance for your help.
  4. Eugene_prius
    Charlotte
    I’m starting to understand the root cause of my issue:
    Deep 12V battery discharge (3–4V) → corrupted EEPROM data → lost smart key registration → security handshake failure → no READY mode + CAN communication codes (U0073 / U0293).
    After the severe 12V voltage drop, it appears that EEPROM data in one or more original modules became corrupted, which erased key registration and now prevents system initialization.
    Current situation
    • Prius will not enter READY mode
    • Multiple CAN communication errors (U0073, U0293)
    • Only one remaining smart key, but security system is not fully functional
    Plan / What I believe is needed
    • Restore Toyota security handshake between:
      • Immobilizer (ID Box)
      • Smart Key ECU (Smart Box)
      • ECM
    • I have ordered a Smart Key ECU (Smart Box) P/N 89990-47061
    • Remaining master key must be properly re-registered to the Smart Key ECU
    • Immobilizer seed transfer (EEPROM level, not just Techstream menu)
    • Verify ECM VIN and calibration flash are correct and not mismatched
    • Possible HV system initialization/SMR relearn/Hybrid battery initialization / safety check
    What I’m looking for
    Someone who:
    • Works with Toyota hybrids / Prius Gen 3
    • Understands EEPROM / immobilizer / Smart Key systems
    • Can use Techstream + advanced tools (EEPROM work)
    • Can diagnose which module is blocking READY mode and fix it properly
    Location preferred: Charlotte, NC / Spartanburg, SC
  5. Peter123
    Peter123 Active Member
    132
    128
    You may want to reset everything. Have you tried disconnecting both the 12 volt and the traction battery? The traction battery is connected through the orange high voltage connector in the trunk. You have to pull out all the trunk covers over the spare tire to see it. You have to pull it sideways and then rotate the handle and pull it off it to disconnect it. wait 5 minutes and reconnect it by reversing the disconnect actions. Then reconnect the 12 volt battery. This has worked for me in the past when the dash got lit up like you describe.
  6. bisco
    52,395
  7. Brian1954
    Brian1954 Senior Member
    2,410
    967
    South Central PA, USA
    The traction battery is completely isolated from the rest of the car with relays when the car is not in Ready. So, what would taking out the orange safety disconnect do that turning the car off would not do?
    PrimeDan likes this.
  8. Tombukt2
    13,444
    2,418
    Man you're getting way out on the fringes here before you change electrical computers . You should have a electronic capable smith pull the immo data from you're power button . Can be done wirelessly or through the OBD2 port that will give the smith the immo info that box sends out to look for the fob I think you're gen 3 is id4 system immo. Then he can read you're two fob immo info . See if it matches! The smith w proper tool can re burn the immo data needed to restore the Imobilizer system . What happens when you mess with the car and you leave the charger attached to the battery an AGM likes 12.4 to . 7 V standing. falter is a little with age but nothing crazy until it's dead and fails .
  9. Tombukt2
    13,444
    2,418
    I would think Chapman f maybe able to help w handshake info on gen 3. If you can get gen3 manual set PDF it goes into details of exactly how this works it's kinda confusing all the numbers have to be correct to ready. If immo data is corrupt scanning immo system should show it pretty quick.
  10. Eugene_prius
    Charlotte
    At this point, I’m ready to move the Prius anywhere if needed.
    Do you have contact information for a repair shop or diagnostic specialist who really can help with handshake and ECU and diagnostic work?
    I’m willing to transfer the car to someone who knows how to fix this correctly.
  11. Eugene_prius
    Charlotte
    #11 Eugene_prius, Feb 14, 2026
  12. Tombukt2
    13,444
    2,418
    You need one these new Facebook locksmiths who has unlocked tools in USA before the debacle .alot of Real locksmiths the serious guys have told me they won't venture off into this .too much Inventory to carry etc . Most newer cars have learn mode built in and key fobs are 22 bux etc . They'll get you into car pop a lock etc hopefully you fob is in car etc. you need ID4 info from immo box behind dash very difficult to remove easier to Read... From the start button w an antenna and tool . Someone's believing days is corrupted . It has to be Read to know if it's corrupt have to see ID4 string . From the fobs too . And lock shop can read fod ID at counter with you're fob in hand . For the car they have to come out to with tool to scan start button antenna. Data must match . They're are many videos . With corrupt data believed you're dealing with all keys lost basically . Even though you have the keys . Data corrupt basically same as AKL.. good luck . Look for AKL video of how it's done.
  13. Mendel Leisk
    41,911
    While I’m able to save memory say when replacing 12 volt battery, I’ll purposely disconnect (the neg cable) when DIY’ing brake work. Never messed anything up. No clue, but maybe there’s more to it in your case. All I got, I’m an electrical duffer.
