Coast G2 in 'N' without damage ?
Discussion in 'Gen 2 Prius Main Forum' started by cDxA, Jan 25, 2026.
  1. cDxA
    cDxA Junior Member
    40
    Can you coast a G2 Prius in 'N' while at high speed ? ( 60 + mph )
    A.I. says it won't do any damage, but A.I. is wrong half the time.
    A.I. also says it's pointless though, since the ICE is not allowed to 'freewheel'.
    Also, I'm told that it would work no better than simply taking your foot off of the gas pedal at speed.
    It just seems so 'planned' that the shift knob is perfectly situated where you can easily shift with two fingers without taking your hand off of the steering wheel.
  2. ChapmanF
    18,829
    You can if you want, and it won't hurt a gen 2.
    The thing that confused the AI was that one of the motor-generators, MG1, can overrev at higher road speeds unless the engine is also running. So if your car happens to roll from below that speed to above that speed while you're in neutral, it has to spin up the engine—which requires not being in neutral. But that isn't a problem in gen 2, which will just decide you aren't in neutral for long enough to spin up the engine, and then go back to being in neutral.
    Taking your foot off the go pedal isn't the same, because the car applies a slowing force when your foot is all the way off.
    But if you just back your foot part-way off, to the point where you're not applying forward power or slowing force, people call that point 'glide' and that's what s lot of people do instead of fussing with neutral.
    cDxA and PriusCamper like this.
  3. cDxA
    cDxA Junior Member
    40
    Thanks ! So aeromods just might help a G2 Prius after all !
    From what I understand, there is a two second delay when you shift back into drive.
    Also, there is the safety risk of needing to accelerate suddenly while in N.
    But it's not the same as engine off coasting in other cars where you lose power steering etc and it can lock up on you.
    Is it even possible to engine off coast in a G2 Prius ?
  4. cDxA
    cDxA Junior Member
    40
    I'm confused about that 'glide' point on the accelerator.
    So not entirely off the pedal, but somewhere in the middle ?
    Something like what people call "feather footing " it ?
    ( Driving like there is an egg under the pedal. )
    I already do that out of habit, but it seems the ICE still remains on.
  5. VelvetFoot
    VelvetFoot Senior Member
    1,377
    529
    New York State
    2026 Prius
    Gen5'er here. I think my car coasts really well-better than my last car a '22 MINI with DSG gearbox.
    And it too is very easy to shift into neutral, like your car.
    Even if you could ride the Eco/Normal line, (I can't), you're still looking at the gauge instead of the road.
    And a big plus, is when you start to accelerate at the Stop sign, you don't over-rev because you didn't shift into Drive. :)
  6. ChapmanF
    18,829
    The engine will be on sometimes, and not on sometimes. There are various reasons that feed into whether the engine is on. Above a certain road speed, the engine must remain on.
    You find the 'glide' point on the pedal just by noticing where you've backed off enough that you're not pushing the car forward, but not so far that you're holding the car back.
    You can search for the phrase "pulse and glide" on this forum and read a lot about it.
  7. highmilesgarage
    highmilesgarage Active Member
    494
    182
    Kansas City
    but why? N doesn't mean the engine turns off all the time (computer decides when) and there's no benefit, it doesn't even charge the battery.
  8. VelvetFoot
    1,377
    529
    New York State
    2026 Prius
    All well and good if you're gonna have to apply the brakes.
    But if you can run it out, safely, it all goes to changing momentum-no transformation losses to charge the battery. That's the way I look at it.
  9. pasadena_commut
    pasadena_commut Senior Member
    2,960
    909
    Southern California
    While driving down a long slope on a highway I have observed the energy monitor sometimes go to all black arrows in "D" and light pressure on the accelerator. That's coasting above 60 mph for all intents and purposes, and the "N" hardly matters. It is possible though that the car was not showing accurate data, as when stopped that same display sometimes shows the ICE stopped when it can be heard running and vice versa. For a short while anyway.
    cDxA likes this.
  10. cDxA
    cDxA Junior Member
    40
    And what is the maximum speed you can safely shift from D to N and back to D again ?
    I tested it out at crawling speeds around the parking lot today.
    Shifting from D to N and back again was extremely easy.
    One finger !
    I swear it seems designed with that in mind, even if the idea was not encouraged by the factory.
    And ( at crawling speeds at least ) there was no delay going from N to D and immediately accelerating.
    With a long flat road, improved aerodynamics and traffic far behind, I can see how this could really be a really useful tool !
  11. Brian1954
    Brian1954 Senior Member
    2,534
    1,007
    South Central PA, USA
    Just put the car into drive , and drive the car just like any other car. There is no reason to overthink it. Shifting into neutral is a safety concern.
  12. cDxA
    cDxA Junior Member
    40
    Why is that ?
    I can understand if you are on a mountain road, but what about gently sloping hills, and with traffic far behind you ?
    Do you lose your brakes ? Does the steering wheel lock ?
    Is there a delay in the time it takes to shift back into D at high speed ?
    ( I had read of a supossed 2 second delay for the car to go back into D from N. Is this true ? )
    The only thing I can think of is if you suddenly need to accelerate.
    And that is if there is that delay I asked about.
  13. Brian1954
    2,534
    1,007
    Because shifting back and forth between drive and neutral is a distraction for you while you are driving. There is no reason to physically shift the car into neutral when the car is being driven. You can use the accelerator pedal to find the "glide" point, which is neutral, while the car is still in drive. This was previously written about in post #5,
    #13 Brian1954, Feb 2, 2026
  14. highmilesgarage
    494
    182
    Kansas City
    there are people that has issues with the shifter joystick (it seems to be fragile) Worst if the shift actuator gets worn out and you have to replace it. You're simply just wearing those components out by unnecessary shifting.
  15. ChapmanF
    18,829
    I believe the shift selector design overall is pretty bulletproof, though I think there were some threads here where a thin plastic dust shield inside it got warped or misshapen and interfered with the motion, not too hard to fix.
    As the sensing is all done by non-contact, non-moving Hall-effect sensors, I have trouble imagining any serious trouble developing, sooner than various other Earth-threatening issues might materialize.
  16. Leadfoot J. McCoalroller
    8,210
    7,713
    Pennsylvania
    2018 Prius c
    I think it's been covered well in accurate technical detail above, but I'll put it in more blunt terms:
    The Prius is already delivering the savings you are attempting to milk out of it with coasting in neutral. I'm not going to say it's impossible, but it will be very, very difficult for you to improve on what it is already doing with robotic precision. You paid for that level of automation, enjoy it.
    Just leave it in drive and modulate the pedal carefully.
    Brian1954 likes this.
