Maintaining Battery during dormancy
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by gatorback, Jan 24, 2026 at 10:14 PM.
  1. gatorback
    gatorback Junior Member
    It is my understanding, when the Prius Gen3 is garaged, it is not off in the truest sense: it is still burning battery energy and will eventually exhaust one or more batteries. This give rise to several questions:
    1) What is the longest period of dormancy possible? Months, weeks?
    2) During dormancy is only the 12V (small battery) exhausted or is the large HV (hybrid battery) drained as well?
    3) If a 12V trickle charger is engaged during dormancy, is this is enough in two maintain both batteries (hybrid HV battery and 12V)?
    4) If parked at the airport for an extended period of time, is it enough to disconnect the 12V battery or is there a need / advantage to disconnecting the HV hybrid battery?
    I have a Nocu Trickle charger that is switched on / off with a wifi smart switch for 1-month dormancy periods.
    #1 gatorback, Jan 24, 2026 at 10:14 PM
    52,117
    When off, the hybrid battery is isolated from the rest of the car.
    They typically don’t lose much energy, but the older they are, the more prone to it.
    there is a constant drain on the 12v, again, the older it is, the more likely to drain and sulphate.
    In good health, it should last more than a few weeks, but becomes more risky as it ages.
    A maintainer is always best, but disconnecting also works. But you may lose a few settings like radio stations or window memory, it’s inconsistent
    CR94 likes this.
  3. VelvetFoot
    VelvetFoot Active Member
    925
    335
    New York State
    2026 Prius
    I don't think there's a need to cycle that maintainer manually.
    bisco and Brian1954 like this.
  4. bisco
    52,117
    correct, it does all the switching itself. when not charging, it is monitoring charge level. you don't want to switch it off
