Prius 2010 Energy flow Arrows not showing
Discussion in 'Gen 3 Prius Main Forum' started by Lib, Jan 25, 2026.
  1. Lib
    Lib Junior Member
    34
    Zambia
    After realizing this we opened up the HV battery cleaned the boss bars and the nuts boxed it up. But still the energy flow arrows were not showing after driving it for 30 km intense driving and error code or there is a cable which is not connected at the 12th volts battery. It's a blue and paper cable.
  2. Lib
    Lib Junior Member
    34
    Zambia
  3. PriusCamper
    PriusCamper Senior Member
    13,102
    5,310
    Pacific Northwest, USA
    I'm not sure what you're saying here? Did you have a warning light with an error code or not? And if you did what is the error code?
    Also disconnecting the 12v battery for a minute will do a factory reset on your car and its the easiest way to fix a glitch like this.
  4. indel
    indel Member
    279
    88
    Northwest Indiana
    His 12V battery harness is broken partially, which is probably what's causing missing data (I don't even know how) that is normally fed to the energy monitor.
  5. Lib
    Lib Junior Member
    34
    Zambia
    l did the reset by disconnecting 12 v batterry but the arrows still not showing.after speeding with aircon on it gave an error code P0A80.
    PriusCamper likes this.
  6. Lib
    Lib Junior Member
    34
    Zambia
    i
    s that what the blue and purple cable is for?it seems to be coming from the lights as it moves to gether with those cables.where should it be connected
  7. PriusCamper
    13,102
    5,310
    When you get a P0A80 code the computers shut down the hybrid systems so I'm pretty sure the screen would show no arrows when that happens. Apologies for not being more clear, I thought you had no arrows and no error codes at the same time.
  8. Lib
    Lib Junior Member
    34
    Zambia
    after resetting there were no arrows and no error codes,error code came after driving for some days
  9. PriusCamper
    13,102
    5,310
    So car drives normally with no arrows? Or does car lack power and driving slow because its running on gas engine only?
  10. indel
    indel Member
    279
    88
    Northwest Indiana
    I thought the Prius could not run on gas engine only (unlike Honda insight) or is that a myth?
    #10 indel, Jan 27, 2026
  11. PriusCamper
    13,102
    5,310
    It can't run normally on engine only, so they call it limp mode and hyrbid system isn't entirely shut down, but put in safe mode.
  12. Lib
    Lib Junior Member
    34
    Zambia
    Yes it drives normally with no arrows but it doesn't charge to the point of have green leaves icons.only after the code appears does it runs on engine continuously.The code appears when car much energy is demanded like speeding 0 to 80miles in seconds and turning on aircon while driving
  13. Lib
    Lib Junior Member
    34
    Zambia
    . perhaps this report can help
  14. PriusCamper
    13,102
    5,310
    That's not a report specific to error codes for hybrid cars so you need a better code reader / service.
    Put clearly P0A80 is the primary code for when the computers shut down the hybrid system and trigger limp mode. So you do have an error code that explains why there's no arrows and now you need to find out what the sub-codes are so we can get more details about what's wrong with your hybrid battery pack.
  15. Brian1954
    Brian1954 Senior Member
    2,422
    972
    South Central PA, USA
    The P0A80 code only has one sub-code, which is 123. So, the sub-code is not any help.
    The freeze frame data for the P0A80 code will show you the voltages of the 14 battery blocks when the code occurred. It would also show what the current flow was when the code occurred. That information would be very helpful.
    An example of the freeze frame data for the P0A80 code using the Autel AP200 scanner is attached to this post,https://priuschat.com/index.php?posts/3592806
    #15 Brian1954, Jan 29, 2026
  16. PriusCamper
    13,102
    5,310
    Yea... Subcodes is probably not as accurate as saying "other codes." For example if its a P3000 in addition to P0A80, or many other codes related to P0A80, the OBD2 device OP is using to diagnose clearly doesn't have those hybrid specific codes in its library.
  17. Brian1954
    2,422
    972
    Why do you think there is a second code? The P0A80 code can occur without having any other code.
