PHEV/Prime Low Temperature concerns
Discussion in 'Gen 5 Prius Main Forum' started by RX808, Apr 14, 2025.
  1. KMO
    KMO Senior Member
    2,011
    734
    Finland
    2023 Prius Prime
    Have you got the cold region setting enabled? It should be keeping the battery from getting too low to operate while plugged in. If you've got a charging schedule set, and the cold region setting is on, it should show a message about the schedule being overridden at those temperatures. Not sure if it flags it up otherwise.
    This is a setting that has to be set via a scantool - dealer can do it and probably are supposed to have done.
  2. VelvetFoot
    VelvetFoot Active Member
    1,216
    476
    New York State
    2026 Prius
    The manual for my HEV says the same thing:
  3. Trollbait
    12,681
    It's a drawback of Li-ion. Operating at those temps could damage the battery even if it could provide energy. Then the gen5 PHV has the battery outside the cabin space where it can lose heat faster.
    The cold climate setting will run the battery heater for longer while parked than the default. But it isn't high power; temps that low might be too much for it.
    BiomedO1 likes this.
  4. KMO
    KMO Senior Member
    2,011
    734
    Finland
    2023 Prius Prime
    Right, and that's the point of the PHEV Greenland/Canada cold weather setting - to give you a way to stop the battery going below -30°C by plugging the car in. Especially needed with the battery exposed on the outside.
    The normal "battery heater" selectable via the options screen operates from something like -10°C to 0°C, trying to keep the battery above freezing so it operates efficiently, with the aim being to avoid needing to start the engine. At temperatures below somewhere between -10°C and -15°C it gives up, presumably knowing the engine's just going to have to start. That operates for up to 3 days.
    The cold weather setting starts heating operation somewhere below -20°C to make sure the battery doesn't get cold enough to not work, and that operates for up to a month.
    I managed to profile the battery heater's behaviour in this thread. It hasn't got cold enough here to analyse the Greenland/Canada setting in detail.
    But it's clear here in Finland why it's a setting - the chances of the weather hitting and staying around -25°C here for a period are relatively high, but the chances of getting as low as -30°C are minimal. So having it on and consuming electricity at -25°C to tend the battery would be pointless - there's been no sign of the car being reluctant to start.
    I assume the limited power is part of why it's an option - to stop the battery getting below -30°C it wants to start while there's still plenty of margin. It's not being tasked with literally heating the battery - it's being tasked with sustaining its temperature.
    It just has to keep up with whatever heat loss there is with a 10-to-15 degree difference. If it can get the battery to 0°C when it's -10°C outside, it should be able to hold it at -28°C when it's -38°C outside.
  5. BiomedO1
    4,136
    2,170
    SacTown, Ca
    My understanding of these PHEV's is, if you set a departure time and your plugged-in - the ECU will pre-warm the traction pack, if it's wasn't charging; in preparation to start the car at the appointed time. That's assuming that all cold weather defaults are toggled ON. I believe that the ECU will also keep battery warming pads ON below certain temperatures, if plugged-in. Not sure if you need to turn that factory default ON or if it's factory defaulted OFF to save energy. My area doesn't get that cold, but I did see those toggles while poking around the system.
  6. KMO
    KMO Senior Member
    2,011
    734
    Finland
    2023 Prius Prime
    I'm repeating myself here, but that is the "try to keep the battery above freezing for optimal performance" function described above that gives up below around -10°C.
    That won't be doing anything at all if the temperature approaches -30°C.
    The solution to that is the Alaska/Canada dealer cold weather survival setting, which operates with no user controls, independently of any charge schedule.
  7. P X
    P X New Member
    Ontario
    2026 Prius Plug-in
    I have a 26 PHEV Prius in Ontario, and it’s not liking the cold at all. Started to have issues where blower will not come on to defrost windshield (both ev and hv mode)- requires restart of car to get it working, and remote starter not working via app or FOB most likely due to 12V (and when it’s below -10C) car will light up dash for a quick moment and shuts back down. Dealer has no answer to the issue other than to park the car indoors.
  8. BiomedO1
    4,136
    2,170
    SacTown, Ca
    You know you have two windshield defoggers in your car. One is a heated grid line, similar to your rear window defogger - NO fans on that one. The defogger button in your HVAC cluster, should fire the engine and fans.
    Hope this helps...
    If you have 12VDC battery issues, the dealership should be taking care of that under your 3-year, 36K mile warranty..... If they don't, take the car to any auto parts store and get that battery checked. Get a printout and give the dealership one final chance to make it right before calling Toyota corporate.
  9. P X
    P X New Member
    Ontario
    2026 Prius Plug-in
    Thanks but it’s not related to the defrosting lines but rather the HVAC unit, when it’s too cold, blower does not function until a full restart whether on HV or EV mode
    yes dealer is looking at it but no answers from Toyota Canada.
