2008 Toyota Prius – Intermittent limp mode, loud engine with poor acceleration, no fault codes
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Zanga, Jan 24, 2026.
  1. Zanga
    Zanga New Member
    Leicester
    Hi everyone, hoping someone here can point me in the right direction because I’m a bit stuck.
    I have a 2008 Toyota Prius with about 90,200 miles on it. There are no warning lights on the dash and no fault codes showing on diagnostics.
    The issue started suddenly after refuelling. Since then, the problem comes and goes. Some days the car drives completely normally, and other times it struggles.
    When it happens, the engine gets very loud but the car doesn’t accelerate properly. It does move, but it feels like driving uphill or like being in the wrong gear in a manual car (even though this is an automatic) — the engine sounds like it’s working hard but the power doesn’t really translate to the wheels. Even when just maintaining speed, the engine stays louder than normal. Sometimes it goes into limp mode, but it doesn’t stay that way and can clear on its own after a while or after switching the car off.
    RAC (UK breakdown assistance) suggested it could be a sticking throttle body and mentioned these faults can be intermittent.
    The first mechanic I took it to initially thought it might be a wiring or communication issue. He cleared the only fault code that had ever shown (this was when pressing the accelerator while parked, the engine wouldn’t rev). That particular issue hasn’t come back, but the main driving problem didn’t go away. He later changed his view and said it could be the catalytic converter.
    While the fault was present, he also looked at live data and noticed odd throttle behaviour — delayed response, the throttle opening slowly and then dropping back down even though my foot was still fully on the accelerator, and the throttle position sometimes showing 0%.
    I then took it to a second mechanic, who found no fault codes. He checked a few things and mentioned the purge valve as a possible cause, but said he wasn’t sure — someone he knew had a very similar problem on a Vauxhall, and in that case it turned out to be the purge valve. The 12V battery was showing about 64%, which he said may be a contributing factor (he mentioned being expensive to replace) so he mentioned not wanting to get me to change the battery and that not being the problem.
    Since I’ve owned the car, I’ve also had some intermittent electrical quirks, like the screen flickering and the radio or heater turning off randomly, though this has been happening on and off for a long time.
    At this point I’m honestly a bit confused about what to do next. Could this be a hybrid battery issue, wiring/grounding, throttle body/sensor problem, or even a catalytic converter? I’d appreciate any guidance on what might make sense.
    Thanks in advance for any advice — I’d really appreciate it.
    #1 Zanga, Jan 24, 2026
  2. dolj
    dolj Senior Member
    8,528
    4,327
    Wellington, New Zealand
    These symptoms are consistent with what happens when the hybrid vehicle battery get low on capacity. If you can find someone to do a round of reconditioning charge/discharge cycles it may restore enough capacity to get you by for a few more years.
    You can get the Dr. Prius app and a compatible OBDII dongle to run its battery test which will give you a rough idea of your battery's health.
    Unfortunately, not living in the UK, I can't recommend anyone to you. Hopefully, some of our UK members can help you with that. Don't be talked into exchanging your battery for a reconditioned one, though.
    If you do find your battery is end of life, then a new battery from Toyota is the option you will be looking at. Everything else you might see is a bandaid to buy you time to save up for a new battery. Think of this job in the same way you would for a transmission overhaul in a Vauxhall.
  3. Rennie
    Rennie Junior Member
    Australia
    When the engine is "loud" and with no power, is it revving up very high or just getting loud and feeling like it's lugging?
    Low hybrid battery health issues are usually rev up high like you're stuck in first gear but have little power.
    Clogged cat or some other issues could be like you're in a high gear with pedal to the floor - it's making noise and vibration but not revving to the max
  4. Zanga
    Zanga New Member
    Leicester
    These were the findings from Dr. Prius
  5. Zanga
    Zanga New Member
    Leicester
    Good question it just sounds loud and feels like it’s lugging when I first start driving, then when I am on the motorway or require to go at a higher speed the noise gets louder like a loud fan almost. It hasn’t gone into limp mode so I have not been experiencing the car struggle to pick up speed.
  6. dolj
    dolj Senior Member
    8,528
    4,327
    Your battery screenshot is showing only 1.77 A discharge, which is not enough to expose any blocks that might be suspect. The battery test, which gets you to accelerate and decelerate, does do a decent charge and discharge, so on that basis, there appears to be no immediate cause for concern. Your IR numbers are starting to rise, but again, no alarm bells at this stage.
    I would look more at Rennie's suggestion and inspect the exhaust system for leaks, especially looking closely at where the exhaust connects to the manifold. If there is a blockage in the exhaust, you may see that bounce on the springs. Try to pinpoint where the engine is loudest when you have a helper press down on the accelerator pedal.
    You can use an OBDII scanner, like the Autel AP200 (which is popular around here), to look at the fuel trims. Both long-term (LTFT) and short-term fuel trims (STFT) should be near zero +/- 5. If the combined total is near 20, you have a problem.
  7. Zanga
    Zanga New Member
    Leicester
    These were the other results of the battery check from the car itself in vehicle signal check mode.
    Battery 11.9V with Tail lights off
    And 11.4V with them on.
    thank you for the help, I will try check out the fuel trims like you mentioned.
  8. dolj
    dolj Senior Member
    8,528
    4,327
    That is almost fully discharged. You want to aim for the high 12 volts long term. You probably will benefit from using a 4-5 Amp fully automatic 12 V battery charger with a setting for charging AGM batteries, to charge that battery up.
    As long as your car does not dip below 11.0 V when it starts, you just need to charge that battery up. If it can't hold a high 12 V charge (12.7 to 12.9 or greater) after charging and then being left overnight, then you should look at replacing the 12 V battery. Make sure whatever you get is an AGM. These don't seem readily available at the UK after-market suppliers, for some reason.
  9. Zanga
    Zanga New Member
    Leicester
    Will look to purchase a new 12 V battery and buy one of those chargers you mentioned just to keep at hand. Appreciate all the advice !
  10. dolj
    dolj Senior Member
    8,528
    4,327
    Just to be clear, I am not recommending that you replace the 12 V battery; it is expensive. Do the check I mentioned and only replace if it failed. You would be better off spending your money on the battery charger and using it regularly. Also, while I'm talking about the battery charger, get one with a quick connect that you can attach to the battery posts in the back. Because of its convenience, you will use the charger more often, and you will not cross-connect it.
