Oil pump chain position.
Discussion in 'Prius v Technical Discussion' started by Hirshwin, Jan 26, 2026 at 7:54 PM.
  1. Hirshwin
    Hirshwin New Member
    Thousand Oaks
    2013 Prius v wagon
    Hello Prius Chat members,
    I am fully involved with a DIY cylindar head gasket repair. I have the head back from a machine shop and it all looks pretty good. It's pretty eash to tell when the crank is TDC. But, there is not much information on this smaller chain. Many of the videos do not even pay attention to the relative position. There is one post on prius chat that which refers to the reationship. I have rotated the engine not several times and have the small dot alligned on the lower gear and the tooth is very close on the upper. maybe half a tooth off. There does seem to be a small triaangle stamped on the large gear with the holes. A stamp like a small triangle which is perfectly alligned with the top link. Question. Must the valve train be in specific time with the lower for balance purposes? Is my position correct. Some have mentioned that every nine turns of the crank is when you get both yellow marks aligning on both sprockets. I believe the larger sprocket with the sqared off teeth if for crankshaft position ? BTW, I did not disasssemble any part of this lower assembly. Finally, because the chain is on I can's see and marks on the upper inner sprocket. Just the triange mentioned . I'm guessing this is correct.
    Many thanks to anyone with posses these details.
    Hirsh
  2. rjparker
    10,289
    6,436
  3. Mendel Leisk
    41,698
    Last link in my signature is the full engine section from Repair Manual; might help.
    (on a phone turn it landscape to see signatures)
