Prius 2010 Energy flow Arrows not showing
Discussion in 'Gen 3 Prius Main Forum' started by Lib, Jan 25, 2026 at 3:53 AM.
  1. Lib
    Lib Junior Member
    32
    Zambia
    After realizing this we opened up the HV battery cleaned the boss bars and the nuts boxed it up. But still the energy flow arrows were not showing after driving it for 30 km intense driving and error code or there is a cable which is not connected at the 12th volts battery. It's a blue and paper cable.
  2. Lib
    Lib Junior Member
    32
    Zambia
  3. PriusCamper
    PriusCamper Senior Member
    12,899
    5,229
    Pacific Northwest, USA
    I'm not sure what you're saying here? Did you have a warning light with an error code or not? And if you did what is the error code?
    Also disconnecting the 12v battery for a minute will do a factory reset on your car and its the easiest way to fix a glitch like this.
  4. indel
    indel Member
    225
    78
    Northwest Indiana
    His 12V battery harness is broken partially, which is probably what's causing missing data (I don't even know how) that is normally fed to the energy monitor.
  5. Lib
    Lib Junior Member
    32
    Zambia
    l did the reset by disconnecting 12 v batterry but the arrows still not showing.after speeding with aircon on it gave an error code P0A80.
    PriusCamper likes this.
  6. Lib
    Lib Junior Member
    32
    Zambia
    i
    s that what the blue and purple cable is for?it seems to be coming from the lights as it moves to gether with those cables.where should it be connected
  7. PriusCamper
    12,899
    5,229
    When you get a P0A80 code the computers shut down the hybrid systems so I'm pretty sure the screen would show no arrows when that happens. Apologies for not being more clear, I thought you had no arrows and no error codes at the same time.
  8. Lib
    Lib Junior Member
    32
    Zambia
    after resetting there were no arrows and no error codes,error code came after driving for some days
