Please help
Discussion in 'Gen 2 Prius Main Forum' started by Ajj, Jan 27, 2026.
  1. Ajj
    Ajj Junior Member
    uk
    ----UK----
    Please help c1241 code
    ✳️✳️ Update the local garage told me it HV traction battery problem. And he told me he had recalibrate the battery because the cells were not even, some 80 % and some 50%. He did this by using a snap on scanner only. And it took approximately 30 minutes. Is this possible I paid him for the work.
    As I drove out of the garage. The braking system light re appeared. Thanks for looking everyone. IMG_1240.jpeg IMG_1229.jpeg
  2. ChapmanF
    18,969
    I think I would not return to that garage. C1241 is not about the traction battery, and there is no traction battery 'recalibration' that balances the modules in half an hour using only a scan tool.
    pasadena_commut and Brian1954 like this.
  3. Ajj
    Ajj Junior Member
    uk
    ----UK----
    Hi thanks for your reply. He insisted that he balanced the battery via a snap on scanner. It may have been one hour. Do you think the the 12 volt battery that needs replacing.
    #3 Ajj, Jan 27, 2026
  4. ChapmanF
    18,969
    He can insist all he wants; there's no scan tool function to 'balance' a traction battery that I know of. Not in half an hour, not in an hour.
    So far, I can't say what "needs replacing", if anything. It sounds like you have a C1241 code. You can search for C1241 on this page, and you'll get the basic idea what things can cause it and where to start looking:
    Blink (a/k/a Flash) Codes – How to. | PriusChat
    Fixing or replacing anything comes after finding the cause of the problem.
  5. Ajj
    Ajj Junior Member
    uk
    ----UK----
    Thank you
  6. highmilesgarage
    highmilesgarage Active Member
    494
    183
    Kansas City
    the 2nd gen Ford Escape Hybrid has that balancing feature using a scan tool (Forscan) but I don't think any Toyota hybrid has that. Your mechanic just basically screwed you..
  7. PrimalPrius
    PrimalPrius Member
    138
    America
    Those codes are both from ABS/VSC/TRAC because it is seeing a 12V battery voltage that is too low. (Neither is about the HV battery).
    First step is to charge your 12V with a battery charger. Keep a jump pack with you if you have one.
  8. qmanqman
    qmanqman Active Member
    444
    153
    CO
    FYI, "Traction Battery," if you wanna call it that, rebalancing takes 3 days using an $800 tool
  9. PrimalPrius
    PrimalPrius Member
    138
    America
    Actually, I should have written: C1241 is caused by the battery. C1249 could have a "real" cause.
    First I would ensure that battery is good, clear codes, verify that brake lights work, and see if the code comes back.
  10. dolj
    dolj Senior Member
    8,633
    4,387
    Wellington, New Zealand
    Maybe, but there can be other things to check. Specifically, C1241 is about low/high voltage arriving at the B+ terminal of the skid control ECU. Everything on that path from the 12 V battery to B+ is suspect until ruled out.
    Brian1954 likes this.
  11. PrimalPrius
    PrimalPrius Member
    138
    America
    Correct, but battery should be most common cause. I think that the part missing from the quote is the correct next step for most people: "First I would ensure that battery is good, clear codes, verify that brake lights work, and see if the code comes back."
    #11 PrimalPrius, Feb 12, 2026
  12. dolj
    dolj Senior Member
    8,633
    4,387
    Another thing to bear in mind is that C1241 is often set while driving. Theoretically, the battery is not in the loop once the car is READY.
    The point I am trying to get across is that this code simply is not caused by the battery as was stated up thread. This code is far more nuanced.
    The first step with any code that involves voltage received is to check the power supply. The repair manual test is to check the 12 V battery voltage, and (usually) if it is above 10.5 V, then move on to the next step.
  13. Ajj
    Ajj Junior Member
    uk
    ----UK----
    Thank you I bought a new 12v
  14. PrimalPrius
    PrimalPrius Member
    138
    America
    Yep, I'm just saying that first thing to do is to check the battery. I think that in most cases the code is picked up when the voltage of a marginal battery drops while getting the car to ready mode.
    The cause could, of course, be something else, but the 12V battery needs to be checked first.
