Steering wheel replacement for "System Malfunction Visit Your Dealer" dash warning
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by GeoJ, Dec 30, 2024.
  1. GeoJ
    GeoJ Active Member
    219
    198
    United States
    2023 Prius Prime
    XSE
    I had a "system malfunction visit your dealer" dash alert with a little orange icon (circle with rectangle and two orange marks in the rectangle). Dealer ran faults and apparently there is a defective sensor in the wheel, so they have ordered replacement wheel.
    All under warranty, so other than a half day it takes to do the work, not really a big problem. My only question, is there any concern on having a non factory installed steering wheel on this kind of car? I would not think so, and have no options anyway, but wondering if anyone else has experience with this. Dealer said it is the only time they have seen it. Thanks.
  2. ChapmanF
    18,681
    Replacing the Toyota wheel that came on it with another Toyota wheel fresh out of a box?
    Wouldn't worry me....
    GeoJ likes this.
  3. Danno5060
    Danno5060 Active Member
    394
    201
    Wyoming
    There are too many buttons in that wheel to replace it with something other than a replacement OEM one. Unless you like not being able to control things on the car.
    The sensor that's a problem probably isn't in the steering wheel itself. My guess is It's the steering angle sensor - which is behind the steering wheel. It's not all that unusual for those to go out, but that usually happens after a decade or so, and not after only a year.
  4. KMO
    KMO Senior Member
    2,014
    742
    Finland
    2023 Prius Prime
    Just thought I'd add to this thread - it's one of the ones I found while searching.
    I had the same message, with the failure icons showing for LTA, LKA, PDA and LCA. Same repair proposed - steering wheel replacement.
    Those are all the functions which rely on steering wheel hand detection, and the wheel replacement means the problem has been diagnosed as capacititative touch sensors in the wheel.
    The other fix I've seen apply to one person online is a replacement of just the steering wheel ECU (which is in the wheel to read the touch sensor and control the heating).
    Still within warranty, but not by that much. Hope the new wheel doesn't give up after warranty...
    VelvetFoot likes this.
  5. VelvetFoot
    VelvetFoot Senior Member
    1,318
    513
    New York State
    2026 Prius
    Capacitive would be the more luxurious line, correct? The base model does small steering changes. I believe to see if you’re still holding the wheel. I thought the luxury model used interior cameras.
  6. KMO
    KMO Senior Member
    2,014
    742
    Finland
    2023 Prius Prime
    In the US and Europe, PHEVs have the capacitative sensors. That's associated with the lane change assist, and possibly traffic jam assist.
    There is a driver camera too, but that's for attention.
  7. Trollbait
    12,714
    The camera is for TJA, since it allows hands off driving.
  8. VelvetFoot
    1,318
    513
    New York State
    2026 Prius
    Not to drag this off topic, too much, but a search I did to educate myself revealed VW's failed experiment with capacitive steering wheel touch controls. I'm reminded of the stupid light switches on the Prius. I set off a light every once in a while, and look how far removed from, say, the steering wheel it is. Then too, you can't be wearing gloves or have to have conductive pads on them.
    I guess the infotainment touch screen is similar. I had to take off gloves, and it was cold.
    Same as with the fancy steering wheel, I imagine, when it works. Bare hands or fancy gloves.
    All in the name of quasi self driving tech. Not progress.
  9. Trollbait
    12,714
    I thought the issue with VW's buttons was in accidently activating them or require looking for the desired one to hit. Not an issue when used as another way to see in a hand is on the wheel, as it is just one big button you want to be hitting all the time anyway.
    As for the gloves, my touchscreen works with all gloves(so far). Same with the smart key sensors on the door handles. Seems to be a solved issue.
  10. VelvetFoot
    1,318
    513
    New York State
    2026 Prius
    Maybe it was my gloves. They had no conductive pads. Just coated with rubber, the antithesis of a conductor, lol.
    I didn't say it was, just that a search is littered with the VW experience, plus I related my opinion of the Gen5 Prius light buttons, which are not tactile, but capacitive, I assume, since they don't work with my (rubber coated :) ) gloves, but somehow my head seems to set them off when it gets near. And in the Gen5, you're bobbing and weaving a bit in there at times.
    edit: I might ask what car you are talking about in your experience? Gen5 Prius?
    edit2: The glove in question, lol:
    #10 VelvetFoot, Jan 27, 2026
  11. VelvetFoot
    1,318
    513
    New York State
    2026 Prius
    Having nothing better to do, I just found that those gloves do work on the door handles but not the touch screen or the overhead light switches.
    Again, sorry for dragging the thread off topic.
  12. VelvetFoot
    1,318
    513
    New York State
    2026 Prius
    I take it back.
    I was driving around tonight and the gloves started working on the touchscreen and the light buttons, as well as the door handle.
    Voodoo. :)
  13. Trollbait
    12,714
    Perhaps your hands were too cold before:)
    My serious guess is your finger may not have gotten close enough to be detected with the glove on.
  14. VelvetFoot
    1,318
    513
    New York State
    2026 Prius
    I did push on the screen, initially, with no result.
    I think perhaps the first guess was more correct. Or something along those lines, like voodoo. While driving, pushed on the screen and overhead light buttons with the rubber-coated part of the gloves, and it worked.
    They still don't work on my cell phone though. :)
