Airbag SRS ECU Failure causes Hybrid System Malfunction
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Dan Dolsberry, Jan 28, 2026.
  1. Dan Dolsberry
    Dan Dolsberry New Member
    I suddenly got many warnings, Hybrid System Malfunction, Pre Collision Malfunction, ...
    The scanner showed a SRS ECU airbag failure. It was cleared but then came back up.
    Took it to the dealer, they replaced the part, car works fine.
    Seems crazy, why would SRS ECU failure cause about 6 unrelated alarms. Toyota rep said she never heard of this. Any explanation?
    2017 Prius Three
    52,258
    many of the eco's are tied together. the warnings have no detail, that's why you read the trouble codes.
    amos and PrimeDan like this.
  3. BiomedO1
    3,994
    2,102
    SacTown, Ca
    The SRS ECU failed in such a manner that it disrupted communications with those other ECUs. When the master ECU couldn't get a decent reply from them. It flagged all of them as defective.
    YMMV
    PrimeDan likes this.
  4. ChapmanF
    18,434
    I would think not so much 'disrupted communications' and more just the ECUs talking about each other the way they normally do. There isn't any single 'master ECU' that flags others as defective, but various ECUs do routinely communicate with each other and can set trouble codes of their own based on what they hear.
    I don't have a specifically gen 4 manual to look in, but as of gen 3 for sure, the HV control ECU likes to stay aware of what the SRS ECU is saying. Codes like P1606, P3107, or U0151 can be set in the HV control ECU based on what it hears (or doesn't hear) from the SRS ECU.
    Then, in turn, the skid ECU (responsible for the brakes, ABS, and stability control and their associated warning lights) has its own familiar codes C1259 and C1310 that it sets when it is notified of codes in the HV control ECU.
    Won't know for sure if the dealer didn't report what the trouble codes were, but my guess would be those were among them.
    BiomedO1 likes this.
  5. BiomedO1
    3,994
    2,102
    SacTown, Ca
    FWIW: Just trying to K.I.S.S (keep it simple stupid). Would've dropped into more detail if he was troubleshooting it himself. This is why I warn people to use their brain and look for root cause. A lazy troubleshooter could have replace all those ECUs; because the computer told him to.
  6. ChapmanF
    18,434
    Even without seeing the codes that were pulled, I can about guarantee you there wasn't any computer telling anybody to do that. Assuming anybody pulled the codes at all, looking them up in the repair manual would have revealed what they actually meant, and it wouldn't have been 'replace all these ECUs'.
