Maintaining Battery during dormancy
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by gatorback, Jan 24, 2026.
  1. gatorback
    gatorback Junior Member
    58
    It is my understanding, when the Prius Gen3 is garaged, it is not off in the truest sense: it is still burning battery energy and will eventually exhaust one or more batteries. This give rise to several questions:
    1) What is the longest period of dormancy possible? Months, weeks?
    2) During dormancy is only the 12V (small battery) exhausted or is the large HV (hybrid battery) drained as well?
    3) If a 12V trickle charger is engaged during dormancy, is this is enough in two maintain both batteries (hybrid HV battery and 12V)?
    4) If parked at the airport for an extended period of time, is it enough to disconnect the 12V battery or is there a need / advantage to disconnecting the HV hybrid battery?
    I have a Nocu Trickle charger that is switched on / off with a wifi smart switch for 1-month dormancy periods.
    #1 gatorback, Jan 24, 2026
    52,393
    When off, the hybrid battery is isolated from the rest of the car.
    They typically don’t lose much energy, but the older they are, the more prone to it.
    there is a constant drain on the 12v, again, the older it is, the more likely to drain and sulphate.
    In good health, it should last more than a few weeks, but becomes more risky as it ages.
    A maintainer is always best, but disconnecting also works. But you may lose a few settings like radio stations or window memory, it’s inconsistent
    CR94 likes this.
  3. VelvetFoot
    VelvetFoot Active Member
    1,226
    480
    New York State
    2026 Prius
    I don't think there's a need to cycle that maintainer manually.
    bisco and Brian1954 like this.
  4. bisco
    52,393
    correct, it does all the switching itself. when not charging, it is monitoring charge level. you don't want to switch it off
  5. rjparker
    10,519
    6,602
    All vehicles "burn" power when off. A Prius with no aftermarket gizmos has 15-25 ma of parasitic draw. That is 15 thousands of a amp. Many trucks have close to 50 ma of parasitic drain.
    With a new 12v battery you might get 4 weeks before you can't get a Ready. With an 8 year old battery you might get 4 days. The truck has gone through 2 batteries in 8 years. I had a Prius 12v battery last 10 years as have others so its no surprise its dead after a week trip.
  6. gatorback
    58
    Please clarify. I think you are indicating that I should just leave the charger on and all will be automagically fine?
    The reason for the wifi switch is so that I can turn the charger on 3 days before returning home after a 3-5 week trip. It's probably safe to leave it charged the entire time, but it makes me feel better to charge "just enough".
  7. rjparker
    10,519
    6,602
    Allowing it to discharge dramatically reduces battery life. Great if you are helping Priuscamper.
    #7 rjparker, Jan 26, 2026
  8. VelvetFoot
    1,226
    480
    New York State
    2026 Prius
    That's what these new-fangled battery maintainers do. They're smart. Not an old-fashioned dumb 'trickle' charger, so no worries about over charging. Read the link on the NOCO1 you provided above. It's for the 12v battery only.
    As far as the traction battery goes, on your 2010 or on my 2026, I've got no idea. It does lose charge, as @bisco said. Perhaps scouring the threads will give you an idea how long it can remain unattended. If it goes totally dead, I THINK there's no return.
  9. ASRDogman
    ASRDogman Senior Member
    7,824
    3,985
    If you have someone that could drive it for a few miles once a week would be good.
  10. Mendel Leisk
    41,909
    For the 12 volt I'm using a smart charger, rated 4.3 amps, pretty much constantly. If we drive one day, I pop the hood when we get home, plug it in the next morning, it stays thus until the next time we drive. Parked at an airport, for more than a few days, I would disconnect the 12 volt. Apparently that can be done under the hood, the fat, white wire in the fuse box is pulled, IIRC. @ChapmanF I believe shared that tip?
    The Owner's Manual say that the hybrid battery is ok for "several" months down time:
    VelvetFoot likes this.
  11. indel
    indel Member
    277
    88
    Northwest Indiana
    What could happen to the rest of the car if the hybrid battery was disconnected for 1-2 months?
  12. bisco
    52,393
    Nothing, it’s already disconnected when off
  13. bisco
    52,393
    It’s not magic, just software logic.
    If you’re concerned about a fire, you’ve already got a high voltage car in the garage.
    Regardless, you can keep switching it, but it does hurt the battery life to discharge. They prefer to be topped up all the time unless lithium
  14. Mendel Leisk
    41,909
    Our 2010 has spent at least half it's life on a CTEK charger; I installed the current battery in September of 2015. It's still testing like new.
  15. gatorback
    58
    Is there any equivalent trickle charger for the HV battery commercially available?
  16. bisco
    52,393
    Not that I’m aware of. Look into the prolong charger. I don’t think you can use it like that, but I could be wrong
  17. indel
    indel Member
    277
    88
    Northwest Indiana
    There are grid chargers and they only top off the battery. They are also quite expensive. What they won't do is restore the capacity through repeated cycling.
  18. Mendel Leisk
    41,909
    Unless you're mothballing for more than a couple of months, fugedgabout the hybrid battery. For the 12 volt battery, connect it to a decent-quality smart charger for the 12 volt battery, at the commencement of the downtime, and just leave it connected.
    As alluded to by @rjparker, only activating the 12 charger for a few days at the end of multiple week hiatus, could be it's demise.
  19. ASRDogman
    7,824
    3,985
    You could always just disconnect the negative cable of the 12v battery.
    It will hold the charge for several months.
    Just write down your radio stations. And your trip miles, if you keep track of mileage.
    Then just connect it when you return. Remember, the rear deck is electric. So either leave something
    across the latch so it doesn't latch shut, or you'll have to climb through the back and remove the small
    panel to release the trunk lid to reconnect the battery.
    You could disconnect the white cable in the fuse box in the engine compartment. Don't let it touch ground!!!
