Just need to vent...
Discussion in 'Fred's House of Pancakes' started by Mendel Leisk, Jul 6, 2022.
  1. ChapmanF
    18,354
    A file-directly-with-IRS program was piloted by the Biden administration, available in a subset of states to begin with; it got a couple hundred thousand users the first year and something like 350k users the second year if I remember right. The next administration killed it.
    CR94 likes this.
  2. BiomedO1
    3,895
    2,042
    SacTown, Ca
    Ditto; Since the first Trump administration - it isn't worth my time to itemize. I backdated 3-years of returns and they all came out to less than $75 - $100 in tax savings - Not worth the additional time, effort, and possible mistakes or audit review.
    I'm always in the middle or slightly to the right of center on the programs' audit risk gauge - So I guess I have a lot of outliers - but I've got receipts for each and every one of them.
  3. ChapmanF
    18,354
    I understand that, new for this year, there's to be some provision for deducting charitable giving when there's otherwise no benefit to itemizing.
    Interesting question, does deductibility work as an incentive to giving? Might say no, 'cause when the standard deduction went up so much I stopped itemizing, I didn't stop giving. So allowing (a limited part of) it to be deductible again could be seen as a needless incentive for something I was going to keep doing anyway.
    On the other hand, my habits were formed earlier in life when the tax code materially encouraged them. So maybe there was something to that.
  4. CR94
    CR94 Senior Member
    2,719
    1,186
    Northwestern S.C.
    It certainly encouraged procrastinating giving, because it applies to 2026, not 2025 contributions.
    They tricked me when there was a similar exception for charitable contributions during covid times, which I assumed would continue the following year, but it didn't.
  5. CR94
    CR94 Senior Member
    2,719
    1,186
    Northwestern S.C.
    Tax Hawk (not $0, but relatively inexpensive) does cover incomes over 89K, capital gains, capital loss carryovers, etc., and probes for additional deductions.
  6. Trollbait
    12,609
    Just used it. The federal is free if you don't opt for the extras like outside support. It includes the full form, not just the EZ, though I can speak on how it handles investments.
    It charges something like $15 to file a state return. Whether it is worth that depends on the state. Pennsylvania is single flat rate with few, if any, deductions. I just use the state's site to file.
  7. Mendel Leisk
    41,711
    Maybe I should have been a manual writer. I got a low-end, cheap thermostat for the furnace, here's the manaul's explanation for how to adjust temperature:
    I finally figured it out, put this little note by it:
    (I know, don’t give up my day job. :rolleyes:)
    futurist likes this.
  8. bisco
    52,135
    Sounds like Steve Wozniak, when he kept pressing speed on his Prius cruise control.
    The car took so long to increase speed, after he stopped it just kept going up until it hit max, and he thought he had unintended acceleration
  9. Mendel Leisk
    41,711
    Yeah, basically "push buttons, you'll figure it out", lol.
    futurist and bisco like this.
