Prius 2007 switches to neutral or park while in motion
Discussion in 'Gen 2 Prius Technical Discussion' started by Judea, Jan 27, 2026.
  1. Judea
    Judea New Member
    Lagos
    My Prius 2007 switches to neutral or park while in motion. I have a couple of codes C1241. Sometimes the screen displace 12v battery and check hybrid when it happens. But immediately I turn the car off and back on the screen returns to normal and it drives. Again, I noticed my 12v battery drains doesn't charge when I did the self diagnosis on the monitor. I bought another new battery it's the same issue. What could be the problem. I've also changed the gear sensor.
  2. PriusCamper
    PriusCamper Senior Member
    12,985
    5,281
    Pacific Northwest, USA
    You said you have a couple of codes but only listed one? What's the other code?
    As for the photo, that happens when driver's door is open and car is in drive. Not related to your probelm.
    Main concept to understand here is car goes into neutral when it has something seriously wrong with it... I suspect both your 12v and your hybrid battery got problems.
  3. Hayslayer
    Hayslayer Active Member
    445
    262
    If the car door is opened when in DRIVE, the CAUTION screen that appears tells you to shift to the P position when parked. Along with a blurb about batteries not charging if the shifter is in Neutral.
  4. pasadena_commut
    pasadena_commut Senior Member
    2,776
    831
    Southern California
    Since this is often related to a bad 12V the OP should confirm with a voltmeter that the 12V has a decent voltage on it. It is a "new" battery but it might have been on the shelf long enough to fully self discharge, making it a "new" but fully discharged battery, AKA bad. Then verify that both cables are on the posts properly. The clamps should be all the way down, not part way up on the post. Measure the voltage on the posts at the battery, then again at the jump point in the fuse box (with an unpainted bolt on the body for ground). Have one person start the car while another monitors the voltage at the jump post. It should not fall very far. If it drops down below 10.5V (if memory serves) some of the car's electronics won't be happy. If the car starts the voltage will instantly jump up above 13V, possibly as high as 14.3V or so. If the car doesn't start then the battery voltage will slowly return to its original value, but it may take several minutes to do so. That slow recovery is normal, the chemistry in the battery only goes as fast as it goes. The colder it is, the slower that will be.
    Another test is to jump start the car with a known good battery. But be exceedingly careful to put the positive lead on the jump post, because doing it backwards will break things. If it starts from a good battery, but not from the one inside, that pretty much means the problem is with the 12V battery or associated wiring.
    Finally, the p lock screen can also occur when there is a corrosion problem in the fuse box. The "fix" is to add a wire that gets around the corrosion. Worry about that after definitively showing that the 12V is good all the way to the fuse box.
  5. dolj
    dolj Senior Member
    8,524
    4,326
    Wellington, New Zealand
    There is not a single definitive voltage. 10.5 V is the one most commonly seen in the repair manual, but there are others. Others that I have seen are 8.5 V and 8.9 V.
    #5 dolj, Jan 28, 2026
  6. pasadena_commut
    2,776
    831
    Southern California
    I suspect that the exact voltage where things go wrong is in large part a function of how weak the battery is. If one attached a power supply capable of putting out 100A set at 10.5V I bet the car would start every time, and even well below that. However, in the real world using a battery with very low capacity it might start at 10.5V, or even higher, but as soon as the car asks for its 40A (or whatever it is) the voltage would drop like a rock. More or less like on a conventional ICE vehicle when the starter motor asks for more current than the battery can supply. This would be easier to see with an old fashioned analog voltmeter than a modern digital one, because the needle can move very quickly, but most digital ones take a while to settle, and aren't great at giving a reading on a rapidly changing voltage.
  7. dolj
    dolj Senior Member
    8,524
    4,326
    Absolutely agree.
  8. Judea
    Judea New Member
    Lagos
    I also have P0A94. The doors where locked as I was on motion on a freeway
  9. Judea
    Judea New Member
    Lagos
    I bought a fairly used inverter and I noticed my battery drain when I put off the car for some hours. But if I disconnect the battery it doesn't drain no matter how many hours. My door lights are off, everything is off on the dashboard except the key security light that blink
  10. dolj
    dolj Senior Member
    8,524
    4,326
    What is the subcode? You can find the subcode in the freeze frame data. The field is labelled INF code or Detail Code x (where x=1-5)
  11. Judea
    Judea New Member
    Lagos
    I don't have the sub code. All these started since I entered water on the road. The check hybrid and 12v battery level ght came on as soon as I was leaving the pool of water. Though I passed through much more water but this particular day it just happened
