Toyota Unveils the Powerful and Purely Hybrid Next Generation Camry
Discussion in 'Toyota Hybrids and EVs' started by drash, Nov 9, 2023.
Tags:
  1. PriusCamper
    PriusCamper Senior Member
    13,417
    5,416
    Pacific Northwest, USA
    I don't know... My sister moved to Colorado Springs and told me that people don't drive Prius much where she lives because they suck in cold weather. Beyond that I don't know much.
  2. Isaac Zachary
    Isaac Zachary Senior Member
    2,779
    1,501
    Maybe I should answer my own question. I've only lived here for the past 50-some-odd years.
    Other than the typical full-sized SUVs and pickups, this place is also referred to as "the Subaru capital of the world."
  3. Prodigyplace
    12,710
    11,848
    Central Virginia
    So, a Prius V replacement?? My son replaced his with a RAV4 Prime
  4. Prodigyplace
    12,710
    11,848
    Central Virginia
    i have had no issues with my 2-25 in the past year. I have not moved it in a week though. The 2025 Camry battery cannot take people just using the multimedia usit in a mode other than READY though. It is a flooded maintenance free battery with a vent.
  5. Mendel Leisk
    42,289
    That's one swaddled battery.
    Prodigyplace likes this.
  6. Isaac Zachary
    2,779
    1,501
    I bought a self-heating LFP battery and put it in my Avalon. I works pretty well I must say.
  7. Prodigyplace
    12,710
    11,848
    Central Virginia
    It is in a side compartment of the trunk under a panel, much like the Gen 2 & 3 Prius. The car is white so perhaps that color is distracting you.
    #67 Prodigyplace, Jan 30, 2026
  8. Prodigyplace
    12,710
    11,848
    Central Virginia
    i thought all batteries self heated when overloaded. ;)
  9. Isaac Zachary
    2,779
    1,501
    The Li-Time battery I got:
    • 41 °F (5 °C) and below: Any charge current applied to the battery is routed through heating pads between the cells to heat the battery.
    • 32 °F (0 °C) and below: Switches on a diode so that the battery itself can only discharge. Now all charge current goes through the heating pads.
    • -4 °F (-20 °C) and below: Switches off discharge too, so now the battery cannot charge nor discharge. All charge current still goes through the heating pads.
    So I got a Li-Time LFP charger along with this battery that I use when it's freezing cold out. This keeps the battery warm automatically because any battery temp below 40 °F (4 °C) takes charging current and routes it through the pads.
    Trollbait and Prodigyplace like this.
  10. bisco
    52,795
    I don’t know her habits, anything is possible.
    She’s never had a problem in the past with accords, this is her first Camry, though her husband has had a gasser for 10 years
  11. Prodigyplace
    12,710
    11,848
    Central Virginia
    In my opinion. compared to other cars, the battery does not like those kind of draws, You are the HyCam expert though. My only previous hybrid ownership was a Gen 4 Prius.
  12. bisco
    52,795
    No problems with our 3 different generations, but we drive almost every day, cars are garaged and we know not to do anything unless it’s in ready
  13. bisco
    52,795
    5 below zero shouldn’t kill a one year old battery, unless it’s already low
  14. Prodigyplace
    12,710
    11,848
    Central Virginia
    i actually started muine today & moved it. I think out lowest temperature recently was 8 degrees.
    I really wish there was a PHEV Camry.
    Isaac Zachary and bisco like this.
  15. bisco
    52,795
    Me too
