Gen 3 Prius Owners (2010–2015) – Important Action on Head Gasket & Hybrid System Failures
Discussion in 'Gen 3 Prius Main Forum' started by caprib, Jan 12, 2026.
  1. bisco
    52,386
    it's one thing to replace inverters, and a whole nuther to replace engines. the inverter lawsuit was about safety
    BiomedO1 likes this.
  2. BiomedO1
    4,129
    2,169
    SacTown, Ca
    The court also ruled that Toyota must fix it, even if it's a salvaged car. In other words, If someone puts together a FrankenPrius - Toyota must fix that inverter too as long as the VIN meets the inverter suit parameters..........
  3. Mendel Leisk
    41,900
    There is a somewhat astounding statement in my North American 2010 Prius Owner’s Manual:
    I also got this letter from Toyota Canada:
    #23 Mendel Leisk, Jan 14, 2026
  4. ChapmanF
    18,538
    The letter makes another appearance with a red circle around "While the majority of vehicles will not experience this condition", but no red circle around what condition the letter was about.
    The condition that particular letter was about is (just above the red circle that's there) "a sticking EGR valve due to excess carbon build-up" when that condition causes cold start-up misfiring.
    I don't actually know how many vehicles ever do experience that condition. There are occasional posts here where people have found their EGR valve stuck with carbon build-up, but it doesn't seem like a lot of them.
    Other conditions, like rutted ski jumps and clogged coolers, may be encountered more often. (And, of course, a notorious condition that can cause cold start-up misfiring is a damaged head gasket, whatever may have caused that.)
  5. BiomedO1
    4,129
    2,169
    SacTown, Ca
    Sorry should've of been clearer on my post; 300K miles not KM
    That quart for every 600 miles oil burn seems to be industry standard. I believe Subaru also uses that standard to determine engine replacement. Mind you that this consumption would empty your oil sump in less than 2500 miles - for those that don't check their oil levels be it 5K or 10K mile oil change intervals......
  6. BiomedO1
    4,129
    2,169
    SacTown, Ca
    There was a guy from the UK that had 200K+ miles on the clock on a very early gen4. Only did oil changes but didn't do coolant change. His EGR valve locked-up and had a slight hesitation on acceleration. The EGR error code was there the entire time he was parts swapping.o_O
    He did plugs, coils, throttle body clean-out x2; before jumping on to the forum to ask us.
    He posted pictures afterwards and the jammed valve looked more corrosion than carbon fouled.
    #26 BiomedO1, Jan 14, 2026
  7. arealdave
    arealdave New Member
    Helena, MT
    New to Prius, my folks gave us their 2011 a year ago, super clean car, 175000 miles. My daughter drove it for a year at college and it started messing up. Head gasket, intake and $7000 lighter but my wife and I now have a Prius. Hopefully good to go. I’m going to check out the hybrid battery next.
  8. bettergolf
    bettergolf Active Member
    493
    369
    Sanford NC
    Too late now but $7k sounds huge for that work...
  9. indel
    indel Member
    274
    88
    Northwest Indiana
    It's always huge when you have someone else do the work. Cost of labor is absurdly high.
  10. bettergolf
    493
    369
    Sanford NC
    I've seen posts on here where people had a head gasket done for around $3-4k....
  11. bisco
    52,386
    that's why we need a class action, c'mon people!
