Would you worry? Long trip planned and....
Discussion in 'Gen 3 Prius Main Forum' started by Johnny Cakes, Feb 1, 2026.
  1. Johnny Cakes
    Johnny Cakes Senior Member
    1,055
    780
    Virginia, USA
    Prius has been sitting in the garage for several weeks -- it is bone-chilling cold here.
    I went out to start it up and begin packing it. Noticed "Check Engine Light." Connected my OBD-II scanner.
    Got Code P261B which indicates a "Coolant Pump 'B' Control Circuit Range/Performance" issue,
    Cleared the code.
    Turned off the ICE.
    Restarted.
    Code has not returned with engine running for an hour.
    I was planning on a 2,000 mile trip starting today. Would you be worried or is this a common one-off?
    Thanks!
  2. ForestBeekeeper
    ForestBeekeeper Active Member
    779
    308
    Maine
    I would be perfectly confident to make a coast-to-coast road trip.
    There is always some minor roll-of-the-dice chance that any roadtrip could result in a breakdown. Such is life.
    PrimeDan likes this.
  3. Hybrid Ron
    Hybrid Ron Junior Member
    29
    South of there
    2015 Prius v wagon
    While a breakdown is always possible, I think the OP was concerned about the engine coolant code that got thrown (check engine).
    The question is given the environment (extreme cold, car sitting for several weeks), code gets thrown, gets cleared, and doesn't return in an hour, whether the code was probably a glitch or is a probably legit and something to be worried about on his trip.
    I don't know the answer to that, but I bet someone here does.
  4. PriusCamper
    PriusCamper Senior Member
    12,984
    5,280
    Pacific Northwest, USA
    Can you please give a specific temperature for "bone-chilling" ?
  5. BiomedO1
    4,013
    2,109
    SacTown, Ca
    How many miles on her and has that electronic coolant pump ever been changed along with the OEM coolant change interval. You should probably monitor coolant temperature during your trip; so you don't end up popping a head gasket....
    Good Luck.....
    Brian1954 likes this.
  6. indel
    indel Member
    261
    83
    Northwest Indiana
    Why is it that so many people think clearing codes is the most immediate action to take once CEL illuminates? The car is perfectly capable of clearing the code itself if you fix the issue. I would try to postpone the trip for a couple of days and take the car out for a long drive first to see if the code returns. During the drive, continuously monitor coolant temperature. Most obd scanning apps are capable of monitoring that parameter.
    2000 miles with that code in the back of my mind? Hell naw!
  7. CR94
    CR94 Senior Member
    2,737
    1,196
    Northwestern S.C.
    What was the voltage of the [nominal] 12-volt battery after "sitting in the garage for several weeks"? If you're lucky, low boot-up voltage confusing the computers might explain code. Otherwise, having either coolant pump die during your trip wouldn't be much fun.
  8. Johnny Cakes
    1,055
    780
    Virginia, USA
    Left before getting these replies.
    Drove 13 hours straight. No codes no issues. Drive included the Allegheny Plateau so hard on engine. Had to drive around North Carolina to avoid deep snow.
    Bone chilling cold means 7 degrees outdoors and probably 15 in the garage. Coolant serviced at recommended intervals, pump never replaced.
    With these additional data points, do you think I can breathe easy, and figure code was an anomaly?
  9. BiomedO1
    4,013
    2,109
    SacTown, Ca
    Your data points are kinda irrelevant, since your driving in freezing cold. It's a fairly economical engine that will self cool when moving below 70F. Just because you crossed the Allegheny Plateau in freezing weather doesn't mean your out of the woods. Did you monitor your ECT while you were doing that climb; because your temperature lamp doesn't light up until 248+F, nominal is 180F-210F. Your car might hit 210F on that climb, if it was 100+F with your AC going. I'm assuming it was cold when you did that, running your heater to remove more heat.
    There's been many reports of the electronic coolant pump getting lazy and or intermittent past 120K miles, I'd certainly look at it before it does some major damage to the motor. Many just install a temperature gauge or monitor it through torque app. It's a silent killer and you've got your first warning.
    It's your car, do whatever you want. Just don't be surprised if it blows up on you..... Just saying......
    #9 BiomedO1, Feb 2, 2026
  10. ChapmanF
    18,454
    My concern about the engine water pump is that it is what makes the coolant move.
    When the coolant moves, it can carry engine heat away from the engine, to the radiator and cabin heater.
    Just as importantly, when the coolant moves, it evens out the temperatures between different places in the engine. And it makes the coolant temperature reading (the sensor is just on the head where the coolant comes out) an accurate picture of the temps inside the engine.
    When the coolant doesn't move, it does none of those things, and your engine temperature reading is just telling you how hot a particular corner of the cylinder head happens to be.
    PrimeDan, indel, Merkey and 1 other person like this.
  11. Johnny Cakes
    1,055
    780
    Virginia, USA
    These are all interesting replies. I appreciate the insight/advice.
    Made it to Florida where it is a bit warmer (60 degrees). So now car has been driven for three days, 1,500 miles, and was in READY mode for one night (camping).
    I don't know much about how the Check Engine Light works, but if there were a true issue would it have come back on?
  12. ASRDogman
    ASRDogman Senior Member
    7,758
    3,967
    Welcome to Florida, You didn't bring any more cold with you did you???? :whistle:
    Cold can have strange effects on parts. It could have just been a fluke.
    But it's always best to check thing to be safe.
    The coolant pump might be on it's limits. How is the coolant level? Is the heat working?
  13. ChapmanF
    18,454
    Every code has its own detection conditions. Some are one-trip (light comes on right away if the detection conditions are met), some are two-trip (code is 'pending' when the conditions are met the first time, light comes on if the conditions are met again while 'pending').
    P261B is a one-trip code that means the water pump RPM dropped below 900 while the pump should have been running.
    So, that happened once, on February 1st, and turned your engine light on.
    And it hasn't happened again yet.
    Does that make it "a true issue" or not "a true issue"?
    BiomedO1 likes this.
  14. rjparker
    10,410
    6,521
    I would get a water pump at a dealer asap to make a possible emergency easier to resolve. Hopefully you have towing via your car insurance or AAA.
    I would hope you brought a scanner with you and can monitor both engine temperatures fulltime.
    An ideal monitor for this situation is a P10 obd2 with a user set early audible alarm since you are running it while sleeping.
  15. VelvetFoot
    VelvetFoot Active Member
    1,128
    446
    New York State
    2026 Prius
    Every time I see the title of this thread, I think of:
  16. Johnny Cakes
    1,055
    780
    Virginia, USA
    Doesn't Chapman's post provide the answer? For whatever reason (extreme cold, lack of use, or just a fluke) it triggered once -- and never experienced the fault condition again.
    Given the number of miles driven and amount of time that has gone by, it seems like the "immediately buy a water pump and keep it with you" replies seem alarmist (although I appreciate all opinions).
    I don't know what I don't know -- seems that a one-time condition, not experienced again, is not something to worry about. But again, I don't know what I don't know. What am I missing or is this right? Please chime in!!
  17. rjparker
    10,410
    6,521
    If you are monitoring your coolant temperature as suggested, stay the course.
    The reality is many water pump problems don't code but bidirectional testing can usually diagnose.
    In the same manner, it is very common for engines to be running hot, even dangerously so, and not code. Sometimes we hear the light flashed once and never came back but overheating was occurring.
    BiomedO1 and Brian1954 like this.
  18. BiomedO1
    4,013
    2,109
    SacTown, Ca
    It's true; what you don't know - you don't know. That's why they also say ignorance is bliss - If you don't see it coming; it's someone else's fault.
    We've already told you to actively monitor your ECT - then you'll KNOW if it's a phantom error message or not. It's your car, so you can just keep playing the what I don't know game - Again ignorance is BLISS....
    Peace out....
    #18 BiomedO1, Feb 7, 2026
  19. ChapmanF
    18,454
    It may depend on what the condition is.
    It seems to me that the right number of times for a Prius water pump RPM to have dropped below 900 when it should be operating, is zero.
    This one has already done that more than zero times.
    I could see maybe letting it go, if you had thought of a plausible explanation for why it did so on that one occasion, and that explanation also covers why it hasn't again, and convinces you that it won't, going forward.
    I'm not sure what such an explanation would look like.
    Have you checked the freezing point of your coolant mixture? Could the coolant in the bone-chilling cold have begun to gel, and slowed the pump down that way?
