gear selector malfunctioned in 2015 Prius
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Maruska, Jan 31, 2026.
  1. Maruska
    Maruska New Member
    Vermont
    Today on a frosty 8 degree morning I drove a few miles to do an errand close by and parked on a level spot at the location. When I started the Prius, it would not shift into drive or reverse. Sometimes it would shift into park or neutraI and kept getting messages that said "shift the car into park" etc... and there were other warning lights on. It also wouldn't turn off all the way and made a long beeping noise when I closed the door from the outside. I had to have it towed to my home. The tow person said he experienced the same thing as i did and that it wouldn't even go into neutral. At home, while on the tow truck I got it into neutral and then once off the truck the gear selector started working again and I was able to drive it forward. I live in a remote area with extreme cold in the winter and need my Prius to be reliable. Has this happened to anyone? Is it a sign of something more serious? I recently replaced the 12 volt battery.
    52,362
    get the new battery load tested for free at most auto parts stores, this weather is wreaking havoc on them.
    if it's low, keep it on a maintainer when not driving.
    if that isn't the problem, you'll have to scan for trouble codes.
    Maruska likes this.
  3. CR94
    CR94 Senior Member
    2,741
    1,198
    Northwestern S.C.
    Update?
  4. Tombukt2
    13,355
    2,405
    If be interested in codes . Like lost communication codes electrics and hybrids are bricking all over the place rt now . Just watched a Chevy Volt brick in the cold . Cost more than the car's worth to fix it . And parts is a big issue . Abandoned model. They dropping like dive bombers
  5. Maruska
    Maruska New Member
    Vermont
    I drove it yesterday and today for about an hour each time and it was working as usual. I am taking it to get the hybrid battery tested and whatever else.
