Install dash light to show when ICE is on / off ?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by cDxA, Feb 2, 2026.
  1. cDxA
    cDxA Junior Member
    40
    Imagine an LED that comes on when the ICE does.
    Install it in front of you on the dash.
    Just bright enough to not be distracting.
    Why not just look at the screen ?
    Well, because I like to focus on driving instead of the screen.
    My screen is also all clouded up and cracking inside.
    How hard would it be to find the wire going to the ICE that is powered on and off and splice into that with a low wattage LED ?
    Could that brick the car ? Also, as with everything, it's never that easy.
  2. ChapmanF
    18,484
    well, that depends on whether there is such a wire
  3. Brian1954
    Brian1954 Senior Member
    2,386
    958
    South Central PA, USA
    PrimeDan likes this.
  4. PriusCamper
    PriusCamper Senior Member
    13,004
    5,286
    Pacific Northwest, USA
    Monitoring your engine RPMs via an OBD2 reader and an app on your phone will give you lots more info about your engine running or not then a light will.
  5. fuzzy1
    10,602
    Imagine an ODBII-port tachometer.
    As mentioned by a previous member, most of these devices supply plenty of other datapoints too.
  6. cDxA
    cDxA Junior Member
    40
    Thanks.
    I know these supply lots of useful data, but what I am needing is a way to look straight ahead at the road and know if the car is in ICE or not simply by seeing a light in my pereferal vision.
  7. dolj
    dolj Senior Member
    8,546
    4,341
    Wellington, New Zealand
    Why?
    What benefit do you perceive you will get from having this information?
    PrimeDan and Brian1954 like this.
  8. PriusCamper
    13,004
    5,286
    Many apps like "Car Scanner ELM" have a heads up display setting so your phone will reflect the screen on your windshield so you can look straight ahead at the road while keeping your RPM at 3500, which is the most efficient RPM to use when climbing mountains and doing freeway driving.
    cDxA likes this.
  9. ChapmanF
    18,484
    I'm not sure I follow. This being the gen 2 forum, we'd be looking at the left plot here:
    What jumps out at me is that the desirable 230 g/kWh region is skinny perpendicular to the RPM axis, but long perpendicular to the torque axis. The region extends from ~ 2000 RPM up to just below 4000 RPM, but only a narrow range of torque, just under 80 to just over 100 Nm.
    That suggests to me an efficient power-management strategy would be to try to match whatever power in kW the mountain or freeway is demanding by aiming for an engine torque in that sweet 80 to 100 Nm range and letting the RPM fall where it may in that 2000 to nearly 4000 RPM window. (As the heavy path in the plot shows, that's pretty much the strategy the car is programmed to use.)
    3500 as an upper limit to shoot for makes sense; it is pretty close to the rightmost end of that most-efficient region, so if you do catch yourself exceeding 3500 on a freeway or mountain climb, it might pay to back off some, if the conditions allow it.
  10. fuzzy1
    10,602
    3500 RPM for ordinary non-mountain-climbing freeway driving, without large aerodynamic drag bundles attached externally, will bring far more speeding tickets than I can afford, even in this modern low-enforcement environment. When traffic and road conditions allow one to use such speeds at all.
    I believe existing MPG-vs-speeds graphs show better MPGs at speeds achieved by considerably lower RPMs.
  11. PriusCamper
    13,004
    5,286
    We've already had this conversation before... Basically the mountains on the I-5 Between Eugene, Oregon and Redding, CA. is when I pull out the RPM meter... I've driven the I-5 between Seattle and San Francisco in past quarter century for more 400K miles and when I started driving a Prius in 2012 it was hard not be able to monitor the RPM. First time I did this mountain stretch while monitoring the RPM I found I had a bad habit of driving slower than engine had power for on the steeper hills because I didn't want to push the gas pedal down too far, but realized that aiming to keep it at around 3500 was much faster over the steep stuff and MPG seemed no different, maybe a tiny bit better. And clearly any type of flat ground or down hill the 3500 RPM wasn't relevant because that would often make me go faster than 70mph, which is where I tend to enjoy the drive speed.
  12. fuzzy1
    10,602
    That isn't what you wrote back at post #8, and seems very likely what prompted Chap's reply.
