Rear interior lights won’t turn off
Discussion in 'Gen 5 Prius Main Forum' started by artieb, Feb 2, 2026.
  1. artieb
    artieb Junior Member
    74
    medford ma.
    2024 Prius
    Limited AWD-e
    When I shut car down and open doors all interior lights go on shut the door and front interior lights go off in about 30 seconds but rears stay on
    They go off about 10-15 minutes later
    Doesn’t seem correct?
    Is it ???
  2. mingc
    mingc Member
    77
    57
    Portland, OR
    2023 Prius
    XLE AWD-e
    The rear personal lights have switches right next to the lights. You likely have the switches turned on. Try turning them off. They'll still be subject to the door lights control IIRC.
  3. PriusCamper
    PriusCamper Senior Member
    13,005
    5,286
    Pacific Northwest, USA
    Change the rear lights to "door" setting on the switch.
  4. artieb
    74
    medford ma.
    2024 Prius
    Limited AWD-e
    thanks the problem was that one button was pushed on so lights would stay on
    After 10 minutes or so they’d go off when car was shut down
    Car used in daytime mostly and hadn’t seen them on apparently
    Thanks again
    mingc and Brian1954 like this.
