Pulse and Glide
Discussion in 'Gen 2 Prius Main Forum' started by Jerry Shaw, Oct 8, 2013.
  1. VelvetFoot
    VelvetFoot Active Member
    1,120
    434
    New York State
    2026 Prius
    Trying see how to manipulate this, as a (hypermile-ish) driver.
    The car has a mind of its own.
  2. Winston Smith
    Winston Smith Active Member
    387
    259
    OH
    2024 Prius
    LE AWD-e
    Or would you want to if you could? I understand the system to be tuned to preserve battery function over time. That battery is expensive. Gasoline isn't.
    I am fascinated by marginal efficiencies and have experienced the triumph of calculating great mileage at the pump, but it's more a compulsion than a substantial economy.
    The older cars at the beginning of this thread a decade ago may have benefitted from a technique adapted for a wheezy engine and modest motors. On the other hand, the IC engine in your car makes more HP than a basic Integra 30 years ago and the electric motor would itself have you beating an aircooled VW. The pulse on that is fast enough that you'd be burning fuel at about the same rate as any other normal car, and your glide would be screwed up by the automatic regeneration.
    If you bought your car this last September maybe you were still getting used to the car while the weather was still warm. Your efficiency when it is 10F may not seem great, but I bet you'll be able to manage 70+mpg this summer without too much focus.
    If you work on technique that gets you to 80mpg, and you drive a thousand miles a month, you'd save fewer than two gallons for the entire month than if you'd gotten 70mpg and driven normally.
  3. VelvetFoot
    1,120
    434
    New York State
    2026 Prius
    It's a game.
  4. Winston Smith
    387
    259
    OH
    2024 Prius
    LE AWD-e
    I get it. I'm afflicted too. I indulge in more secondary road travel at lower speeds than I did before this car partly because of the difference in efficiency shown. (Though I will note that it isn't an objectively bad 80-90mph highway appliance, it isn't remarkably efficient while doing it.)
    I wouldn't consider it a victory of that game if posting a great mpg figure came at a much higher cost than the gasoline.
  5. VelvetFoot
    1,120
    434
    New York State
    2026 Prius
    You could say the same thing about a hybrid car. Does it really save any money over the life of that vehicle in the holistic sense.
    Winston Smith likes this.
  6. ChapmanF
    18,436
    The older cars at the beginning of this thread were second-generation Prii (already nearly a decade old by then).
    Finding 'glide' is finding a point where you're minimizing any automatic regeneration.
    Wayne Gerdes was in a modern, fifth-generation Prius when his techniques clocked 93.158 MPG from LA to New York City a couple years ago.
    As I don't normally clock numbers anything like that myself, I'd probably defer to his experience if I wanted to up my hypermile game.
    VelvetFoot likes this.
  7. pasadena_commut
    pasadena_commut Senior Member
    2,765
    828
    Southern California
    Yes. On the highway "win" is:
    1. plan far enough ahead so that the brakes are never used
    2. maintain a constant speed (on flat terrain) - easiest with cruise control
    3. go as slow as possible (and safe)
    4. don't drive in another car's air wake (more drag)
    5. don't draft (more mpg, wildly unsafe)
    6. drive in the smoothest lane (bouncing the car burns energy, right lane is often chewed up by trucks)
    7. when descending long slopes set the accelerator so that the ICE is not running and regen is minimized.
    8. on rolling hills the goal is to maintain constant energy (kinetic + potential): I'm not sure what the ideal strategy is beyond that (as there are a lot of variables) other than do not aim for constant velocity (especially with cruise control) - gain speed going down and lose speed going up, but not too much in either direction.
    In slower driving on uneven terrain always try to coast down. In my area (which is flat for no more than 100 yards in any direction) many trips are "uphill outbound, downhill inbound". I can frequently drive several miles coasting, with the MPG bar indicator showing 100 mpg for 15 to 20 minutes (excluding stops at lights and such). When my wife drives the Prius she does so like a normal car, and she gets around 10 mpg less on most of these local trips than I do.
  8. pasadena_commut
    2,765
    828
    Southern California
    The only way our 2007 could achieve that would be if it drafted another vehicle (except on downhill runs). It might come close if it never went above 45 mph, but that would be one long, long drive.
  9. VelvetFoot
    1,120
    434
    New York State
    2026 Prius
    He probably would charge a lot, lol.
    Also he might not be saying everything in his tips I read once.
    Hypermiling can be dangerous.
  10. fuzzy1
    10,579
    Uncle Wayne's site has accumulated many broken links in the years since I was active there, but I'd point to this item as the centerpiece there:
    Beating the EPA - The Why’s and How to Hypermile | CleanMPG
    See also (some links broken):
    Welcome to CleanMPG Primer | CleanMPG
    On PriusChat (which also suffers old broken links):
    New owner? Want MPG help? Read this first. | PriusChat
    https://priuschat.com/attachments/why_dont_i_get_the_epa_mileage-pdf.7078/
    In closed loop competitions, IIRC, Wayne pushed a Gen2 Prius above 130 mpg. Yes, the speed was under 45, probably closer to 30.
  11. VelvetFoot
    1,120
    434
    New York State
    2026 Prius
