2017 Prius Check Engine Light
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Muhammadk, Feb 2, 2026.
  1. Muhammadk
    Muhammadk New Member
    Ontario, Canada
    I have an idea of what the issue is but I just want to confirm before I go pointing fingers at people in my household.
    My check engine light is on and, when my mechanic checked, he said it had something to do with temperature. What I believe is happening is that something happens with the thermostat or something related to it when the engine isn't allowed to get up to temperature before driving. The issue only comes up when I don't let the engine pre-heat for at least 10 minutes.
    The mechanic cleared the code and I hadn't had an issue, even after driving 40 minutes straight. The light didn't come back on until my sister used my car recently and, while I mentioned to her that she needed to warm up the engine before driving, I don't believe that she did, hence the engine light coming back on.
  2. Brian1954
    Brian1954 Senior Member
    2,385
    958
    South Central PA, USA
    What was the actual trouble codes that the mechanic found. Without the trouble codes, everyone reading this thread can only guess what the problem is. The probability of guessing correctly is very low.
    BiomedO1 likes this.
  3. BiomedO1
    4,058
    2,136
    SacTown, Ca
    Need error code(s).......
    Modern ECU, fuel injected cars DO NOT need warm-up before taking-off. You should take it "easy" on the engine until it warms up, but does not require 10 minute warm-up. If your battery level (SOC) is high, putting the car into Ready mode won't even fire the engine anyways - so how is it warming-up?????o_O:(:whistle:
    The 2016-2018 Prius are prone to exhaust gas heat exchanger leaks. If your coolant level is low that can cause temperature issues, but I'm just guessing without the error codes.
    Something is off or your misunderstanding the mechanic or the mechanic doesn't know what they are doing. As I stated in the previous paragraph, putting the car into ready mode doesn't guarantee an engine start.
    #3 BiomedO1, Feb 2, 2026
    Bill Norton likes this.
  4. Bill Norton
    Bill Norton Senior Member
    2,208
    744
    MONW, Ks.
    2019 Prius
    L Eco
    Yeah, this is not a thing with any modern car.
    It's nice for the driver if it's 15°F. (y)
    Keep an eye on the coolant level and swing by an auto parts store that will read the codes for you.
  5. BiomedO1
    4,058
    2,136
    SacTown, Ca
    Your mechanic didn't fix the car; because your problem came back!!!! Find someone that specializes in Prius, that understands these cars. More than likely an intermittent sensor issue, that your sister's driving style is somehow triggering. Just because your driving style isn't triggering it - doesn't mean there isn't a problem. That's why we need the error codes to figure it out!!!
    It's NOT your sister's fault; because I routinely place my car into ready mode and take-off out of my driveway - WITHOUT issue; since day ONE from the dealership....... I manually switch the car over to HV mode when I hit the highway 8 minutes down the road. That's when my engine kicks on from a dead cold start; moving 65+mph....... This is a car; not Cinderella's glass carriage. If anything, you should be thanking her for alerting you that there is a problem with the car. Early diagnosis and fixes are usually a LOT cheaper than letting a problem fester and getting more expensive to fix.
    #5 BiomedO1, Feb 3, 2026
