Easy headlight replacement?
Discussion in 'Gen 3 Prius Main Forum' started by semilak, Feb 3, 2026.
  1. semilak
    semilak Junior Member
    Darwin NT
    I need to replace the front headlight, and on YouTube I’ve seen a few tutorials that show you have to remove the front bumper etc.. isn’t there an easier way? thanks for tips!
  2. ForestBeekeeper
    ForestBeekeeper Active Member
    779
    308
    Maine
    In my 2017 prius we had to replace one headlight. The LED lights are hardwired in an assembly. The cost of a replacement assembly is $2700 [dealership price]. We had a local mechanic do it, he was able to find an aftermarket assembly for $2500.
  3. Dodge Propshaft
    Dodge Propshaft New Member
    Wisconsin
    Removing the front bumper isn't very difficult - theres a plug under the drivers side to easily disconnect all of the wiring.
  4. Tombukt2
    13,336
    2,401
    I guess the aftermarket finally picked up the LED setup very cool . 2500 to light the road lawdy. On regular gen3 you undo screw in fender well like gen2 and ya tweak bumper cover out n forward n down allowing headlight to slide forward n out of car . I hope one is not doing this for bulbs.
  5. Mendel Leisk
    41,850
    Repair Manual concurs. For your info:
  6. VelvetFoot
    VelvetFoot Active Member
    1,162
    459
    New York State
    2026 Prius
    that's progress
  7. indel
    indel Member
    267
    87
    Northwest Indiana
    Remind me to never buy a Prius gen 4 and onwards. $2700 for one head lamp? That's beyond ludicrous
  8. Mendel Leisk
    41,850
    Gen 3 ain't much better. A pair of sealed-beams used to be $20. Now the price for a pair of those effing sculptures rivals what we paid for our first car. Yeah, appreciate there's been inflation, but still...
  9. indel
    indel Member
    267
    87
    Northwest Indiana
    Is it that the entire housing is $2700 on gen 4 but you can just change the bulbs? Or it's all integrated and the entire unit must be replaced? The latter seems boneheaded and downright malicious.
  10. rjparker
    10,438
    6,546
    There are two headlight assemblies on a gen3. Most have halogen low beams and halogen high beams. Both bulbs can be replaced without removing the bumper cover.
    Trim 5 on gen3 uses an integrated led low beam and a replaceable halogen high. If the trim 5 led goes out you have to replace the whole headlight assembly. However you can remove the bumper cover screw in each wheel well allowing you to pull the bumper cover partial off. This allows access to two of the headlight assembly screws. If you were replacing one side only you could remove the bumper screw for just that side.
    On a gen2 I find it easier to do the partial cover removal than to blindly replace its bulbs. Some with small hands can do it blindly.
    #10 rjparker, Feb 3, 2026
  11. Mendel Leisk
    41,850
    That's us. :(
  12. semilak
    Darwin NT
    Hey guys, I have the same issue. I think I must have installed the low beam halogen bulb incorrectly, and the socket melted, so now I need to replace the whole headlight.
    I’ll try to just loosen the bumper on one side since I only need to replace one headlight.
    Thanks a lot!
  13. rjparker
    10,438
    6,546
    Passenger side
    You have to remove the plastic cover on top as well.
    Driver's side
  14. semilak
    Darwin NT
    THANKS for super fast answer! You helped me a lot :)
