Denso vs. NGK 4912 Spark Plugs? Are Amazon or Rock Auto problematic for 'fakes'?
Discussion in 'Gen 3 Prius Technical Discussion' started by davekro, Feb 4, 2026 at 1:48 AM.
  1. davekro
    davekro Active Member
    500
    69
    SF Bay Area, East Bay
    2013 Prius Plug-in
    I was wondering if it was worth it to consider using an equivalent spec'd NGK 4912 (ILKAR7B11) vs. the OEM choice of Denso SC16HR11(Toyota p/n 90919-01275)?
    Although Rock Auto lists four different NGK part numbers for the 2013 Prius, Chat Gpt says only the NGK 4912 (ILKAR7B11) matches the Denso/ Toyota Spec. and is of equal quality to the Denso SC16HR11. I understand that Chat Gpt, can make mistakes. But what seems to be the consensus of this NGK plug being of equal quality as the Denso?
    On Rock Auto, I see four different NGK Spark Plug part numbers listed as compatible for the 2013 Prius.
    NGK 4912 {Alternate Inventory Numbers: ILKAR7B11} $5.89 (O'Reilly's price $23.99! :eek:O )
    NGK 92274 {Alternate Inventory Numbers: LKAR7AHXS} $9.47
    NGK 93501 {Alternate Inventory Numbers: LKAR7BIX11S} $6.58
    NGK 94297 {Alternate Inventory Numbers: LKAR7BGP} $5.38
    Rock Auto- DENSO 3499 {Alternate Inventory Numbers: SC16HR11} $10.39
    O’Reilly’s and Autozone local stores Denso 3499 $17.99
    toyota.oempartsonline.com Lists Spark Plug - Toyota (90919-01275) for $14.49
    So, is the $5.89 NGK 4912 just as good as the $10.39 Denso at Rock Auto?
    Any worries of getting a 'fake' Denso from Rock Auto?
  2. Hayslayer
    Hayslayer Active Member
    428
    252
    I use RA quite frequently and have purchased dozens of sets of Denso plugs. Never had a counterfeit.
    Many people believe a spark plug is just a spark plug, but I also know I've never had a skip or miss after installing a new set of Denso plugs in a Prius.
  3. ASRDogman
    ASRDogman Senior Member
    7,697
    3,952
    You just can't trust rock auto any longer. I had used them in the past, and had no issues.
    But they are using more and more of the cheap chinese crap. Like pretty much everyone else, sadly.
    I ran ngk once because autozone didn't have the Bosch plugs. They only lasted a few thousand miles
    before they started missfiring. I replaced them with the Bosch plugs and haven't had any failures.
    Just check the box and make sure they aren't made in china. (y)
    Denso have been very good plugs. Getting they from the deal will cost a little more, but the chance of
    getting the cheap chinese copies, is pretty much zero. They last over 100,000 miles, how often do you think
    you'll need to replace them???
  4. Mendel Leisk
    41,738
    How much is the savings, say an inexpensive bottle of wine, every 12 years or 120k miles?
    I typically buy plugs from a local automotive place, a dedicated automotive place. With our ‘10 though, the Denso’s were $2~3 CDN per plug cheaper, through dealership. Worth a call.
  5. indel
    indel Member
    242
    78
    Northwest Indiana
    Given their loooonnnnnggggg change interval, spark plugs is not the item to try to save money on. Buy it from the dealership. Last fall, I was able to buy some for $13 a piece with free shipping.
