Featured Toyota makes progress on all-solid-state batteries
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Gokhan, Feb 4, 2026.
  1. Gokhan
    Gokhan Senior Member
    6,420
    2,560
    Paramount CA
    Toyota has made progress on its all-solid-state batteries with the groundbreaking of its Idemitsu plant for its sulfide-based solid-state electrolyte. They expect limited production in 2027 or 2028.
    @Salamander_King, what does that Japanese figure say? I see a 2030. I personally don’t expect Toyota to go mainstream on solid-state batteries before circa 2035.
    Toyota partner Idemitsu breaks ground on all-solid-state EV battery plant
  2. Gokhan
    6,420
    2,560
    Paramount CA
    AI translated the figure before @Salamander_King got a chance.
    So, I expect the pilot plant capacity to be on the order of 1 GWh/yr. That is around 15,000 BEVs a year. This means we will see limited production of all-solid-state EV models in 2027–2028. Some of these will be HEVs and PHEVs.
    We should expect mainstream production, such as 100 GWh/yr, to enable around 1 million BEVs a year in the early 2030s.
    Note that Toyota’s all-solid-state battery technology uses a lithium-sulfide solid-state electrolyte (also including some other elements). Competitors of this technology include Samsung and Solid Power.
    Salamander_King likes this.
  3. Salamander_King
    Salamander_King Senior Member
    11,021
    8,955
    New England
    Gokhan likes this.
  4. bwilson4web
    16,303
    It may help to explain the "dendrite" problem that makes solid state batteries so hard:
    During charging, layers of lithium (or other metals) are deposited into microscopic sized, crystal needles. These grow to penetrate the separator and short the cell. An NiMH battery uses hydrogen ions which can not form a crystal at ordinary temperatures. A point electric field becomes preferential for ion deposits. So this suggests several approaches:
    • non-cyrstalizing metals - hydrogen or liquid metals at higher temperatures.
    • strong separators - in theory, a separator can pass ions but not permit a needle pointed dendrite to pass through
    • alloy electro-positive metals - if the deposit voltage is close enough, two metals will disrupt dendrite formation but there may be issues getting intro carbon holding them without excessive mechanical stress and strain
    Solid state batteries are a technical nightmare and I wish anyone working on them “Good Luck!”
    #4 bwilson4web, Feb 4, 2026
  5. Trollbait
    12,634
    Solid state batteries will be like Li-ion when the Volt and Leaf first arrived, expensive. They'll be coming to market against much cheaper LFP and even Na-ion. They will only be used in high end, long range BEVs, and then there will be established semi-solid state batteries on the market.
    Toyota is putting them in hybrids because of lower per car cost and ease of replacing with failures. They talked of using it hybrids first because the battery layers could crack.
    Aside, @bisco reported this Bolt was always going to be a short production run. This one still doesn't use GM's BEV platform.
    The moving of ICE models into that US plant is likely the actual news.
    BiomedO1 likes this.
  6. BiomedO1
    3,948
    2,076
    SacTown, Ca
    That seems to be a sensible approach and getting real world time in the saddle to iron-out kinks. A hybrid can limp back home, where a BEV would be F.O.R.D.. (found on road dead; as opposed to the brand of the same name sake).;)o_O:whistle::X3:
  7. bwilson4web
    16,303
    Meanwhile: Daily Automotive News
    TESLA MASS PRODUCES DRY ELECTRODES TO SLASH COSTS BY $1 BILLION
    Elon Musk
    Making the dry electrode process work at scale, which is a major breakthrough in lithium battery production technology, was incredibly difficult. Congratulations to the engineering, production and supply chain teams and our strategic partner suppliers for this excellent achievement!
    Tesla and its supplier partners have scored a major battery achievement, according to Elon Musk. He says they’ve been able to make the dry electrode process work at scale, calling it a major breakthrough in lithium battery production technology. Instead of applying the cathode material with liquid solvents, which requires massive drying ovens, it’s applied in a powder form. The process can slash factory space by up to 90%, increase output and significantly cut energy costs, which the company previously estimated could save it $1 billion. Tesla said some versions of the Cybertruck were supposed to get the batteries sometime last year, but now that it can mass produce them, they should spread to other models. And previous reports indicated that the Robotaxi and/or Cybercab would feature these batteries, which could be crucial in Tesla’s ability to hit its goal of making 2 million Cybercabs a year.
    Elimination of the "wet" coatings is a major production improvement but my understanding is a small amount of electrolyte is still needed for the chemistry to work. Previous needs to evaporate and condense the electrolyte are no longer needed. Past technical presentations indicate 1/3d the floor space. Production yields remain an open question.
  8. bisco
    52,193
    Buy tesla stock!
  9. bwilson4web
    16,303
    I leave that to others as I have lost confidence in the CEO. He has become distracted and uses TSLA as a "cash cow" to fund his other hobbies.
    I am more interested in automotive like the "SCOUT" even though wholly-owned by VW. Some of the Asian companies sound good too.
  10. PriusCamper
    PriusCamper Senior Member
    12,946
    5,261
    Pacific Northwest, USA
    Seems like small scale Plant 2 expansion of capacity for 2027 is the only relevent effort to measure their work by... The rest, especially mass production is just pie in the skie. Though this schedule is way less delusional than the BS that Toyota Marketing was promising this past Fall.
  11. Gokhan
    6,420
    2,560
    Paramount CA
    Dendrites are mostly a problem with lithium-metal (anode) solid-state batteries, such as the one QuantumScape is trying to mass-produce. They use a ceramic solid-state electrolyte to prevent them. Toyota uses a traditional carbon/silicon anode, so there is no dendrite issue.
    The main challenge is that the solid-state electrolyte tends to separate from the anode and cathode during charging and discharging. They try to circumvent that through external pressure application and other manufacturing tricks. Moreover, the manufacturing process is more complex and requires greater precision.
    Isaac Zachary likes this.
  12. Gokhan
    6,420
    2,560
    Paramount CA
    No, he is not talking about the electrolyte. He is talking about the cathode. He is saying that the cathode active material, such as NMC (lithium nickel manganese cobalt oxide) or LFP (lithium iron phosphate), will be applied as a powder rather than as a slurry before baking. It is true that this is how solid-state battery electrolytes are also made, such as Toyota or Solid Power baking a sulfide solid-state electrolyte into a glass/ceramic structure from a powder rather than a slurry. However, the electrolyte here remains a liquid, making it a liquid battery, and only the cathode is dry, as before.
  13. Gokhan
    6,420
    2,560
    Paramount CA
    This is the standard operating procedure for developing a new battery:
    1. Research and development in a lab
    2. Lab testing
    3. Field testing
    4. Pilot plant producing around 1 GWh/yr
    5. Mass-production plant producing around 50 GWh/yr
    Toyota has already reached step 4, and only one step remains. Scaling new technology is difficult and is done gradually, with each step requiring back-and-forth that leads to new understanding and improvements in the scaling process and manufacturing tools.
  14. Isaac Zachary
    Isaac Zachary Senior Member
    2,622
    1,339
    This is why we use Li-ion batteries, because the ions don't crystalize, but rather, move around freely.
    This was a problem with lithium metal batteries.
    The same problem and solution apply to both wet and solid-state batteries.
  15. bwilson4web
    16,303
    Source: Battery Power Online | A Look Inside Your Battery: Watching the Dendrites Grow
    Among the reported incidents, internal short circuits caused by lithium dendrite formation were one of the reasons for battery failure. A Li-ion battery operating under abnormal conditions, such as overcharging or lower temperature charging, can lead to a harmful phenomenon called lithium dendrite growth or lithium plating. Lithium dendrites are metallic microstructures that form on the negative electrode during the charging process. Lithium dendrites are formed when extra lithium ions accumulate on the anode surface and cannot be absorbed into the anode in time. They can cause short circuits and lead to catastrophic failures and even fires. Several Samsung Galaxy Note 7 batteries caught on fire in 2016, and the investigation revealed the mechanism that lithium dendrites caused an internal short circuit.
  16. Isaac Zachary
    2,622
    1,339
    Yes. Lithium-ion batteries also aren't perfect. That's kind of the main reason not everyone is driving an EV.
    But at any rate, a well designed lithium ion battery does what I said, it moves ions, puts them into latices, and that, in theory, should keep dendrites from forming.
    If you're really afraid of dendrites and lithium batteries catching on fire, then maybe it you ought to stop driving a li-ion powered EV. I'm just saying.
  17. Gokhan
    6,420
    2,560
    Paramount CA
    Even lithium-metal batteries are lithium-ion batteries. You can’t move metals through a battery. You can only move ions. Incidentally, lithium coin cells, such as those used in your key fob, are lithium-metal batteries.
    Lithium-metal batteries are called so because the anode is pure lithium metal. However, during charging and discharging, lithium ions are transported through the solid-state electrolyte using its ionic conductivity.
    Dendrites can form in any lithium-ion battery. However, dendrites are not a main issue in non-lithium-metal solid-state batteries such as Toyota’s. The main challenge there is the separation of the solid-state electrolyte from the anode and cathode during charging and discharging, as the battery undergoes volume changes. Manufacturing is also much more difficult and requires precision.
    Another issue with Toyota’s sulfide all-solid-state batteries is that they release toxic hydrogen sulfide gas if they come into contact with water, which could potentially be deadly.
  18. Isaac Zachary
    2,622
    1,339
    Perhaps technically, technically yes. But I haven't heard anyone refer to lithium-metal batteries as lithium-ion, as the lithium isn't stored at both sides in ion form (solid metal is not a pile of ions).
    But at any rate, that wasn't the point. The point was dendrites are a problem in lithium-metal batteries that keeps them from being rechargeable, as there is no lattice that can absorb and park the ions, and saying that solid-state batteries will suffer the same problem just isn't necessarily true.
  19. Gokhan
    6,420
    2,560
    Paramount CA
    They are all lithium-ion batteries, and the electrodes are always solid. Only the electrolyte differs.
    Lithium is not stored in ion form in lithium-ion batteries either. The anode and cathode, where lithium atoms are stored, are entirely solid in lithium-ion batteries as well, for example, LiC₆ for the anode and LiCoO₂ for the cathode.
    The difference between solid-state and liquid-filled batteries lies only in the electrolyte, not in how lithium atoms are stored. In a solid-state battery, lithium ions are transferred between the solid anode and solid cathode through the lattice structure of a solid-state electrolyte, using its high ionic conductivity. In a liquid-filled battery, lithium ions are transferred between the solid anode and solid cathode via a liquid electrolyte that goes through a porous membrane.
    And a lithium-metal anode is a lattice, just like a LiC₆ graphite anode. All solids have a lattice structure. Liquid electrolyte does not penetrate into a LiC₆ graphite anode, which is nonporous. If we imagine a lithium-ion battery having a porous anode like you do, then it actually becomes a lithium-metal battery, as the lithium ions would fill the pores by growing into a lithium-metal lattice during the charging phase, which would also result in the dendrites you dread. In fact, gradual lithium-metal plating on the anode happens in all lithium-ion batteries, and it is one of the root causes of capacity degradation.
    Toyota all-solid-state batteries use the same anode and cathode in conventional lithium-ion batteries, the only difference being the porous membrane and the liquid electrolyte having been replaced by a layer of a solid-state electrolyte. Lithium-metal batteries offer a higher specific capacity, but an all-lithium anode makes them more susceptible to dendrite growth because there is no carbon or silicon around the lithium atoms to inhibit lithium dendrites. In any case, it is a moot issue for Toyota batteries, and others have succeeded in preventing dendrite growth in lithium-metal batteries, albeit their manufacturing is more challenging than carbon/silicon-anode solid-state batteries.
    #19 Gokhan, Feb 4, 2026
  20. Isaac Zachary
    2,622
    1,339
    Ok. I don't know if you're just trying to argue against everything I said or just confuse everyone.
    A well designed battery has "parking spaces" for the lithium atoms to park on both the anode and the cathode. Yes, abnormal charging conditions or a poorly designed battery allows them to start stacking up and sticking to each other, forming dendrites. The same happens with pure lithium metal anodes, and which is why they are not suitable for recharging.
