Featured Toyota makes progress on all-solid-state batteries
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Gokhan, Feb 4, 2026 at 12:59 AM.
  1. Gokhan
    Gokhan Senior Member
    6,390
    2,552
    Paramount CA
    Toyota has made progress on its all-solid-state batteries with the groundbreaking of its Idemitsu plant for its sulfide-based solid-state electrolyte. They expect limited production in 2027 or 2028.
    @Salamander_King, what does that Japanese figure say? I see a 2030. I personally don’t expect Toyota to go mainstream on solid-state batteries before circa 2035.
    Toyota partner Idemitsu breaks ground on all-solid-state EV battery plant
  2. Gokhan
    6,390
    2,552
    Paramount CA
    AI translated the figure before @Salamander_King got a chance.
    So, I expect the pilot plant capacity to be on the order of 1 GWh/yr. That is around 15,000 BEVs a year. This means we will see limited production of all-solid-state EV models in 2027–2028. Some of these will be HEVs and PHEVs.
    We should expect mainstream production, such as 100 GWh/yr, to enable around 1 million BEVs a year in the early 2030s.
    Note that Toyota’s all-solid-state battery technology uses a lithium-sulfide solid-state electrolyte (also including some other elements). Competitors of this technology include Samsung and Solid Power.
    Salamander_King likes this.
  3. Salamander_King
    Salamander_King Senior Member
    11,020
    8,955
    New England
    Gokhan likes this.
  4. bwilson4web
    16,293
    It may help to explain the "dendrite" problem that makes solid state batteries so hard:
    During charging, layers of lithium (or other metals) are deposited into microscopic sized, crystal needles. These grow to penetrate the separator and short the cell. An NiMH battery uses hydrogen ions which can not form a crystal at ordinary temperatures. A point electric field becomes preferential for ion deposits. So this suggests several approaches:
    • non-cyrstalizing metals - hydrogen or liquid metals at higher temperatures.
    • strong separators - in theory, a separator can pass ions but not permit a needle pointed dendrite to pass through
    • alloy electro-positive metals - if the deposit voltage is close enough, two metals will disrupt dendrite formation but there may be issues getting intro carbon holding them without excessive mechanical stress and strain
    Solid state batteries are a technical nightmare and I wish anyone working on them “Good Luck!”
    #4 bwilson4web, Feb 4, 2026 at 9:17 AM
  5. Trollbait
    12,623
    Solid state batteries will be like Li-ion when the Volt and Leaf first arrived, expensive. They'll be coming to market against much cheaper LFP and even Na-ion. They will only be used in high end, long range BEVs, and then there will be established semi-solid state batteries on the market.
    Toyota is putting them in hybrids because of lower per car cost and ease of replacing with failures. They talked of using it hybrids first because the battery layers could crack.
    Aside, @bisco reported this Bolt was always going to be a short production run. This one still doesn't use GM's BEV platform.
    The moving of ICE models into that US plant is likely the actual news.
    BiomedO1 likes this.
  6. BiomedO1
    3,921
    2,063
    SacTown, Ca
    That seems to be a sensible approach and getting real world time in the saddle to iron-out kinks. A hybrid can limp back home, where a BEV would be F.O.R.D.. (found on road dead; as opposed to the brand of the same name sake).;)o_O:whistle::X3:
  7. bwilson4web
    16,293
    Meanwhile: Daily Automotive News
    TESLA MASS PRODUCES DRY ELECTRODES TO SLASH COSTS BY $1 BILLION
    Elon Musk
    Making the dry electrode process work at scale, which is a major breakthrough in lithium battery production technology, was incredibly difficult. Congratulations to the engineering, production and supply chain teams and our strategic partner suppliers for this excellent achievement!
    Tesla and its supplier partners have scored a major battery achievement, according to Elon Musk. He says they’ve been able to make the dry electrode process work at scale, calling it a major breakthrough in lithium battery production technology. Instead of applying the cathode material with liquid solvents, which requires massive drying ovens, it’s applied in a powder form. The process can slash factory space by up to 90%, increase output and significantly cut energy costs, which the company previously estimated could save it $1 billion. Tesla said some versions of the Cybertruck were supposed to get the batteries sometime last year, but now that it can mass produce them, they should spread to other models. And previous reports indicated that the Robotaxi and/or Cybercab would feature these batteries, which could be crucial in Tesla’s ability to hit its goal of making 2 million Cybercabs a year.
    Elimination of the "wet" coatings is a major production improvement but my understanding is a small amount of electrolyte is still needed for the chemistry to work. Previous needs to evaporate and condense the electrolyte are no longer needed. Past technical presentations indicate 1/3d the floor space. Production yields remain an open question.
  8. bisco
    52,174
    Buy tesla stock!
  9. bwilson4web
    16,293
    I leave that to others as I have lost confidence in the CEO. He has become distracted and uses TSLA as a "cash cow" to fund his other hobbies.
    I am more interested in automotive like the "SCOUT" even though wholly-owned by VW. Some of the Asian companies sound good too.
  10. PriusCamper
    PriusCamper Senior Member
    12,932
    5,254
    Pacific Northwest, USA
    Seems like small scale Plant 2 expansion of capacity for 2027 is the only relevent effort to measure their work by... The rest, especially mass production is just pie in the skie. Though this schedule is way less delusional than the BS that Toyota Marketing was promising this past Fall.
