  1. cnc97
    cnc97 Senior Member
    1,422
    1,536
    Evansville, IN
    bluhawk likes this.
  2. Priipriii
    Priipriii Member
    231
    67
    Wrapping is absolutely painful to do. Everytime i done it, i swore to never again and after some time passes, i go back to trying again only to realize why i quit the first time. One of the most anger induced tasks on the planet. You actually did it without leaving bubbles or creases, nice. Respect.
    Do you do it dry, or do you use soap and water?
  3. bluhawk
    bluhawk Junior Member
    25
    Torrance, CA
    Dry, this was my first time. I did learn a lot from this experience. There was a point when i questioned myself why am I doing this. Would I do this again? Absolutely, but not for other people. Maybe when i get tired of the color. Next project would be the cleaning of EGR.
  4. sourdoughfred
    sourdoughfred New Member
    Alameda, CA
    Installed TRD rear sway bar as well as TRD springs with new KYB shocks, thanks to Hybrid Pit for the quick shipping.
  5. MPGRaja
    MPGRaja Senior Member
    472
    1,687
    Corona
    It’s has definitely been a long time since I posted any upgrades. But here’s what she currently looks like ;) G’s bumper has been long time coming for me.
  6. Markee
    Markee Member
    336
    South Florida Broward County
    I called the guy to come out and fix my leaking Solar Sunroof
  7. Bohemian Grove
    55
    40
    I might be the first person to install the new fully illuminated auto power folding mirror switch in a Prius. This one is RGB swapped. It also has a feature to tilt your side view mirrors downward when in reverse, so you can see the curb… but I haven’t figured that out yet. It is NOT plug and play.
    Also check out my YouTube for more details!
    jarl, Khezekiah, tony_2018 and 2 others like this.
  8. douglasjre
    douglasjre Senior Member
    2,250
    751
    Null, NL
    Love the pass eject and turbo options ;)
    Bohemian Grove likes this.
  9. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,576
    2,603
    Taylors, SC
  10. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    I don't know if this will make a difference, but in the 2025 Toyota Crown Signia, both mirrors will tilt down when put in reverse if the selector switch is either in the left or right mirror select position, but it will not work when the selector switch is in the middle position.
    SM-S936U ?
    RightOnTime, w84me and Bohemian Grove like this.
  11. HKz
    HKz Junior Member
    45
    17
    Mesa, AZ
    Wife had been asking for fogs for years but I finally got around to grabbing some cheap winjets for christmas and I just finished 'er up....fresh set of headlights with black housings are next!
    Also I hooked my fuse taps to the interior cig fuse and exterior hazard fuse but I read there are more preferable fuse spots but after a bit of searching google and looking at all the other fuses I could tap from, I wasn't sure what would be better..I read to use the side marker fuse instead of hazard but I didnt see anything in the fuse box that corresponds to the side markers..
    Burna J and ASRDogman like this.
  12. Hiva
    Hiva New Member
    Chicago
    Battery died (RIP, was changed on Jan 2018, laste 8 years!, Japanese shit is no joke!), replaced it with some aftermarket super start platinum AGM from O'Rielly (4 years warranty). Tried to put a maintenance for 4 years from now (2030), but noticed the maintenance clock does not go beyond 2027 ( I have prius 2010 trim IV)! :/ I take my excitement back from Japanese shit is no joke!
  13. katzi
    katzi Junior Member
    New Zealand
    I fitted LED indicators front and rear, with a *Great* sounding Flasher via AliExpress (got the LEDs themselves locally), and replaced the numberplate bulbs with LEDs.
    OH and last week my JDM-spec numberplates arrived, so they fit perfectly on my JDM G-Touring.
    Burna J likes this.
  14. douglasjre
    2,250
    751
    Null, NL
    Chinese bulbs will burn your car to the ground. Good luck w that. Check back in a week and tell us how many bulbs still work
  15. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
  16. JazzzJon
    JazzzJon New Member
    Hawaii
    Cat and Skid!
    Burna J likes this.
  17. Georgina Rudkus
    3,576
    2,603
    Taylors, SC
    Mine have been working for 5 plus years and are still going strong.
    HKz and Brian1954 like this.
  18. ASRDogman
    ASRDogman Senior Member
    8,066
    4,089
    Nifty cover! Did you make that? Why didn't you have it cover the whole area like the oem?
    Just wondering...
  19. douglasjre
    2,250
    751
    Null, NL
    My cat theft protection is a .380cal
  20. Georgina Rudkus
    3,576
    2,603
    Taylors, SC
    How do you protect yourself from the rogue cop or ICE officer trained on video games who shoot first and ask questions later?
