ID connector hybrid battery
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Steve 72, Feb 4, 2026.
  1. Steve 72
    Steve 72 Junior Member
    Maryland
    I don’t know where it connects to all I know is it goes straight down and is a blue with black stripe Please help
    #1 Steve 72, Feb 4, 2026
  2. PriusCamper
    PriusCamper Senior Member
    13,301
    5,377
    Pacific Northwest, USA
    That's the connector that confirms that your orange safety plug is locked into the correct position...
  3. Hayslayer
    Hayslayer Active Member
    501
    300
    There is a socket located on the bottom front of the receptacle for the interlock safety switch. The wire that disappears "straight down" plugs into that socket. When the safety plug is inserted into its socket, the handle is rotated until vertical, then pushed straight downward. This last downward motion inserts a shorting wire across that interlock plug to let the ecu know the interlock switch is fully installed. If that plug is not inserted, the ecu will think the safety switch is not installed and won't allow the car to function.
