How was Florida this year?
Discussion in 'Environmental Discussion' started by bwilson4web, Feb 3, 2026 at 8:42 AM.
  1. bwilson4web
    16,294
    In addition of an orange tree blight, I notice the freezing line went pretty deep into Florida. Just wondering if anyone witnessed the effects this past week?
  2. hill
    8,872
    Calling Mr Bisco -
  3. bisco
    52,179
  4. hill
    8,872
    Paved paradise, put up a parking lot.
    some 40-50 years ago California Orange crop was 40% larger. ie - don't look for the West Coast to make a big dent if Florida starts shipping less (in the short run) due to weather. Our SoCal - Orange County Park & Ride was right next to some 20+ acres of Orange Groves in the 90s. It got bulldozed. The shopping center, Irvine Spectrum - needed expansion so now it's 80+ acres of 'commerce' ...... or whatever you want to call it.
    PrimeDan and bisco like this.
  5. fuzzy1
    10,549
    An area article on the West's lousy ski year claimed that the Florida Panhandle has received more snow this year than has Salt Lake City.
  6. bisco
    52,179
    Our politicians have never paid much attention to food production, very short sighted
    PrimeDan likes this.
  7. hill
    8,872
    Well - except for grain over production - so we can run our cars ah la ethanol - adulterated gasoline so that mileage ends up being worse (Sigh)
  8. bwilson4web
    16,294
    Having benchmarked Prius efficiency on:
    • straight gas - retail most expensive
    • 10% ethanol - cheapest per mile
    • 50% ethanol - more expensive without cold weather triggering check engine light
    • 85% ethanol - retail rate excessive over wholesale yet provides peak power and efficiency
    My Prius benchmarks revealed something other than "mileage ends up being worse." My benchmark consists of:
    • +8% grade climb at maximum throttle
    • ~1.1 miles up ~525 ft (up Old Dixie Highway South of the Tennessee River)
    The Prius uses the knock sensor to tune the spark advance. More spark advance, more HP and a faster hill climb which peaked on E85. The "check engine" light was because the spark advance was more than the hard coded Prius control laws allow. At one time, I looked at an after-market, timing system that would "spoof" the engine to allow maximum spark advance for E85 operation. But then I realized the problem with the wholesale and retail rates:
    • gasoline ~= K * wholesale price
    • ethanol ~= (K + ~20%) * wholesale price
    The cost of E85 is artificially high even though it performs better than straight gas. More power with lower coolant and exhaust temperatures. There is a reason high performance dragsters run a mostly alcohol fuel.
    #8 bwilson4web, Feb 5, 2026 at 4:03 AM
  9. hill
    8,872
    Ethanol in machinery / small ICE & boat enginess IIRC is still such that it can do bad things;
    E-10 Alive: The corrosive damage ethanol gasoline does to your fuel pump | Equipment World
    Perhaps things are better now in more recent times? But yeah, running a tank of e85 through the system - it's not going to wipe things out real quick - any more than a diet of mashed potatoes, corn chips, cream cheese dip & a Coke - over the Super Bowl weekend.
    I still find non-ethanol fuel for the snow blower & have switched over to an electric mower / leaf blowe & string trimmer to avoid the risk.
    #9 hill, Feb 5, 2026 at 10:24 AM
  10. Trollbait
    12,624
    It is the potential of long term damage to aluminum* and rubber/plastic parts ethanol can do to parts with using concentrations higher than recommended. Plain steel might also be at risk; which is why these blends aren't piped in petroleum lines.
    *Adding a bit of water to the fuel blend will protect aluminum. Those additives claiming to protect against ethanol likely are just that.
