“New” (Feb ‘26 Production onward) OM – Different Specs (no more AWD?)
Discussion in 'Gen 5 Prius Main Forum' started by Probity, Feb 5, 2026 at 8:51 PM.
  1. Probity
    Probity Junior Member
    42
    30
    Covington LA
    2026 Prius
    I happened to see there’s a new owner’s manual on the Toyota site. The 1st one (like mine, 600 pages) is:
    Toyota 2026 Prius from Jun. 30, 2025 through Jan. 31, 2026 Prod. Owner's Manual USA and Canada Only (OM47F65U) pM_PRIUS_OM_OM47F65U_(U).book
    The “new” one (680 pages) is:
    Toyota 2026 Prius Starting Feb. 1, 2026 Prod. Owner's Manual USA and Canada Only (OM47G03U) OM47G03U . This one contains a new section on “Plug-In Hybrid”.
    I get it that periodically there’ll be updates, revisions to OM’s, every manufacturer does it. I haven’t done a detailed side-by-side comparison, will leave that to others. But what caught my eye is there seems to be some spec changes between the pre-Feb. 1 ’26 production and post-Feb. 1 ’26 production runs. No mention of AWD anymore in the entire post-Feb ’26 manual. So no more US AWD HEV's?
    I’m not familiar with ‘the Toyota way’, don’t know how they normally do things, but struck me a bit odd that in the middle of a model year there would be spec changes. For those in the know – what’s going on? Just some examples:
    1. Dimensions and weights – same, Engine – same M20A-FXS (bore, stroke, displacement)
    2. Fuel tank capacity – (a) pre-Feb ’26: AWD 10.6 US gal., FWD 11.4 US gal, (b) post-Feb ’26: all 10.6 US gal.
    3. Oil capacity with filter – (a) pre-Feb ’26: 4.4 US qts., (b) post-Feb ’26: 4.1 US qts
    Other:
    Gokhan likes this.
  2. Pdog808
    Pdog808 Active Member
    434
    289
    Los Angeles
    2018 Prius Prime
    The lower oil capacity on the newer models is interesting. Assuming the same internal engine design, perhaps a smaller oil pan?
  3. hill
    8,873
    That can't be great for heat dissipation.
  4. Trollbait
    12,626
    The new manual is for the plug in.
    It doesn't get AWD. The motor is more powerful for EV performance. It has a lower oil capacity due to an engine balancer.
  5. hill
    8,873
    Still - pulling a grade in the Arizona summer desert running AC & stuck behind some nightmare accident w/ miles of backup? I'd love love love to have a few extra quarts going on.
  6. KMO
    KMO Senior Member
    1,998
    720
    Finland
    2023 Prius Prime
    Clearly. :LOL:
    That might have been a clue. :ROFLMAO:
    So those aren't real changes, but there have been a few.
    Biggest thing I'm aware of is the July 2025 production change:
    * Switch from specced 0W-16 to 0W-8 oil (but no evidence of a related mechanical change aside from removal of the low oil level sensor)
    * Removal of charge mode for the US plug-in (new California emissions rules).
    Plus there was the US Prime -> PHEV branding change before that, and the nightshade colours.
    Also there have been multimedia system updates - newer models have refreshed UI graphics. Not a major change like the 2006 G2 update that got a higher-res screen - might be software-only, so could maybe one day be issued as an OTA update, if Toyota ever did one.
    One extra function in Europe is a hotkey in the status bar for disabling the EU-mandated-on-power-on speed beeps. (I got the newer UI for my older car from a multimedia unit replacement, but the "hotkey" just indicates status - I'm assuming I'd need a dash update for it to work as a button as described in the newer manuals).
    Phone charger became available in Europe in 24 or 25, it had previously been omitted.
    Also they were plugging some EV geofencing thing for the navigation. My newer navigation now talks about charging points as if it were an EV, noting that destination is out of range and having the option to suggest charging points. Original didn't care about that sort of thing.
    #6 KMO, Feb 6, 2026 at 1:35 AM
    LRO likes this.
  7. Gokhan
    Gokhan Senior Member
    6,402
    2,558
    Paramount CA
    You are comparing the HEV to the PHEV as others said.
    There have been no significant updates in Gen 5 so far. The engine is identical in earlier years; so, you can use 0W-8 in all Gen 5 if you like.
    2027 should finally be a mid-cycle refresh with TSS 4.0 and perhaps some other updates.
