Should I replace my 2yr old TPMS when changing tires?
Discussion in 'Gen 3 Prius Main Forum' started by Somu, Dec 31, 2025.
  1. Cornvalue
    Cornvalue New Member
    24
    Internet
    Business Ed. Plus
    @Mendel Leisk Surely this could be determined by many other sensors ie VSC etc.
    I do generally agree this system is sound - apart from Toyotas unsmart implementation to not auto learn new IDs until perhaps 2017-18.
    That is not ok. Also - replaceable batteries should be mandatory. It’s all in all not pro.
  2. ASRDogman
    ASRDogman Senior Member
    7,788
    3,975
    So who's going to design them? YOU can do it! (y)
    Something that only likely needs to be replaced once in the life of the car, and is inexpensive?
    Unless you purchase aftermarket ones, then their is no telling how long those batteries will last.
    You CAN replace the battery, it's just takes some time. There are videos on youtube on how to do it.
    Remember you have to fill the void so to protect from the heat and possibility of the battery cell getting
    thrown out and flopping around in the tire....
  3. rjparker
    10,437
    6,544
    I love threads like this. Its easy to id the grumpy old men (some early onset). And some females who are under informed.
  4. ASRDogman
    7,788
    3,975
    Easy to id the kids that think they know it all..... ignored...
  5. Mendel Leisk
    41,850
    Yeah he lost me at “early onset”.
    I’d like to think I’ve developed a “surge pile” over the years, become less prone to knee-jerk reaction, separate wheat from chaff.
    @bisco is the sensei in that department. :)
    #45 Mendel Leisk, Feb 2, 2026
  6. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,508
    2,487
    Taylors, SC
    I'll keep mine as proverbial dead doornails and turn off the light on the dash.
  7. notspam3
    notspam3 Member
    88
    45
    Toronto
    2024 Prius Prime
    XSE Premium
    Did they get you to change your blinker fluid or just a top up?
    ASRDogman likes this.
  8. Cornvalue
    24
    Internet
    Business Ed. Plus
    That is just sad mansplaining and misogyny. And how do you determine that I am so under informed?
    Especially @ASRDogman answer makes me realize this forum is just full of old men who think they know it all.
    It’s like an answer from a 10 year old brain.
    Toyota implementation of TPMs is terribly stupid and bad on gen3.
    Any sensor without possible battery replacement ability should naturally be auto learned IDs when replaced.
    But you wish to explain this with a wish consumers should redesign it. That’s almost trumpian. Aha.
    Since y’all disagree, please mansplain why this system - that requires techstream to learn - is good.
    #48 Cornvalue, Feb 7, 2026
  9. VelvetFoot
    VelvetFoot Active Member
    1,162
    459
    New York State
    2026 Prius
    I agree, but too bad you had to throw in your ideology.
  10. Mendel Leisk
    41,850
    still, it’s the norm. So here we are.
    Didn’t take me long to come to same conclusion, but my take: if you take away the TPMS system, what happens? Not much. You’ve lost the convenience of an early-warming system, should be more vigilant, check your pressures regularly, and so on. But life goes on. :)
  11. VelvetFoot
    1,162
    459
    New York State
    2026 Prius
    I just ordered 4 ‘Toyota’ tpms sensors off eBay. 50 bucks each. I bet they’ll turn out to be counterfeit.
    Cornvalue likes this.
  12. Brian1954
    Brian1954 Senior Member
    2,386
    958
    South Central PA, USA
    Techstream is NOT required. Any scanner that is capable of writing the tire sensor ID numbers into the TPMS ECU can be used. A capable scanner does not mean it is an expensive scanner. The Autel AP200 scanner is capable of doing this, and it only costs $60.
  13. rjparker
    10,437
    6,544
    My TPMS system started going bad after ten years. $40 worth of parts and $60 labor and it was good for ten plus more years. The fact it does not auto learn is no big thing when the tire shops have a $60-$200 Autel tool to setup the tpms ecu in the car. Safety is not compromised when a 20 psi tire with a nail in it is not felt by the driver.
    That is my point others seem to rail against.
  14. hill
    8,909
    It's one of those things that work for some but most definitely not for all. If someone were to ask AI, for instance, the general rule of thumb is that the expected TPMS life is for 5 years in the world of somewhat certainty. Our plug-in had the unfortunate experience of a being on the short end of the stick as one of the set of four batteries died in under 2 years. That's most likely due to substandard TPMS quality batteries getting used.
  15. ASRDogman
    7,788
    3,975
    :confused::eek::rolleyes: Another crybaby..... ignore...
  16. Cornvalue
    24
    Internet
    Business Ed. Plus
    Oh my. That lack of testosterone really shows for @ASRDogman
    Anyhow, ask any Toyota dealer for a sensor replacement.
    That will not be the cost of the sum mentioned by @rjparker.
    This forum seem really hostile. Great work old men.
  17. hill
    8,909
    It's always a good opportunity to reciprocate grace to people that have never learned that life skill. Also - it's not just old folk that are short on kindness.
