Old mfd
Discussion in 'Gen 2 Prius Audio and Electronics' started by outtabounds, Jan 31, 2026.
  1. outtabounds
    outtabounds Junior Member
    46
    Metairie, LA
    Current one is trash. Bought a $29 junkyard one to try but screen looks worst. I'm wondering if there is an afforable cheap fix or if there is a delete option? All I can think of that's a needed function is the climate controls. Nav and bt is covered by my android unit. I saw a yt some guy had climiate controls working on an android unit but he didnt show how he did it. I also wonder if the mfd serves any other function that is needed for operation. I dont want to drop $200-$300 on a rebuild that will prob fail.
  2. Priapet
    Priapet New Member
    In my Prius
    You said the first one is “trash”. What is actually broken? The box under the driver seat is navigation, I can confirm completely unplugging it is perfectly fine. When you press any buttons on the right side of the screen, it gives you a basic message that Nav isn’t available. Looks way better than the ugly lines though.
    You still control climate by the MFD, you just add a small resistor between two wires.
    See around 7:06. I didn’t splice. I just shoved both ends into the back of the harness and taped it up,
