Head Gasket Replacement Shop Recommendations- San Francisco Bay Area
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by davekro, Feb 4, 2026.
  1. davekro
    davekro Active Member
    529
    83
    SF Bay Area, East Bay
    2013 Prius Plug-in
    [Edit] Well, crud, after just taking the time to type in all the blah, blah, blah additional diagnostic bits and pieces below that I have gathered... I read your post #18. I think I need to step away from the monitors and get the car to Gasket Masters for an assessment...]
    Since my wife drives it, I really have no idea how long it took to loose a 1/2 gal. of coolant. I may have stated before the last oil change I did, but I think that I would have noticed lowered coolant in the reservoir. So it may have lost coolant over these last 5 months (≈5600 miles). But my wife first reported the engine shake one week ago 1/28. At that time I added the half gal. of coolant. Since the few 6-mile round trips the car has been used for, the coolant level has not dropped from the full mark at all. Not sure what that info means.
    As the engine cools overnight, especially with our current overnight temps between 40ºF to 48º-ish, doesn't the coolant contract as the engine temp matches ambient temp, then essentially be close to atmospheric pressure by morning normally? Two nights ago, I was doing MY first drives in the car to test 'when' and for how long the shaking happened. When the Autel Live scanning showed 195º, thinking that was abnormal (glad to know it is not), I pulled over to look at the coolant level. It was exactly at the Full mark that I had filled it to the week prior. I decided to open the reservoir cap, and a big woosh of pressure was released. No coolant/ liquid came out at all. But the coolant level in the reservoir, strictly from releasing the pressure by removing the cap, was then ≈ 1/2" 'above' the Full mark it had been just before removing the cap.
    One data point from the Autel Live drive that I forgot to report was the 'Electric Water Pump Speed'. Autel says Target speed is 2450 rpm. When Coolant temp read 187ºF, 'Elect. W/P Speed was 3125 rpm. When Coolant temp read 195ºF, 'Elect. W/P Speed ranged between 3400-3500 rpm.
    Back to last week, 1/28, when my wife experienced the knock/shudder, she told me she checked the web that indicated to her it was likely low coolant. That day, I added a half gallon of coolant. I did a scan and it showed P0117 'Engine Coolant Temp Circuit Input Low' (maybe coolant below sensor level) and P148F 'Engine Coolant Pump Over Revolution' (maybe impeller cavitating due to low coolant). After adding the coolant, I cleared those codes and they have not returned.
    I still feel drawn to pulling the wipers and cowling, pull the plugs and check Cyl. 1 with a borescope. But, I do NOT have the experience and knowledge to make a complete diagnosis, so your wisdom here is settling in to this old brain to this time, 'let a trusted shop do it'. ;o)
    What does "may not choose to use a JDM based on a comment in one of their videos" mean?
    I'd be very curious to see the video you refer to.
    Thanks again RJ!
    #21 davekro, Feb 8, 2026
  2. davekro
    529
    83
    2013 Prius Plug-in
    rjparker, Thank you very much for posting these vidoeos, especially the Car Care Nut one.
    After watching the first video, seeing the details he describes, I now clearly see your point that I should just take it to Gasket Masters, have them diagnose the issues and listen to their recommendations and options. At 19:30 in the Car Care Nut video, he lays out how to frame the decision to repair vs. cut your losses and buy a newer version of the car you love(d), so the whole car is newer, not just the engine.
  3. davekro
    529
    83
    2013 Prius Plug-in
    Thanks for the comments. I am only 2 years your junior, but still working at my office coffee service business. Not full time, but too much time. ;o) My brain is slower in recent years, so I pretty much say it would take me 5 times as long doing the actual work... But I have to add in another 50% time for all the distractions to other tasks, not to mention my OCD "I need to make all these parts as clean as new, and other unnecessary, 'let's make it perfect' baloney. LOL Still not sure how to proceed, but I think a good first step is to let Gasket Masters do a genuine diagnosis, and go from there. Between you and me... I have had cases where I've thrown more parts at a car than needed. ;o)
  4. Mendel Leisk
    42,271
    I concur. Any time I take on something new there tends to be a few surprises as I get into it. Occasionally I’m defeated, but I just move on. More often than not I get it done though. Prep, plan, try a few prelim forays if practical.
  5. rjparker
    11,007
    6,898
    The aluminum head and cylinder contract allowing a possible very slight gasket leak to drip into the cylinder.
    It is also possible you have a very big leak.
    There is no level sensor. It basically means the sensor is reading low either from a wiring or thermistor failure or from air in the system. The car has two temperature sensors (thermistors).
    The fact you had water pump codes happen could mean the water pump is possibly a problem. It could also mean you were a half gallon low of coolant and the water pump was seeing air pockets.
    I don't remember which video but there was one. Most likely they were using JDMs until one failed on them under warranty and they had to redo it.
    JDM used in Japan engines can be as new as a 2021. I would do a JDM over a hg job especially on an oil burner. It helps if your mechanic can cherry pick the engine at a local JDM distributor rather than having one shipped in..
    Often as shops prosper, they want the sure solution even if it is three times the cost. Kind of the dealer mindset "install a quality rebuilt engine that did not overheat first." Which is what they do if the engine blows under a new car warranty and you are two years into a five year note. The dealer or similar pro shop gen3 rebuild will be $8k or more.
    Gasketmasters also had a video where they recommended preemptive head gasket changes before any problem occurs. Good idea on non-oil burners but unlikely to be followed by most owners of a 15 year old Prius who are convinced their car has been maintained well and head gasket or water pump problems happen to delivery drivers who neglect their Prius purchased at 175k miles.
    There are many factors, problems and solutions for Gen3 problems. If I lived in the expensive Bay Area I would get a problem car to their original Manteca location asap. If you lived in Central Texas I eould direct you to a JDM shop that has successfully swapped many hundreds of Gen3 engines and resolved every Prius issue out there.
    #25 rjparker, Feb 8, 2026
    davekro likes this.
  6. BiomedO1
    4,523
    2,378
    Left Coast
    My point is that a used JDM replacement is a 'crap shoot'. The gen3 engines has know defects, so you may only be buying yourself a year or two. My point of a properly rebuilt engine will have the technical fixes in place, so it becomes as reliable as a gen2 or gen4 engine.
    I'm a one and done kind of guy, that doesn't like to play wack-a-mole with know issues. Your gen3 head gasket IS a well know issue and a weak point of that generation Prius along with other long term engineering flaws. Addressing the head gasket is only one of them - IMHO.
    I had a friend that bought one of those late 90's early 2000 Honda accords with the automatic transmission issue. He got the car new and put 130K miles on it, before blowing up the transmission. Told him there was a know defect and he needed it get it "properly" rebuilt. We he got cheap and replaced it with a junk yard unit - 'supposedly' low mileage unit. Having a thick skull; he did that again when it failed on him again in a year. He eventually sold it to me for $500; and telling me Honda's are junk after 180k miles. I did a tune up and got the transmission rebuilt with the recommended factory reliability modifications and gave it to my niece. Last time I saw it was way past 350K miles with simple tune ups and oil changes, of course a bunch of additional dents from being a kid.
    It's your car and your money.............
    davekro likes this.
  7. davekro
    529
    83
    2013 Prius Plug-in
    This problem'ed 2013 will remain parked until I and my wife are available for me drive it there, knowing we may be leaving it there. I've read people say they took their Prius in for a diagnostic at Gasket Masters, the recommendation was change the head gasket, so they started right then and were done in 3-4 hours! I'd like to be able to take it there and if between their recommendation and the price seeming OK vs. 'Moving On', I'd like to just leave it there for them to proceed with the decided upon (HG or JDM swap). I was thinking to have my wife follow me there, so I'd have the option to leave it right then, but I guess I could just drive the Prius there, get the diagnosis, THEN call my wife to pick me up (50 min. drive) if needed. I don't mind the wait, but she would likely mind waiting for the diagnostics to get done. ;o)
    So we have had the discussion 'moving on'. She LOVES her Prius. When we talked about the 'move on' choice would mean we'd opt for a 2023 Gen 5 just coming off a lease. She LOVES the look of the Gen 5! She said she'd be happy either fixing her 2013 or as she calls it, the "looks like a Tesla" 2023 Gen 5. I am sure she would be happy with that swap! ;o)
    If the cards tell us we'll be looking for a new to us Hybrid coming off a lease, it would be a 2023 car. 2023 being the first year of a significant redesign the engine and of tech, not just the body, my "Be wary of buying the 1st year of a big redesign" (of any carmaker or model) pops up. What are PriusChat folks 20-20 hindsight on the then new 2023 Gen 5?
    I had no clue what the Gen 5's looked like so we watched a reviewer (young lady) describe all the things she loved and the one thing, not so much (plain Jane interior, way behind the competition, in her opinion). She said compared to the 2023 Prius, the competing KIA & Hyundai interiors were just WOW. It seems the closest KIA competitor to the Prius was their Niro. It is a whole different style, more like a small cross-over. It seems to have good ratings. It certainly rates better in headroom, back seat fitting adults, and larger cargo area, so those would be pluses. No idea if my wife would prefer a cross-over look to her self proclaimed 'Tesla look-a-like' Gen 5 (and its 40% more HP than her 2013, which the Niro does NOT have.
    If we went with the HG replacement route, IDK if these things would be an additional cost or if any of these would add significantly to what Gasket Masters considers a basic head gasket replacement price: Brand new Head Bolts, Thorough cleaning of the EGR system, water pump impeller (and bearing?), Cam chain tensioner, Thermostat. Are there any other components that you might as well do while it's torn down that far?
    Another thought... If we decided quotes they gave us for either the HG (+ other stuff above) or a JDM swap were such that we thought we'd better pass on those, that means we are writing off our 2013's engine. At that point we could consider two options: 1) There would be no downside to adding Bar's Leaks head gasket sealant and driving it until the issue reoccurs. 2) By a newer hybrid and either a) sell it for $1000 or whatever, to someone wanting to repair it themselves, or b) park it in the driveway (Non-Op & uninsured) until I have time to get to a DIY repair. b) would make it available to sell as a working used car as opposed to a project car.
    I'll stop there.. it's late. ;o)
  8. davekro
    529
    83
    2013 Prius Plug-in
    Mendel, what do you mean by "there’s been reports: hostile reactions to post-job issues, unaddressed collateral damage (broken/missing fasteners, for example)." Can you expand on your thought?
    Are you thinking that specifically Gasket Masters' pricing might be “too good to be true” and maybe "find out why, belatedly" due to either a too rushed job or that of a ton of variables in a HG replacement good become problematic just because? One concern I'd have about a HG replacement is how sure can Gasket Masters be in checking both the head and block for not being warped at all. We know the tight tolerances make any resurfacing, especially if it is the head -and- block a problem of ever getting the time to be right again.
  9. davekro
    529
    83
    2013 Prius Plug-in
    @rjparker
    Prior to driving the Prius to the Manteca Head Masters shop for a full diagnostic, if I were to remove the wipers and both cowls, carefully bagging and labeling all the bolts/nuts I remove: 1) Am I correct in assuming it is fine to drive the car with the wipers, cowling, and hardware stowed in the back as I drive the 50 mins. to Manteca? 2) Would Head Masters not like to see this minor disassembly done by the customer enough that it would erk them or otherwise be a problem? Or would they be OK with me having done this?
    It turns out my brother-in-law has a borescope he's going to lend me. Two reasons I am still curious to pull the plugs and look into the cylinders. I am VERY curious to learn the car's cylinders' condition visually myself. Most shops would not like a customer 'hovering' as they did the borescopeing, in fact don't allow customers in the shop area at all. I assume that is most likely (for good reason ;o). That is why I'm still drawn to peeking into the cylinders to see what's there first hand. Additionally, It would save my and their time in getting to the actual diagnostics part of the process (and save me some labor cost, m a y b e ;o)
    I understand your previous comment on not telling the shop what I believe is the problem. That they do not like that.
    So I'm wondering how much I should share of the timing of what we have observed of when the engine shake happens (never when started cold. Always after getting to op. temp, and the engine being off for a few minutes). The initial P0117 and P148F codes that went away after 1/2 gal. of coolant was added (to full) a week ago. Then a day later after two short 6 mile round trips, then the P0301 code appeared. Now a week later and ≈ only 30 miles in these short trips, the coolant level has not dropped. Is that TMI, or info they'd want to hear? (I'd put this info into Chat GPT to get is reworded as concise as possible. ;o)
  10. rjparker
    11,007
    6,898
    I would put it back together and plan on leaving the car.
    davekro likes this.
  11. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,756
    1,784
    Bay Area
    I’ll buy it for 1k if you’re selling it
    davekro likes this.
  12. davekro
    529
    83
    2013 Prius Plug-in
    I'm sure it would be a great buy for someone very familiar the repairs. ;o) My thinking lately, is that even if we decide to buy a new Hybrid to replace it, I'd likely keep it until I have time to leisurely tear into it, where I don't feel the wife's pressure to 'Get 'er Done! LOL. Then I could sell it at the going rate for that year and mileage.
    @NutzAboutBolts , do you live in the SF Bay Area?
    bisco and NutzAboutBolts like this.
  13. NutzAboutBolts
    1,756
    1,784
    Bay Area
    :ROFLMAO::ROFLMAO:
    Yes, I live in the Tri-Valley :) But I also work on the Prius at my own Leisure or when I can get to it since I have other stuff going on :ROFLMAO:
    bisco and davekro like this.
  14. Joele3
    Joele3 Active Member
    137
    205
    Bay Area
    Ive taken a gen 2 to earthling automotive back when they were known as Luscious Garage. I had them replace a gen 2 AC compressor. Pricey but got it done with no issues. Thankfully the gen 2 I had was pretty much bulletproof. My 2010 on the other hand not so much. I did a gen 4 motor swap into it. One year ago did a head gasket on my 14 V wagon. Id go with headgasket over gen 4 swap. Only reason I did the swap on 2010 that thing slurped on oil like crazy. Gen 4 motors at the time were dirt cheap 800$. Im sure you can do the headgasket DIY with Nutzandbolts YouTube video on standby.
  15. davekro
    529
    83
    2013 Prius Plug-in
    I am taking our 2013 to Gasket Masters in Manteca (Ca) tomorrow for a 9:00am diagnostic appointment. We'll see what they have to say after scoping cylinder #1 and the rest too, I assume. I did not pull the wipers and cowls after all, to check the plugs and scope #1 cyl. I did not have time.
    One term that @Mendel Leisk and you have referred to was "COLD-START engine shake". My wife says she never got the engine shake when first leaving the house after it had sat overnight. I in the few test drives I have done with it, I had the same experience. No engine shake when starting up first thing after it had sat overnight. For both of us, It ONLY shook AFTER the engine had gotten to operating temperature, then had been parked any more than 3-4 minutes to whatever it took to finish that short run into a store... THEN and only then, the first time the ICE engine started, shake/shake for 1-2 seconds, then run fine until you got to your next stop.
    So is THAT still considered a "Cold-Start", in Gen 3 head gasket failure lingo? Because, the term does not seem to logically fit, being that it has yet to have engine shake from a genuine cold-start. I've not heard anyone address what the "Warm-Start engine shake" meant, in contrast to what a literal cold-start engine shake means.
    Yesterday, to coolant was down a bit after ≈ 500 miles since the initial half gallon was added 3 weeks ago. It used a little less than 1 quart this time (to bring it back to full).
  16. rjparker
    11,007
    6,898
    Good luck. You are doing the right thing getting it diagnosed.
    If it had not lost coolant I might think it had a sticking open egr valve which is easily diagnosed with a egr block flow test.
    With the coolant loss there needs to be an explanation found. Normally you can go years without losing an observable amount of coolant. Pink coolant is pretty easy to see unless its going through the exhaust either through a hg leak (typical) or an exhaust heat recirculation leak (not typical on a gen3 but will continue if it starts). An exhaust heat recirc leak won't cause rattles but will quickly overheat the engine.
    egr block flow test
    #36 rjparker, Feb 20, 2026
    davekro likes this.
  17. Mendel Leisk
    42,271
    Gotta be head gasket.
    davekro likes this.
  18. davekro
    529
    83
    2013 Prius Plug-in
    Andrés at Manteca Gasket Masters was great! He did not pull the plugs to scope. From my description of the codes, the timeline, and him removing the coolant tank cap getting a strong 'woosh' he was confident it was the head gasket. He said exhaust was leaking into the coolant system, causing extra pressure. He was extremely helpful in answering all my questions.
    I asked about how he decides if my head needs to be resurfaced. It was awesome that he had three used heads to show me the areas where the head gasket had leaked -and- the varying levels of 'sludge' on the top of the head.
    1) Heavier sludge (rec. installing an on hand rebuilt head),
    2) Acceptable sludge (OK to reuse my head if it is in this condition - if not warped),
    3) No sludge (I hope mine is in this condition ;o).
    I asked if he could email me pictures of my head's condition, he said, sure. :):)
    I asked how he'd know if the water pump needed replacing. He showed me a used water pump. It was hard to turn by hand, so if mine was like that, it should be replaced.
    I was very pleased to hear the prices!
    $1,850 Replace Head Gasket- Includes: Fel-Pro head gasket, Intake Gasket, New head bolts, new seals as needed, Denso Spark Plugs, PCV valve, Clean EGR valve & install a pre-cleaned EGR Cooler, Oil and filter change, One year, unlimited miles warranty.
    • +$350 for OEM Toyota Water Pump, if needed.
    • +$350 for Rebuilt & Resurfaced Head, if needed. He had two shiny rebuilt heads available on his bench! Surfaced (within spec.), Valves lapped, etc. (very impressed!).
    @rjparker , you were correct that Gasket Masters no longer does JDM engine swaps. They had too many times when the used engine's head gasket failed way too soon! They must not have actually been 70k engines, I'd assume. (?)
    • For $3,250 they would install a refurbished engine w/ a rebuilt head, (IIRC, pistons & rings checked, maybe more, IDR)
    Bottom line, I am very pleased to get my wife's baby's Head Gasket repaired for $1,850. I'd be glad to pay +$350 each if it happens to need a water pump and/or a rebuilt head.
    I'm very interested to see the pictures he will send tomorrow of my head and cylinder walls. LOL, curious to see the 'sludge level' on the top of 'MY' head, to see if I have been a 'good boy' or a 'bad' boy regarding oil change intervals. ;)
    The attached my symptoms summary and random pics of Prius heads in varying conditions (and a block) in their shop:
    • The one-page symptoms/ timeline and DTC codes sheet I gave him.
    • The tops of three random heads in the Gskt Mstrs shop with zero, medium, and heavy degrees of 'sludge'
    • The under side of this head he said was warped. He said that was indicated because the gasket failed between each of the cylinders.
    • He did not comment on the block. I just saw it and had to take a picture! ;o) I felt the top of the bore with my finger and felt no ridge.
    • A picture of the front of the Manteca, CA Gasket Masers shop with our 2013 Plug-In next in line for a head gasket replacement. :D:D
    Our car was second in line for today. They were not able to finish it. I'll hear from Andres tomorrow morning on the condition of my head and water pump were fit to be reused. Plus, he will email me pics of my head, top and bottom, as well as the block. I am very curious to see what 214,000 miles looks like on a Prius. (y)(y)
    TLDR (my questionable engine rebuild skills growing up ;o):
    My first car in high school was from my uncle in LA who had passed away. It was a '62 2 door Mercury Monterey, 390 cid. It was blowing oil badly. It maybe had 170k-ish miles. It had not been cared for. The sludge on the heads was prob. 1/8" thick with a hard, dried outer crust! I had watched my dad work on and pull engines growing up. It was fun to tear the engine down and send the heads and block to the machine shop. The machinist called and asked if I had marked where the crankshaft bearing caps had come from. What, that matters?? (The school of experience ;o). He said he'd mic them and make his best guess. Oops.
    At about age 14, my Taco 44 mini bike's Briggs and Stratton engine ran fine, but I thought it might be dirty/ sludgy inside, so I tore it apart hoping to find 'stuff' in there slowing it down. LOL. Of course, it was clean as a whistle. I put it all back together, pulled the cord to start it, and it came about halfway out and stopped. I yelled : "DAD, it's stuck, it won't turn over." He said, did you time it? Me, what's that? Oops, learn by experience... Align Timing Marks, dude. Who knew! ;)
    Edited: a few words
    Head-1 w. NO 'sludge'  (not mine)(black sealant).jpg Head-2 w. Acceptable 'sludge' (not mine)(orange sealant).jpg Head-3 w. Bad 'sludge'- He'd recommend a Rebuilt Head for this condition .jpg A Warped Head sitting in the Gskt Mstrs shop.jpg A Block sitting in the Gskt Mstrs shop.jpg GsktMstrs Shop #1 with our 2013 'next-in-line' ;o) .jpg
    #38 davekro, Feb 20, 2026
    hitsue likes this.
  19. rjparker
    11,007
    6,898
    Run it like a banshee when you get it back. You want to ensure its good during the warranty year.
    davekro likes this.
  20. davekro
    529
    83
    2013 Prius Plug-in
    My wife will say: "Well, I can do THAT." "But officer, my mechanic said to drive it like I stole it during the first year under the repair warranty!"
    :D:D
