How common is Gen 2 Head Gasket Failure after 300,000 miles?
Discussion in 'Gen 2 Prius Main Forum' started by PrimalPrius, Feb 6, 2026 at 5:10 PM.
  1. PrimalPrius
    PrimalPrius Junior Member
    40
    America
    The coolant should be at 13 PSI, give or take, so way less pressure than combustion, so should be way less likely to cause a gasket failure than cylinder prssure.
  2. PrimalPrius
    40
    America
    I'm guessing that a water pump-to-oil (via timing cover) failure path, if it happens, is likely often assumed to be head gasket and never discovered since the timing cover RTV would likely not be examined in great detail, if at all, and would get replaced when the engine is put back together or never seen when the engine is junked...
  3. PrimalPrius
    40
    America
    The timing chain cover, as designed is actually "poor design", except for parts cost/parts count and assembly cost, which is what probably matters the most.
    A separate piece for the water pump would have ensured that any possible leak is external and easily detectable (instead of mixing with oil and taking out the engine).
    I'm not saying that it's what is happening with my car, just saying that it's optimized for cost at the expense of quality and durability, regardless of how common or rare failures there are.
  4. PrimalPrius
    40
    America
    Some more data:
    Under the UV light, the inverter coolant already in the car also looks Peptobismol light pink, but cleaner than the coolant (which, I'm ashamed to say, was on my "change ASAP" list when I got the car 50k miles ago...).
    An unopened bottle of (Prestone, I think) coolant marketed as Toyota spec is also Peptobismol color under the light.
    Brand new oil (synthetic) under the light is white, whereas my oil (with only 325 miles on it) is a very light blue or very light purple.
    Interestingly, it looks like with the light I have, dye would not be required, at least not for coolants and oil I have, if searching for an external leak.
    #24 PrimalPrius, Feb 7, 2026 at 8:10 PM
  5. dolj
    dolj Senior Member
    8,490
    4,308
    Wellington, New Zealand
    Excluding your dataset of one, this conclusion is not borne out in the general population of this model world-wide.
  6. PrimalPrius
    40
    America
    I believe that they all have the same cover design as my car. I purposely put "poor design" in quotations because it all depends on what the design objectives and constraints were.
    If the objective was low cost though lower parts count, lower assembly time, etc. then using a single cover is a success.
    If the objective was to focus on minimizing potential coolant-to-oil failure paths and some added cost was allowed by the design constraints (which is what I would have picked, but Toyota obviously didn't), then they failed.
    I have no idea if that is the failure mode in my car, but it is a possible failure mode and I believe that a failure there could very often be misdiagnosed as a bad head gasket.
    #26 PrimalPrius, Feb 7, 2026 at 9:52 PM
  7. pasadena_commut
    pasadena_commut Senior Member
    2,748
    821
    Southern California
    I'm getting very confused.
    If there is milky oil collect a small but macroscopic amount of it (like 1 cubic inch), put it in a small capped clear container of some sort, and let it sit for a day at room temperature. It should separate into an upper oil phase and a lower aqueous phase. If it does and the contaminant is coolant the lower phase should be pink, but water from some other source, like combustion gas getting past the rings and into the crank case, won't be that color. This assumes that the pink dye is sufficiently hydrophilic that it stays in the water phase.
    Or just do an oil change and pour all the oil into a container like a PET 1 gallon water bottle. Then wait for it to separate. But don't leave it in that container for a very long time as used motor oil might make the plastic brittle or leak. For long term storage transfer the oil to something like HDPE. HDPE isn't clear though.
    PrimalPrius likes this.
  8. PrimalPrius
    40
    America
    Yes. I'm planning on pulling a sample through the drain plug and letting it sit in a tall glass.
  9. PrimalPrius
    40
    America
    I took a sample from the drain plug without disturbing the oil (without cranking the engine), about 1 quart. The oil has been sitting undisturbed in the oil pan for about 3 days now. I was expecting to maybe get some coolant or water out first, but I did not notice any at all.
    The oil is light brow, substantially different, of course, from any oil I have drained from the car before. There was a pretty strong gasoline smell I have never noticed before.
    In the container the oil does not respond to the UV lamp at all. when spread thin on the paper it glows the same light blue/light purple under the light as oil obtained from the dipstick.
  10. PrimalPrius
    40
    America
    I filled a tall glass with the oil and covered it with Saran wrap. (I'm not very optimistic that it will separate, but time will tell).
    Not sure why the oil this time smells so much like gasoline, especially after only 325 miles.
    I checked again and no misfire or any other engine codes.
