Please help c1241 code ✳️✳️ Update the local garage told me it HV traction battery problem. And he told me he had recalibrate the battery because the cells were not even, some 80 % and some 50%. He did this by using a snap on scanner only. And it took approximately 30 minutes. Is this possible I paid him for the work. As I drove out of the garage. The braking system light re appeared. Thanks for looking everyone.
I think I would not return to that garage. C1241 is not about the traction battery, and there is no traction battery 'recalibration' that balances the modules in half an hour using only a scan tool.
Hi thanks for your reply. He insisted that he balanced the battery via a snap on scanner. It may have been one hour. Do you think the the 12 volt battery that needs replacing.
He can insist all he wants; there's no scan tool function to 'balance' a traction battery that I know of. Not in half an hour, not in an hour. So far, I can't say what "needs replacing", if anything. It sounds like you have a C1241 code. You can search for C1241 on this page, and you'll get the basic idea what things can cause it and where to start looking: Blink (a/k/a Flash) Codes – How to. | PriusChat Fixing or replacing anything comes after finding the cause of the problem.
the 2nd gen Ford Escape Hybrid has that balancing feature using a scan tool (Forscan) but I don't think any Toyota hybrid has that. Your mechanic just basically screwed you..
Those codes are both from ABS/VSC/TRAC because it is seeing a 12V battery voltage that is too low. (Neither is about the HV battery). First step is to charge your 12V with a battery charger. Keep a jump pack with you if you have one.
