Featured Toyota Debuts Stylish, Powerful 2026 C-HR Battery Electric Vehicle
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Tideland Prius, May 14, 2025.
  1. bisco
    52,335
    I’ll take a when they’re on the lots and willing to deal.
    That should eliminate them :p
    bwilson4web likes this.
  2. Mendel Leisk
    41,850
    Toyota seems to be having a tough time selling their current pure-electric model, current inventory near us:
    Merkey and Tideland Prius like this.
  3. mikefocke
    4,039
    1,834
    Sanford, NC
    Not sure that things aren't slowing down in the big prices world.
    I happened to be in Walmart today and noticed the stacks of TVs sitting in the aisles with not a single customer to be seen and not a single one going out the door and this 5 days before the super bowl. I'll watch on my 3 year old 84" that is probably available now for 1/3 what I paid for it.
    I also frequent a Facebook like site called Nextdoor which is locality oriented. Every third posting is a tale of woe and begging for $ or things. Every third posting is asking for the cheapest whatever.
    The wonderful thing about that site is no politics or religion just like this one. Separate groups for that.
  4. drash
    drash Senior Member
    2,586
    1,328
    Upstate NY
    I stand corrected, you can now get the specs on Toyota's website as well as build one (2026 Toyota C-HR | Toyota.com). Not the first time Toyota put specs on the site before their Pressroom site.
    There are a few differences between original press release and Toyota's site, along with some other notables:
    • EPA Range: 287 mile (462 km) for the SE trim with 18" wheels, EPA Range for XSE trim with 20" wheels: 273 miles (439 km). Press release said up to 290 miles (467 km) Manufacturer estimated Range. nothing to really argue about but yes the bZ XLE AWD gets 288 EPA miles range.
    • MPGe EPA rating. SE: 117, XSE: 112
    • Press release said around 5 seconds for 0 - 60 mph, Toyota Site: 4.9 seconds for 0 - 60 mph
    • Cargo space is 25.9 cu. ft. behind the rear seats, 59.5 cu. ft. behind front seats (rear seats folded). This is actually more than the bZ at 56.9 cu. ft. So you have to ask how did they do that? Um rear leg room is a full 3 inches (79 mm) shorter than the bZ. Only the Toyota Corolla Cross has less rear leg room.
    • Still sits at 8.0 inches (203 mm) of ground clearance which is about the same as Toyota's other SUVs.
    • With the SE trim sitting at 4,322 lb curb weight it is only 44 lbs lighter than the bZ XLE AWD.
    • No Towing but you can get an Activity mount as an accessory.
  5. bisco
    52,335
    volume is a useless measurement. all mfg's should be required to supply length, width and height of the hatch area, rear seats up and down, front seats all the way back
    #65 bisco, Feb 7, 2026
  6. drash
    drash Senior Member
    2,586
    1,328
    Upstate NY
    Actually they already do most of that for the C-HR and bZ. It's under Dimensions. My preference, however, is load height which almost never appears unless I do it myself.
  7. Tideland Prius
    16,609
    I wonder how many are the pre-refresh ones. Compared to the refresh, it’s a much harder sell.
  8. Trollbait
    12,662
    How about we start with them all using the same edition of the standard for marketing, preferably the one the one required for the EPA size category?
    Then we move to using something like the trunk volume measurement; how many of standard boxes can be fitted inside. Europe uses such for SUVs and estates.
  9. bisco
    52,335
    I’m not interested in how many projectiles can be piled above the height of the rear seats
  10. drash
    drash Senior Member
    2,586
    1,328
    Upstate NY
    Oh no, total height is very important, since people everyday buy rather large boxed items and shove them into the back of their vehicle. Even plain bulky items, it would be a common sight to see people load them in from the garage sale they just visited.
  11. Trollbait
    12,662
    It isn't the number they report. The boxes are known volumes. Put as many as you can into the cargo area with squeezing them. Then add up that volume. What the US uses for SUVs and wagons now is the measurements you want. These allow wiggle room that leads to unusable space being counted. Like the indentations on the side panels and dead space behind the rear seat from the seat's recline angle.
    It is why the numbers for trunks are under reported, and the ones for SUVs over reported.
    Tideland Prius likes this.
  12. bisco
    52,335
    we'll have to agree to disagree. all I want is height, width and depth
  13. mikefocke
    4,039
    1,834
    Sanford, NC
    Can a dishwasher fit is all I want? In a Rav4h, the answer is yes.
  14. Trollbait
    12,662
    Not saying instead of that. And since they are taking those measurements for the volume now, it would be easy to post them.
    But there are issues there. How do you want the measurements done? Take depth, do you want them measuring from the hatch to the base of the rear seat back or the top of the seat? With the rear seats down, how far back should the front seats be and what incline those seat backs are at? For width, do you want between the walls, the wheel wells, or the hatch opening?
    Without defining how it's done, you will see different results for the same model. In the US, the published standard from the SAE is used for measuring cargo space. It's one standard with almost a dozen versions. The EPA states which one to use for interior volume for size class designation. The means all the rounded volume figures on Fueleconomy.gov were done the same way and comparable.
    For the manufacturers' sites, they are free to use whichever version they want. Legally, they could use their own method. So comparisons need to be taken with a grain of salt. That will be true even with the height, width, and depth measurements.
  15. Mendel Leisk
    41,850
    For cargo/storage assessment, a Project Farm style assessment would be good: how many suitcases can go in the hatch/trunk, seat fold-down, and so on, something more subjective than raw numbers. YouTube opportunity?
  16. bisco
    52,335
    suitcases aren't standard sizes. floor measurements are fine with me, but whatever standard they use, at least you can compare
  17. Trollbait
    12,662
    The cargo areas aren't standard shapes. Some are squarish, some have sloping ceilings like the Prius. They all have some slope to the rear window. A box that takes the floor to the door edge could hit the window while having plenty of space clearing the roof.
    The issue is that any measurements published now aren't following a standard. Looking at just a number, you can't tell if it is taken from the longest, shortest, or best usable point, at this point in time.
    Wayne Gerdes of Cleanmpg will include measurements in some reviews. When he does, he includes photos of where the tape measure is at for them.
  18. bisco
    52,335
    Yes, that’s what I want. I doubt manufacturers are interested
  19. flim
    flim Active Member
    260
    183
    Huntington Beach, California
    2023 Prius Prime
    XSE Premium
    C-HR EV gets $5000 Discount MSN
  20. flim
    flim Active Member
    260
    183
    2023 Prius Prime
    XSE Premium
