Dongar connector for dashcam
Discussion in 'Gen 5 Prius Accessories and Modifications' started by AndersOne, May 24, 2024.
  1. AndersOne
    AndersOne Active Member
    344
    199
    Europe
    2023 Prius Prime
    Roberto Amador likes this.
  2. PhoS
    PhoS Active Member
    257
    210
    Nowhere
    2023 Prius
    Limited AWD-e
    I'm almost certain the same connector is still there digital mirror or not. It would take you 2 minutes to pop the cover off to look.
  3. AndersOne
    344
    199
    Europe
    2023 Prius Prime
    I dont have my P5 yet but was wondering to buy the connector already while going to the states to save on shipping costs.
    Even if the connector is the same - couldnt be there a chance, that some "new important" pin is not included yet?
  4. Lantaral
    Lantaral Member
    66
    31
    US
    2024 Prius
    The Dongar only works on models that have an auto-dimming mirror. It shunts into the mirror's power plug.
    There is another power plug under the same panel, but it's for Toyota Safety Sense, the Dongar can't use it. Their guide page (expand Toyota / Lexus) has example images.
    Adapter Guide – Dongar Technologies LLC
    soft_r likes this.
  5. srwax
    srwax Junior Member
    29
    31
    Las Vegas, NV
    2023 Prius
  6. AndersOne
    344
    199
    Europe
    2023 Prius Prime
    I read all this but they don't explicitly mention the digital mirror - after all the digital mirror has to send some video from the back of the car that has to got through the same cable. Or is there an exta cable for the video feed?
    So far apparently none has experience with the dongle + toyota digital mirror
    The wolfbox has its own cable for the rear video signal feed I assume.
  7. Lantaral
    Lantaral Member
    66
    31
    US
    2024 Prius
    Suggest emailing them. They respond quickly to support inquiries.
  8. srwax
    srwax Junior Member
    29
    31
    Las Vegas, NV
    2023 Prius
    Yes, The wolfbox G850 that I got come with a 1080p rearview cam that I attach at the top of back window.
    Typical digital mirrors should can with power source cable, GPS unit and rearview cam that all use different cables.
    The Dongar adapter just an extra USB type A port that you can use as digital mirror's power source, so you don't have to wire it from any type C ports or fuse box.
  9. AndersOne
    344
    199
    Europe
    2023 Prius Prime
    So not sure if they updated their instructions or I missed it earlier - no digital rear view mirror. Its sold out anyway
  10. PixelRogue
    488
    86
    US
    I have a Wolfbox as well, partially installed and getting close the hard wiring. Does this adapter support parking mode, or just while car is on?
  11. WaikikiPrius
    WaikikiPrius New Member
    2024 Prius Prime
    XSE
    i purchased the FitDVR which is much cleaner and cheaper! you can find it on amazon!
    blfuller likes this.
  12. PixelRogue
    488
    86
    US
    Right, they are one of the companies with an adapter that works w/Wolfbox. The key question is if the adapter supports parkinglot mode (meaning there is one power lead that works while the ignition is on, and another power lead that works 24/7 while the car is off.) This would be the way to go to hardwire if it has the 24/7 lead.
  13. WaikikiPrius
    2024 Prius Prime
    XSE
    wolfbox also sells their always on kit called Wolfbox OBD
  14. PixelRogue
    488
    86
    US
    Yes, already have it. The discussion has been around wiring the cam/s w/o the need to visit the fuse box. The space by the mirror already has access point to tap into ignition power. Some of the kits (not Wolfbox) tap into the wires/harnesses around the mirror (ie. adaptive cruise control.) It is my understanding these kits do not support parking mode (always on) and was clarifying.
    I'd like to wire the dashcam from wires that are already in the vicinity. In theory, there should be an always on dome light wire, in conjunction w/an ignition on wire (adaptive cruise) so no need to bring a wire down; plus, once you tap a fuse box lid never goes back on right and looks like a hack job.
  15. PixelRogue
    488
    86
    US
    In theory, it would seem the Wolfbox Dashcam could be wired completely from the top, tapping the ADD wire for ignition power, and dome light for always on power (parking mode.) Now, not sure if the amps/watts etc would match. Thoughts?
  16. blfuller
    blfuller Junior Member
    37
    Eastern Washington State
    2026 Prius
    XLE AWD-e
    Same here. Works great with aftermarket dashcam.
  17. MScelery
    MScelery Junior Member
    83
    25
    Mississippi
    Amazon has adapters that plug into the safety sense 3.0 connector to supply power to another device. Maybe look into that?
  18. fourenty
    fourenty Member
    47
    26
    Endwell, NY (near Binghamton)
    2024 Prius
    Limited AWD-e
    I just installed the Donger Classic 10B on my 2024 Limited with digital rearview. Very easy install. I would have liked if everything fit inside the plastic cover over all the safety sense electronics. The brick that usb cable plugs into is mounted to the back of the rearview. It is still a nice clean install with nothing to see while seated or from outside looking in.
    AndersOne likes this.
  19. dicknose
    dicknose New Member
    Toronto
    2024 Prius Prime
    XSE Premium
    I used Dongar copy from Amazon (brand name is Hifihia) in my '24 Prime and its working great so far. All the wiring fit under the cover, nice clean install.
  20. AndersOne
    344
    199
    Europe
    2023 Prius Prime
    Cool...Thanks. Funny enough i ordered it back then but was too lazy to ever add it, as the long usb extension from the middle console was actually not as bad as i thought. Might try it again! But if they brick is ugly anyway the improvement might not so big.
